quick question, once we go to electric eel and we can use docker compose on the metal, how will i do something like pass my nvidia gpu thru to my emby container? many times this requires installing extra packages, but apt install is disabled on truenas. how will i be able to successfully do gpu passthru in the future?
Same way you do with Jailmaker.
At least if you’re using compose.
The packages needed to do GPU passthrough will be available out of box on EE and will be supported via the UI and manual docker compose usage methods.
