I have a YuanLey 10G Base-T Ethernet Card with Intel X540 network card.
I have a 2.5g router plugged into 1 port of the card and a 5g adapter plugged into the other port on the card. The adapter on my Mac connects to the card at 5g and the router at 2.5g. So from a hardware point of view it is all working. On the UI in Truenas the speed is stuck at 1000mb/s on both interfaces. If I transfer a file through either port, it maxes out at 1000mb/s.
The card is plugged into the bottom 16x PCIe slot so it should be running at 8x speed.
Any suggestions would be helpful.
Thanks
