NVMe pool slower than HDD pool | What am I missing here?
MB: X10SRi-F
PCIe 3 slot 5 x8
My setup has two pools:
Data pool is comprised of 4x 4TB HDD in RAIDZ2
  • 2x Seagate IronWolf ST4000VN006-3CW104
  • 1x WDC WD40EFPX-68C6CN0
  • 1x WDC WD40EFZX-68AWUN0
machines pool is comprised of 2x 240GB NVMe M.2 on PCIe converter card in x8 slot bifurcated in BIOS in mirror:
  • SAMSUNG MZVPW256HEGL-000L7
  • Patriot M.2 P300 256GB
I ran some tests and unless I am mistaken, the HDD pool gives significant write performance than the SSD pool and HDD reads as fast as the SSD pool, maxing theoritical SATA 6GB
How is this possible ?
HDD pool write
truenas_admin@truenas[/mnt/Bassin/testpool]$ sudo fio --ramp_time=5 --gtod_reduce=1 --numjobs=1 --bs=1M --size=100G --runtime=60s --readwrite=write --name=testfile
testfile: (g=0): rw=write, bs=(R) 1024KiB-1024KiB, (W) 1024KiB-1024KiB, (T) 1024KiB-1024KiB, ioengine=psync, iodepth=1
fio-3.33
Starting 1 process
testfile: Laying out IO file (1 file / 102400MiB)
Jobs: 1 (f=1): [W(1)][100.0%][w=235MiB/s][w=235 IOPS][eta 00m:00s]
testfile: (groupid=0, jobs=1): err= 0: pid=2899517: Wed Jul 29 12:25:45 2026
  write: IOPS=254, BW=255MiB/s (267MB/s)(14.9GiB/60015msec); 0 zone resets
   bw (  KiB/s): min=34816, max=362496, per=100.00%, avg=260829.66, stdev=68093.48, samples=120
   iops        : min=   34, max=  354, avg=254.59, stdev=66.47, samples=120
  cpu          : usr=0.97%, sys=9.30%, ctx=15619, majf=0, minf=37
  IO depths    : 1=100.0%, 2=0.0%, 4=0.0%, 8=0.0%, 16=0.0%, 32=0.0%, >=64=0.0%
     submit    : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
     complete  : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
     issued rwts: total=0,15280,0,0 short=0,0,0,0 dropped=0,0,0,0
     latency   : target=0, window=0, percentile=100.00%, depth=1
Run status group 0 (all jobs):
  WRITE: bw=255MiB/s (267MB/s), 255MiB/s-255MiB/s (267MB/s-267MB/s), io=14.9GiB (16.0GB), run=60015-60015msec
HDD pool read
truenas_admin@truenas[/mnt/Bassin/testpool]$ sudo fio --ramp_time=5 --gtod_reduce=1 --numjobs=1 --bs=1M --size=100G --runtime=60s --readwrite=read --name=testfile
testfile: (g=0): rw=read, bs=(R) 1024KiB-1024KiB, (W) 1024KiB-1024KiB, (T) 1024KiB-1024KiB, ioengine=psync, iodepth=1
fio-3.33
Starting 1 process
Jobs: 1 (f=1): [R(1)][90.9%][r=6560MiB/s][r=6559 IOPS][eta 00m:02s]
testfile: (groupid=0, jobs=1): err= 0: pid=2903196: Wed Jul 29 12:27:17 2026
  read: IOPS=6082, BW=6083MiB/s (6378MB/s)(85.6GiB/14406msec)
   bw (  MiB/s): min= 2924, max= 6675, per=99.83%, avg=6072.30, stdev=1205.59, samples=28
   iops        : min= 2924, max= 6675, avg=6072.21, stdev=1205.65, samples=28
  cpu          : usr=0.77%, sys=99.19%, ctx=85, majf=0, minf=39
     issued rwts: total=87626,0,0,0 short=0,0,0,0 dropped=0,0,0,0
   READ: bw=6083MiB/s (6378MB/s), 6083MiB/s-6083MiB/s (6378MB/s-6378MB/s), io=85.6GiB (91.9GB), run=14406-14406msec
SSD pool write
truenas_admin@truenas[/mnt/machines/testpool]$ sudo fio --ramp_time=5 --gtod_reduce=1 --numjobs=1 --bs=1M --size=100G --runtime=60s --readwrite=write --name=testfile
[sudo] password for truenas_admin:
fio-3.33
Starting 1 process
Jobs: 1 (f=1): [W(1)][100.0%][w=215MiB/s][w=215 IOPS][eta 00m:00s]
testfile: (groupid=0, jobs=1): err= 0: pid=2909168: Wed Jul 29 12:31:46 2026
  write: IOPS=184, BW=185MiB/s (194MB/s)(10.8GiB/60090msec); 0 zone resets
   bw (  KiB/s): min=133120, max=233939, per=100.00%, avg=189280.16, stdev=25145.60, samples=120
   iops        : min=  130, max=  228, avg=184.77, stdev=24.54, samples=120
  cpu          : usr=0.76%, sys=6.74%, ctx=11367, majf=0, minf=38
     issued rwts: total=0,11107,0,0 short=0,0,0,0 dropped=0,0,0,0
  WRITE: bw=185MiB/s (194MB/s), 185MiB/s-185MiB/s (194MB/s-194MB/s), io=10.8GiB (11.6GB), run=60090-60090msec
SSD pool read
truenas_admin@truenas[/mnt/machines/testpool]$ sudo fio --ramp_time=5 --gtod_reduce=1 --numjobs=1 --bs=1M --size=100G --runtime=60s --readwrite=read --name=testfile
fio-3.33
Starting 1 process
Jobs: 1 (f=1): [R(1)][90.5%][r=6543MiB/s][r=6543 IOPS][eta 00m:02s]
testfile: (groupid=0, jobs=1): err= 0: pid=2913140: Wed Jul 29 12:33:28 2026
  read: IOPS=6505, BW=6505MiB/s (6821MB/s)(85.3GiB/13430msec)
   bw (  MiB/s): min= 4889, max= 6632, per=100.00%, avg=6507.02, stdev=333.38, samples=26
   iops        : min= 4889, max= 6632, avg=6506.96, stdev=333.53, samples=26
  cpu          : usr=0.59%, sys=99.38%, ctx=34, majf=0, minf=37
     issued rwts: total=87367,0,0,0 short=0,0,0,0 dropped=0,0,0,0
   READ: bw=6505MiB/s (6821MB/s), 6505MiB/s-6505MiB/s (6821MB/s-6821MB/s), io=85.3GiB (91.6GB), run=13430-13430msec
How is your CPU usage when running the test?
Did you confirm the commands ran on the intended disks? This can be done in the charts under ‘Reporting’.
How is the SSD pool configured?
Why did you select those parameters for fio? Have you compared your fio result with actual performance such as copying a large file in shell?
Your reads are not the speed of SATA. 6-7 GB/s is more than 8 times faster than SATA (6Gb/s). So either youre testing ARC or the wrong drive(s). (see Common pitfall when benchmarking ZFS with fio | pV-tech )
Please don’t cite AI slop screenshots.
I don’t
I typed a query in google, it returned this result with the “fs.com” as a source. I went to the website and they sell HW and they have a FAQ that I read. Maybe they have written this using AI but I am not going 2 level down.
This was done a few days ago. I’ll rerun the test and check.
Forgot to specify in OP like I did for HDD pool. It’s a mirror.
I just followed some reference for which I did not keep the exact source, only a screenshot. IIRC, it’s from the legacy TN forum.
I’m with floz, running the same test will read/write directly to arc (ram) unless you disable arc before testing.
Si I read this ( I think I can understand the main idea) and ran this
fio --rw=read --bs=1m --direct=1 --ioengine=libaio --size=10G\
  --group_reporting --filename=/mnt//Bassin/machines/bucket --name=job1 --offset=0G\
  --name=job2 --offset=10G --name=job3 --offset=20G --name=job4 --offset=30G\
  --name=job5 --offset=40G --name=job6 --offset=50G --name=job7 --offset=60G\
  --name=job8 --offset=70G
got this
              capacity     operations     bandwidth
pool        alloc   free   read  write   read  write
Bassin      6.70T  7.85T     17      3  7.71M   236K
boot-pool   6.78G  52.2G      0      4  11.6K  73.3K
machines    43.7G   192G      0     14  85.6K   223K
Bassin      6.70T  7.85T     33      0  2.12M      0
boot-pool   6.78G  52.2G      0     38  12.8K   601K
machines    43.7G   192G      8  1.02K  32.8K   131M
Bassin      6.70T  7.85T     32      0  2.02M      0
boot-pool   6.78G  52.2G      0      0  95.9K      0
machines    43.7G   192G      8    762  32.8K  95.3M
Bassin      6.70T  7.85T     31      0  2.00M      0
boot-pool   6.78G  52.2G      0      0      0      0
machines    43.7G   192G      6    480  85.5K  60.1M
Bassin      6.70T  7.85T     29      0  1.87M      0
boot-pool   6.78G  52.2G      0      0  10.4K      0
machines    43.7G   192G      8    490  67.9K  61.3M
boot-pool   6.78G  52.2G      0      0  74.3K      0
machines    43.7G   192G      8    989  68.7K   124M
CPU usage stayed on the floor
Might be silly, but make sure it’s in the correct PCIe slot? (it can mistakenly happen in the wrong slot)
X10SRi-F
1 PCI-E 3.0 x16
1 PCI-E 3.0 x4 (in x8 slot),
2 PCI-E 3.0 x8 ← guess one of these
1 PCI-E 2.0 x4 (in x8 slot)
1 PCI-E 2.0 x2 (in x8 slot)
just covering every possible case -
I think you are reading from the ARC.
A reboot will clear it.
But dont expect miracles from your NVMEs when it comes to writes. Consumer NVMEs use a pseudo SLC cache. And once that is full, they have to write directly to the TLC NAND - and this can be terribly slow.
This is a really good point especially when using desktop boards for a NAS. There’s just an extremely limited amount of pci-e lanes for use from the cpu & high end board will have dedicated controller to allocate additional lanes for extra m.2 slots. Can’t just slap an addon card to a free pci-e slot and expect to get pci-e lanes required.
Yup, there can be a world of difference in write speed between what goes into the cache up front vs. the permanent flash in the back. No different than real CMR hard drives vs. shingled magnetic recording drives that use a CMR cache.
Once the “fast” cache is full, performance craters.
