Plex stuck on deploying after updating
Hello guys,
Issue with my plex on trunas TrueNAS-SCALE-24.10.2.2.
After many reboot and shutdown, I’m overwhelmed and I need your help.
My issue:
On plex 1.41.7.9823-59f304c16 Version 1.2.2 installed by trunas app center, the app stay blocked to deploy status, with they logs :
2025-06-05 20:12:29.553936+00:00[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
2025-06-05 20:12:30.153751+00:00[s6-init] ensuring user provided files have correct perms…exited 0.
2025-06-05 20:12:30.157163+00:00[fix-attrs.d] applying ownership & permissions fixes…
2025-06-05 20:12:30.161438+00:00[fix-attrs.d] done.
2025-06-05 20:12:30.163751+00:00[cont-init.d] executing container initialization scripts…
2025-06-05 20:12:30.167304+00:00[cont-init.d] 40-plex-first-run: executing…
2025-06-05 20:12:31.076324+00:00Plex Media Server first run setup complete
2025-06-05 20:12:31.077965+00:00[cont-init.d] 40-plex-first-run: exited 0.
2025-06-05 20:12:31.080478+00:00[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing…
2025-06-05 20:12:31.326927+00:00[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: exited 0.
2025-06-05 20:12:31.329312+00:00[cont-init.d] 50-plex-update: executing…
2025-06-05 20:12:35.680108+00:00Attempting to upgrade to: 1.41.8.9834-071366d65
2025-06-05 20:12:35.689959+00:00% Total % Received % Xferd Average Speed Time Time Time Current
2025-06-05 20:12:35.689995+00:00Dload Upload Total Spent Left Speed
2025-06-05 20:12:39.829619+00:000 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:01 --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:02 --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:03 --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:04 --:–:-- 0
2025-06-05 20:12:44.285539+00:000 0 0 0 0 0 0 0 --:–:-- 0:00:04 --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:06 --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:07 --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:08 --:–:-- 0
100 79.3M 100 79.3M 0 0 9449k 0 0:00:08 0:00:08 --:–:-- 21.9M
2025-06-05 20:12:48.550115+00:00Selecting previously unselected package plexmediaserver.
2025-06-05 20:12:48.596185+00:00(Reading database … 7274 files and directories currently installed.)
2025-06-05 20:12:48.596544+00:00Preparing to unpack /tmp/plexmediaserver.deb …
2025-06-05 20:12:48.609361+00:00PlexMediaServer install: Pre-installation Validation.
2025-06-05 20:12:48.618494+00:00PlexMediaServer install: Custom environment detected. Skipping preinstallation validation.
2025-06-05 20:12:48.622164+00:00Unpacking plexmediaserver (1.41.8.9834-071366d65) …
2025-06-05 20:12:54.231231+00:00Setting up plexmediaserver (1.41.8.9834-071366d65) …
2025-06-05 20:12:54.243347+00:00PlexMediaServer install: Custom environment detected. Skipping postinstallation tasks. Continuing.
2025-06-05 20:12:54.272902+00:00[cont-init.d] 50-plex-update: exited 0.
2025-06-05 20:12:54.273576+00:00[cont-init.d] done.
2025-06-05 20:12:54.274208+00:00[services.d] starting services
2025-06-05 20:12:54.279417+00:00Starting Plex Media Server.
2025-06-05 20:12:54.279659+00:00[services.d] done.
The problem first appeared this morning, but I haven’t done anything. I’m assuming it’s just a crash, but then the app refuses to restart. I’ve tried updating the app, but the problem persists.
If anyone will has an idea, i will get it.
Thanks you all !
Looking at your logs & comparing them to mine (also on Truenas 24.10.2.2, also on same version of Plex), I see no difference… except my Plex is working & yours is not. Whatever the issue is, I don’t think the log output is helpful. Any other details you can provide?
my logs if you want to compare
2025-06-03 16:02:31.058710+00:00Attempting to upgrade to: 1.41.8.9834-071366d65
2025-06-03 16:02:31.064203+00:00% Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
2025-06-03 16:02:31.064241+00:00Dload  Upload   Total   Spent    Left  Speed
2025-06-03 16:02:31.433667+00:000     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
2025-06-03 16:02:36.889205+00:008 79.3M    8 7278k    0     0  10.0M      0  0:00:07 --:--:--  0:00:07 10.0M
 32 79.3M   32 25.7M    0     0  14.8M      0  0:00:05  0:00:01  0:00:04 18.2M
 56 79.3M   56 44.6M    0     0  16.4M      0  0:00:04  0:00:02  0:00:02 18.7M
 66 79.3M   66 52.5M    0     0  14.1M      0  0:00:05  0:00:03  0:00:02 15.1M
 78 79.3M   78 62.5M    0     0  13.2M      0  0:00:05  0:00:04  0:00:01 13.8M
 96 79.3M   96 76.7M    0     0  13.4M      0  0:00:05  0:00:05 --:--:-- 13.9M
100 79.3M  100 79.3M    0     0  13.6M      0  0:00:05  0:00:05 --:--:-- 13.0M
2025-06-03 16:02:36.974841+00:00Selecting previously unselected package plexmediaserver.
2025-06-03 16:02:36.999798+00:00(Reading database ... 7274 files and directories currently installed.)
2025-06-03 16:02:36.999973+00:00Preparing to unpack /tmp/plexmediaserver.deb ...
2025-06-03 16:02:37.015203+00:00PlexMediaServer install: Pre-installation Validation.
2025-06-03 16:02:37.021811+00:00PlexMediaServer install: Custom environment detected.  Skipping preinstallation validation.
2025-06-03 16:02:37.025653+00:00Unpacking plexmediaserver (1.41.8.9834-071366d65) ...
2025-06-03 16:02:40.454700+00:00Setting up plexmediaserver (1.41.8.9834-071366d65) ...
2025-06-03 16:02:40.467365+00:00PlexMediaServer install: Custom environment detected.  Skipping postinstallation tasks. Continuing.
2025-06-03 16:02:40.505557+00:00[cont-init.d] 50-plex-update: exited 0.
2025-06-03 16:02:40.506175+00:00[cont-init.d] done.
2025-06-03 16:02:40.506848+00:00[services.d] starting services
2025-06-03 16:02:40.511425+00:00[services.d] done.
2025-06-03 16:02:40.511519+00:00Starting Plex Media Server.
Did you try to unset the app pool, refresh app catalogue, and re-set the app pool?
*only slight differences I see is that you went from having 0% of the update to 100% of the update in a single increment, while I downloaded it in parts… which doesn’t outright indicate a fault imo.
You can also try to rollback the update & try to install it again.
I have rollback to 1.1.1 and it’s work.
I will test next update if my issue appear again.
Thanks you for this tips, i didn’t think to rollback the app.
I had the same issue with my plex and same logs, I am however just running 25.04.1.
When I went to the plex URL (http://IP:32400/web) in my browser I (in the deployed but not working state) it showed an xml output indicating that it was migrating the plex database and I needed to wait.
I left it overnight and it has been up and running first thing when I looked this morning. (I went to sleep and didn’t sit up to monitor how long it took, sorry)
