Pool now offline following shutdown, shows one drive exported?
Y’all, I’m losing my mind here. Our power went off earlier and I manually shut down the server before the UPS ran out (for once lol). I brought the server back up later when I knew the power was stable, but now one of my pools is just… gone? And I’m running out of paths to go down here, so maybe someone may have an idea that I haven’t found googling yet.
Version: TrueNAS-SCALE-23.10.1.3
HBA: Intel RES2SV240 in IT mode
Drive bays: Three ISTAR BPN-DE350HD-BLACK Trayless 3X 5.25 to 5X 3.5 12Gb/s HDD Hot-swap Rack
PSU: EVGA Supernova 750 GT
Batuu is the pool missing, and from what I can tell, all of the drives are lighting up in their drive bays. Looking at Disks, this is all that show up–the four Batuu drives are missing. The one listed here, I think, is a hot swap that I had in the drive bay but not associated to a pool.
It’s also the one drive that shows up in the Storage dashboard in the 1 Unused Disk screen.
There are no pools that show up in Import.
Coruscant pool shows DEGRADED, as one drive is somehow… Unavailable? Running a scrub to see if that can fix things.
I did some zpool commands, and got these outputs:
root@truenas[~]# zpool import
   pool: Batuu
  state: UNAVAIL
status: One or more devices contains corrupted data.
 action: The pool cannot be imported due to damaged devices or data.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-5E
        Batuu                                     UNAVAIL  insufficient replicas
          raidz2-0                                UNAVAIL  insufficient replicas
            52f66304-c4f1-11eb-89ce-002590d4794f  UNAVAIL
            533f9615-c4f1-11eb-89ce-002590d4794f  ONLINE
            53596c07-c4f1-11eb-89ce-002590d4794f  UNAVAIL
            53c35903-c4f1-11eb-89ce-002590d4794f  UNAVAIL
root@truenas[~]# zpool status Batuu
cannot open 'Batuu': no such pool
  pool: Coruscant
 state: DEGRADED
status: One or more devices could not be used because the label is missing or
        invalid.  Sufficient replicas exist for the pool to continue
        functioning in a degraded state.
action: Replace the device using 'zpool replace'.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-4J
  scan: scrub in progress since Sun Sep 14 22:44:06 2025
        4.04T / 4.66T scanned at 1.47G/s, 1.36T / 4.66T issued at 509M/s
        0B repaired, 29.25% done, 01:53:16 to go
        NAME                                      STATE     READ WRITE CKSUM
        Coruscant                                 DEGRADED     0     0     0
          raidz2-0                                DEGRADED     0     0     0
            16cd6d61-c4f1-11eb-89ce-002590d4794f  ONLINE       0     0     0
            17550338-c4f1-11eb-89ce-002590d4794f  ONLINE       0     0     0
            15832442471779559229                  UNAVAIL      0     0     0  was /dev/disk/by-partuuid/1770abf5-c4f1-11eb-89ce-002590d4794f
            178d39ab-c4f1-11eb-89ce-002590d4794f  ONLINE       0     0     0
errors: No known data errors
  pool: Kuat
 state: ONLINE
  scan: scrub repaired 0B in 00:03:27 with 0 errors on Sun Aug 17 00:03:30 2025
        Kuat                                      ONLINE       0     0     0
          mirror-0                                ONLINE       0     0     0
            9364057d-7b18-4ff0-a0a4-979645e83d3b  ONLINE       0     0     0
            dee08782-1dea-4134-b51d-868a3c807f74  ONLINE       0     0     0
  pool: boot-pool
 state: ONLINE
status: One or more features are enabled on the pool despite not being
        requested by the 'compatibility' property.
action: Consider setting 'compatibility' to an appropriate value, or
        adding needed features to the relevant file in
        /etc/zfs/compatibility.d or /usr/share/zfs/compatibility.d.
  scan: scrub repaired 0B in 00:05:16 with 0 errors on Mon Sep  8 03:50:19 2025
            sdf2    ONLINE       0     0     0
            sde2    ONLINE       0     0     0
root@truenas[~]#
Other things I’ve done:
  • I’ve power cycled the server multiple times, including pulling the power from the PSU for a while.
  • Reseated SAS cables at HBA
  • Reseated power cables in drive
I haven’t reseated all data cables at the bays yet, nor have I tried pulling the drives out of the bays and running them all separately, mostly because getting the power cables to the drives may be pretty tricky with how they’re currently run.
I’m thoroughly exhausted at this point and my eyes are pretty useless right now, but I’ll be back at it tomorrow. Looking forward to see if anyone has any other ideas I can look into then. Thanks in advance.
… wouldn’t let me post with images embedded, so… cool.
You will have received an email about some training before being able to post pictures. I suggest you follow it.
As to the issue - I would personally remove all the drives (ZFS doesn’t care which slot drives are in) and then add them back in one at a time and see what happens.
You haven’t posted your full hardware. That isn’t an HBA - its a SAS expander. What are you feeding it from? Please post your FULL hardware
I actually haven’t received any such email that I can locate. I’ve checked my junk folder, searched all inboxes for both TrueNAS and Discourse, and haven’t found anything. I’ll dig through some resources later to see if I can find a way to resend that.
Here’s my full hardware list, I don’t think I left anything out.
TrueNAS version: TrueNAS-SCALE-23.10.1.3
Mobo: Supermicro X10SLM-F
CPU: E3-1265LV3
RAM: Hynix 32GB 4x8GB PC3-12800E “ECC UDIMM” 1600 DDR3
HBA: IBM M5110 = LSI 9207-8i
Expander: Intel RES2SV240 24-Ports 6G 6Gbps RAID Expander
Batuu pool drives: 4x HUS726060AL5210
Coruscant pool: 2x ST4000NEZ01, 2x WDC_WD4003FFBX-68MU3N0
Kuat pool (TrueCharts): Kingston 120GB A400 SATA 3 2.5" Internal SSD SA400S37/120G
Hot spare: 1x HGST HP HUS726060AL5214
Drive cages/backplanes: 3x ISTAR BPN-DE350HD-BLACK Trayless 3X 5.25 to 5X 3.5 12Gb/s HDD Hot-swap Rack
Boot drive: 2x GLOTRENDS M.2 PCIe NVMe 4.0/3.0 Adapter with Crucial P3 500GB NVMe M.2 SSD each
I just had to interact with a bot message, it seems.
