New user needs help with rebalancing
In the process of moving from unraid to scale. I am having to do it a piece at a time. I got one vdev setup, 8 wide raidz2 filled it to 81% which cleared enough drives to setup second 8 wide raidz2 vdev. I thought truenas would place new data on second vdev to balance use. Started moving data but stopped when vdev1 hit 85% and vedv2 was 4%. I downloaded the rebalancing script but can’t get it to run, probably permissions, but I’m stumped. I ran it on one folder in case it went horribly wrong. Opened shell, ran script and it copies first file to .balance, then i get error on second line, cp: preserving permissions “Operation not permitted”. Sudo or sudo su makes no difference. I tried changing owner to admin and root on the folder and files, no difference.
Post your complete hardware, TrueNAS version, pool setup and if you are sharing.
scale 24.04.2
hp z840 computer, dual e5-2630v4 CPU’s, 64GB memory
quadro p620 for transcoding, connectx 10G network card
LSI 9207-8e connected to ktn-stl3 and md-1000 JBODS
mirrored 80G ssd boot pool connected to MB SATA ports
1 pool of 8x14tb raidz2 vdev and 8x10tb raidz2 vdev
SMB sharing
I also tried disabling the share on the dataset I am trying to rebalance, same error.
Figured it out, needed to set acl mode to passthrough. Reading up on ACL made my eyes bleed, but got rebalancing working.
