Permissions issues after updating to 24.10
I updated scale 24.10 and now one of my datasets in unwritable through NFS.
I have the dataset on basic permissions, no ACLs, with the user as “media” and the group as “media”. The user and group both have read/write/exec permissions. I made sure to tick the “apply permissions recursively” box when reapplying them.
The mapall user and group in the NFS share are both set to media. However, when I attempt to mount the NFS share to an application (e.g. navidrome) I get permissions errors. When I mount the share manually on my desktop, I get the same result. Access for sub for any sub directories are just set as “none” as seen in the screenshot.
I would post the actual screenshot but apparently I’m “not allowed yet” so you’ll just have to use your imagination.
I also manually tried to chmod and chown the dataset in the truenas shell but no difference is made.
Try browsing a few other threads to get your forum trust level up. After that, images should be allowed. If that doesn’t work, take the tutorial by the forum bot
TrueNAS-Bot
Type this in a new reply and send to bring up the tutorial, if you haven’t done it already.
@TrueNAS-Bot start tutorial
