That might have been a different issue or maybe similar but manifesting with a different and less severe outcome.
The real concern is not that the pools keep exporting, but that they cannot be imported again.
It gets more difficult to know the underlying issue, since one of the examples had skipped ahead and recovered their files using data recovery software. They have since formatted their disks with Windows, which makes it impossible to diagnose what happened.
Another was only able to get their pool imported by reverting to 23.10.x. Iām not sure how comfortable they feel trying again with an upgrade, which might result in the same or worse outcome.
The remaining two examples are inconclusive, and as of yet are still unable to import their pools.
It is indeed possible that the pattern is an upgrade to 24.10.x and not necessarily 25.04 (since the problem might have been triggered between the two upgrade steps). Maybe not even 24.10.x, but a specific minor version?
Itās also possible that it could equally be 24.10 or 25.04, and perhaps thereās a common trigger that only affects those two. (Maybe because of a change in partitioning? Something in OpenZFS?)
Does it warrant a new thread, so this one doesnāt get derailed?
I wonāt be able to troubleshoot, and weāre still waiting on the results of the other two users.
It does seem to be a pattern that happened recently, and they all involved unimportable pools immediately after an upgrade.
Itās not certain yet, but it could also be triggered based on when and how the pool was created.
I could ask the other two users to direct message @HoneyBadger to send this:
