Need help Fixing my app Tandoor Recipe
So I started to use the app Tandoor Recipe on Monday, it worked great so I added something like 200 recipes. And today, I decided to change a bit the folder for the “Integrated Persistent Storage”. To be precised, it was originally in a folder named RECIPES, and I just added another dossier so RECIPES/Tandoor Recipes.
But it blocked, I got an error message, and I am now stuck. If I try to start the app, it just indicates “deploying” but nothing happens, and if I try to change the storage, I just got the same message.
Please help me, it took me a lot of time to put all my recipes in it, I will be very sad if I loose everything.
Relative information
  • Tandoor Version= 1.5.17
Truenas Scale Version= Dragonfish-24.04.1.1
“Title” of the error window
[EFAULT] Failed to update App: WARNING: Kubernetes configuration file is group-readable. This is insecure. Location: /etc/rancher/k3s/k3s.yaml Error: UPGRADE FAILED: pre-upgrade hooks failed: 1 error occurred: * timed out waiting for the condition
Information in the “More information” part
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 469, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 511, in __run_body
rv = await self.method(*args)
File “/usr/lib/python3/dist-packages/middlewared/service/crud_service.py”, line 210, in nf
rv = await func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 47, in nf
res = await f(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 187, in nf
File “/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/chart_release.py”, line 568, in do_update
await self.middleware.call(‘chart.release.helm_action’, chart_release, chart_path, config, ‘update’)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1564, in call
return await self._call(
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1428, in _call
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1321, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/helm.py”, line 49, in helm_action
raise CallError(f’Failed to {tn_action} App: {errmsg}')
middlewared.service_exception.CallError: [EFAULT] Failed to update App: WARNING: Kubernetes configuration file is group-readable. This is insecure. Location: /etc/rancher/k3s/k3s.yaml
  • timed out waiting for the condition
