So I recovered several thousand pictures from an SSD drive with PhotoRec. Now I have the data in a RAIDZ2 configuration in TrueNas. I would like to separate the pictures, as many of them are duplicates or garbage (irrelevant app thumbnails)
I would like to use preferably AI for this task because of the huge number (~167000)
Can Immich do this ?
i think the basic immich ( without the AI addon ) will detected duplicates on its file hash. if the same pictures exists eg. Original vs. WhatsApp (sent/recieve ) AI might be required.
Yeah that’s right. I could also use czwawka in a mounted NFS partition to find duplicates. Can Immich categorize the pictures?
yes. you can search for context eg. “sun” or “cat” etc.
latest update seems to enable to search for similar pictures:
Release v1.141.1 · immich-app/immich
I am very pleased with immich, especially that it allows autom. uploading from mobile and has Android TV App for showcasing/slideshow etc
