No previous versions
I dont see any options to revert back to snapshots in windows previous version tab.A while ago i ran into this same problem, cant remember what i did to fix it.
version im using is TrueNAS-13.0-U6.8
zfs list -t snapshots shows snapshots.(i can show screenshot if needed)
There tasks listed inside Task>Periodic Snapshot Task with the green Finish state.
when I make a test file and put text into it then wait for the system to create a snapshot of that change, nothing shows up under previous version.
A long time ago I remember (11.1) this could be fixed with an AUX parameter.
If someone could help me figure this out that would be great.
TIA
I posted some snapshots of my setup. If anyone has any ideas please let me know.
Can you share a screenshot of your SMB share config from the TrueNAS UI?
Thank you very much for the replay fartpants!
Let me know if this is what you are asking for.
Those auxiliary parameters are probably breaking things. Get rid of them and try again.
My snapshot happen on the hour, let me make a change to a test text file and i will report back.
TYVM
Yup that was it.
Any idea how they got there?
Excellent. Thanks for the update and glad it’s all working for you.
They must have been manually added at some point I’m sure with best intentions.
