Pool offline after reboot, no datasets in pool after zpool import
OS Version:TrueNAS-SCALE-24.10.2.2
Rebooted server and pool was offline. Imported using zpool import and it brought the pool online but there is no data…
The error i get when browsing to datasets in gui.
[Errno 2] No such file or directory: '/mnt/.ix-apps/app_configs'
> root@truenas[~]# lsblk
> NAME    MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
> sda       8:0    0 232.9G  0 disk
> └─sda1    8:1    0 232.9G  0 part
> sdb       8:16   0 465.8G  0 disk
> └─sdb1    8:17   0 465.8G  0 part
> sdc       8:32   0 139.7G  0 disk
> ├─sdc1    8:33   0     1M  0 part
> ├─sdc2    8:34   0   512M  0 part
> └─sdc3    8:35   0 139.2G  0 part
> sdd       8:48   0 476.9G  0 disk
> └─sdd1    8:49   0 476.9G  0 part
> sde       8:64   1     0B  0 disk
> zd0     230:0    0    60G  0 disk
> ├─zd0p1 230:1    0   976M  0 part
> ├─zd0p2 230:2    0  57.1G  0 part
> └─zd0p3 230:3    0     2G  0 part
> zd16    230:16   0    30G  0 disk
> root@truenas[~]# zpool status
>   pool: Pool1
>  state: ONLINE
>   scan: scrub repaired 0B in 00:02:34 with 0 errors on Thu Aug 21 17:29:10 2025
> config:
>         NAME                                      STATE     READ WRITE CKSUM
>         Pool1                                     ONLINE       0     0     0
>           mirror-0                                ONLINE       0     0     0
>             fe86057e-bfe5-4bdd-8e58-c5f45a439d6f  ONLINE       0     0     0
>             e1f71194-989c-4f0f-9378-50817a760dda  ONLINE       0     0     0
>         cache
>           8bac091d-db3a-41b4-abf6-285c4a2d2baf    ONLINE       0     0     0
> errors: No known data errors
>   pool: boot-pool
>  state: ONLINE
>   scan: scrub repaired 0B in 00:02:12 with 0 errors on Mon Aug 18 03:47:13 2025
> config:
>         boot-pool   ONLINE       0     0     0
>           sdc3      ONLINE       0     0     0
root@truenas[~]# zfs get mountpoint
NAME                                                            PROPERTY    VALUE                                              SOURCE
Pool1                                                           mountpoint  /Pool1                                             default
Pool1/.system                                                   mountpoint  legacy                                             local
Pool1/.system/configs-ae32c386e13840b2bf9c0083275e7941          mountpoint  legacy                                             local
Pool1/.system/cores                                             mountpoint  legacy                                             local
Pool1/.system/netdata-ae32c386e13840b2bf9c0083275e7941          mountpoint  legacy                                             local
Pool1/.system/nfs                                               mountpoint  legacy                                             local
Pool1/.system/samba4                                            mountpoint  legacy                                             local
Pool1/.system/samba4@update--2024-12-17-17-27--SCALE-24.10.0.2  mountpoint  -                                                  -
Pool1/.system/samba4@update--2025-02-10-19-41--SCALE-24.10.1    mountpoint  -                                                  -
Pool1/.system/samba4@update--2025-06-26-01-07--SCALE-24.10.2    mountpoint  -                                                  -
Pool1/ActualBudget                                              mountpoint  -                                                  -
Pool1/N8N                                                       mountpoint  /Pool1/N8N                                         default
Pool1/SMBVM1-cmedha                                             mountpoint  -                                                  -
Pool1/ix-apps                                                   mountpoint  /.ix-apps                                          local
Pool1/ix-apps/app_configs                                       mountpoint  /.ix-apps/app_configs                              inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts                                        mountpoint  /.ix-apps/app_mounts                               inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/actual-budget                          mountpoint  /.ix-apps/app_mounts/actual-budget                 inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/actual-budget@1.2.20                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/actual-budget@1.3.5                    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/actual-budget@1.3.7                    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/actual-budget/data                     mountpoint  /.ix-apps/app_mounts/actual-budget/data            inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/actual-budget/data@1.2.20              mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/actual-budget/data@1.3.5               mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/actual-budget/data@1.3.7               mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant                         mountpoint  /.ix-apps/app_mounts/home-assistant                inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/home-assistant@1.4.41                  mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant@1.4.42                  mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant@1.4.43                  mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant@1.5.7                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant@1.5.11                  mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant/config                  mountpoint  /.ix-apps/app_mounts/home-assistant/config         inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/home-assistant/config@1.4.41           mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant/config@1.4.42           mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant/config@1.4.43           mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant/config@1.5.7            mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant/config@1.5.11           mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant/media                   mountpoint  /.ix-apps/app_mounts/home-assistant/media          inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/home-assistant/media@1.4.41            mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant/media@1.4.42            mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant/media@1.4.43            mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant/media@1.5.7             mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant/media@1.5.11            mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant/postgres_data           mountpoint  /.ix-apps/app_mounts/home-assistant/postgres_data  inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/home-assistant/postgres_data@1.4.41    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant/postgres_data@1.4.42    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant/postgres_data@1.4.43    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant/postgres_data@1.5.7     mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/home-assistant/postgres_data@1.5.11    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/overseerr                              mountpoint  /.ix-apps/app_mounts/overseerr                     inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/overseerr@1.1.2                        mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/overseerr@1.1.1                        mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/overseerr@1.1.4                        mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/overseerr@1.1.5                        mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/overseerr@1.1.6                        mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/overseerr@1.1.8                        mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/overseerr@1.1.9                        mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/overseerr@1.1.12                       mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/overseerr/config                       mountpoint  /.ix-apps/app_mounts/overseerr/config              inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/overseerr/config@1.1.2                 mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/overseerr/config@1.1.1                 mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/overseerr/config@1.1.4                 mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/overseerr/config@1.1.5                 mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/overseerr/config@1.1.6                 mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/overseerr/config@1.1.8                 mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/overseerr/config@1.1.9                 mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/overseerr/config@1.1.12                mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole                                 mountpoint  /.ix-apps/app_mounts/pihole                        inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/pihole@1.2.1                           mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole@1.2.7                           mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole@1.2.14                          mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole@1.2.19                          mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole@1.2.25                          mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole@1.3.6                           mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole/config                          mountpoint  /.ix-apps/app_mounts/pihole/config                 inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/pihole/config@1.2.1                    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole/config@1.2.7                    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole/config@1.2.14                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole/config@1.2.19                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole/config@1.2.25                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole/config@1.3.6                    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole/dnsmasq                         mountpoint  /.ix-apps/app_mounts/pihole/dnsmasq                inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/pihole/dnsmasq@1.2.1                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole/dnsmasq@1.2.7                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole/dnsmasq@1.2.14                  mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole/dnsmasq@1.2.19                  mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole/dnsmasq@1.2.25                  mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/pihole/dnsmasq@1.3.6                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex                                   mountpoint  /.ix-apps/app_mounts/plex                          inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/plex@1.1.15                            mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex@1.1.16                            mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex@1.1.18                            mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex@1.1.19                            mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex@1.1.22                            mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex@1.2.4                             mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex/config                            mountpoint  /.ix-apps/app_mounts/plex/config                   inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/plex/config@1.1.15                     mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex/config@1.1.16                     mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex/config@1.1.18                     mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex/config@1.1.19                     mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex/config@1.1.22                     mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex/config@1.2.4                      mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex/data                              mountpoint  /.ix-apps/app_mounts/plex/data                     inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/plex/data@1.1.15                       mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex/data@1.1.16                       mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex/data@1.1.18                       mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex/data@1.1.19                       mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex/data@1.1.22                       mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/plex/data@1.2.4                        mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr                                 mountpoint  /.ix-apps/app_mounts/radarr                        inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/radarr@1.2.8                           mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr@1.2.9                           mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr@1.2.3                           mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr@1.2.12                          mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr@1.2.14                          mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr@1.2.17                          mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr@1.2.24                          mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr@1.2.26                          mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr@1.3.6                           mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr@1.3.7                           mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr/config                          mountpoint  /.ix-apps/app_mounts/radarr/config                 inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/radarr/config@1.2.8                    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr/config@1.2.9                    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr/config@1.2.3                    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr/config@1.2.12                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr/config@1.2.14                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr/config@1.2.17                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr/config@1.2.24                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr/config@1.2.26                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr/config@1.3.6                    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/radarr/config@1.3.7                    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sabnzbd                                mountpoint  /.ix-apps/app_mounts/sabnzbd                       inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/sabnzbd@1.1.2                          mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sabnzbd@1.1.7                          mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sabnzbd@1.1.9                          mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sabnzbd@1.1.10                         mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sabnzbd@1.1.11                         mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sabnzbd@1.1.15                         mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sabnzbd@1.2.3                          mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sabnzbd/config                         mountpoint  /.ix-apps/app_mounts/sabnzbd/config                inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/sabnzbd/config@1.1.2                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sabnzbd/config@1.1.7                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sabnzbd/config@1.1.9                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sabnzbd/config@1.1.10                  mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sabnzbd/config@1.1.11                  mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sabnzbd/config@1.1.15                  mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sabnzbd/config@1.2.3                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr                                 mountpoint  /.ix-apps/app_mounts/sonarr                        inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/sonarr@1.1.3                           mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr@1.1.4                           mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr@1.1.7                           mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr@1.1.8                           mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr@1.1.11                          mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr@1.1.12                          mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr@1.1.13                          mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr@1.1.15                          mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr@1.1.17                          mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr/config                          mountpoint  /.ix-apps/app_mounts/sonarr/config                 inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/sonarr/config@1.1.3                    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr/config@1.1.4                    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr/config@1.1.7                    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr/config@1.1.8                    mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr/config@1.1.11                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr/config@1.1.12                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr/config@1.1.13                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr/config@1.1.15                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/sonarr/config@1.1.17                   mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale                              mountpoint  /.ix-apps/app_mounts/tailscale                     inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/tailscale@1.2.2                        mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale@1.2.5                        mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale@1.2.7                        mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale@1.2.8                        mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale@1.2.1                        mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale@1.2.12                       mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale@1.2.13                       mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale@1.2.14                       mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale@1.2.17                       mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale@1.3.3                        mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale/state                        mountpoint  /.ix-apps/app_mounts/tailscale/state               inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/tailscale/state@1.2.2                  mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale/state@1.2.5                  mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale/state@1.2.7                  mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale/state@1.2.8                  mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale/state@1.2.1                  mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale/state@1.2.12                 mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale/state@1.2.13                 mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale/state@1.2.14                 mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale/state@1.2.17                 mountpoint  -                                                  -
Pool1/ix-apps/app_mounts/tailscale/state@1.3.3                  mountpoint  -                                                  -
Pool1/ix-apps/docker                                            mountpoint  /.ix-apps/docker                                   inherited from Pool1/ix-apps
Pool1/ix-apps/truenas_catalog                                   mountpoint  /.ix-apps/truenas_catalog                          inherited from Pool1/ix-apps
boot-pool                                                       mountpoint  none                                               local
boot-pool/ROOT                                                  mountpoint  none                                               inherited from boot-pool
boot-pool/ROOT/24.10.0.2                                        mountpoint  legacy                                             local
boot-pool/ROOT/24.10.0.2@pristine                               mountpoint  -                                                  -
boot-pool/ROOT/24.10.0.2/audit                                  mountpoint  /audit                                             local
boot-pool/ROOT/24.10.0.2/conf                                   mountpoint  /conf                                              local
boot-pool/ROOT/24.10.0.2/conf@pristine                          mountpoint  -                                                  -
boot-pool/ROOT/24.10.0.2/data                                   mountpoint  /data                                              local
boot-pool/ROOT/24.10.0.2/etc                                    mountpoint  /etc                                               local
boot-pool/ROOT/24.10.0.2/etc@pristine                           mountpoint  -                                                  -
boot-pool/ROOT/24.10.0.2/home                                   mountpoint  /home                                              local
boot-pool/ROOT/24.10.0.2/mnt                                    mountpoint  /mnt                                               local
boot-pool/ROOT/24.10.0.2/opt                                    mountpoint  /opt                                               local
boot-pool/ROOT/24.10.0.2/opt@pristine                           mountpoint  -                                                  -
boot-pool/ROOT/24.10.0.2/root                                   mountpoint  /root                                              local
boot-pool/ROOT/24.10.0.2/usr                                    mountpoint  /usr                                               local
boot-pool/ROOT/24.10.0.2/usr@pristine                           mountpoint  -                                                  -
boot-pool/ROOT/24.10.0.2/var                                    mountpoint  /var                                               local
boot-pool/ROOT/24.10.0.2/var@pristine                           mountpoint  -                                                  -
boot-pool/ROOT/24.10.0.2/var/ca-certificates                    mountpoint  /var/local/ca-certificates                         local
boot-pool/ROOT/24.10.0.2/var/log                                mountpoint  /var/log                                           local
boot-pool/ROOT/24.10.0.2/var/log/journal                        mountpoint  /var/log/journal                                   local
boot-pool/ROOT/24.10.1                                          mountpoint  legacy                                             local
boot-pool/ROOT/24.10.1@pristine                                 mountpoint  -                                                  -
boot-pool/ROOT/24.10.1/audit                                    mountpoint  /audit                                             local
boot-pool/ROOT/24.10.1/conf                                     mountpoint  /conf                                              local
boot-pool/ROOT/24.10.1/conf@pristine                            mountpoint  -                                                  -
boot-pool/ROOT/24.10.1/data                                     mountpoint  /data                                              local
boot-pool/ROOT/24.10.1/etc                                      mountpoint  /etc                                               local
boot-pool/ROOT/24.10.1/etc@pristine                             mountpoint  -                                                  -
boot-pool/ROOT/24.10.1/home                                     mountpoint  /home                                              local
boot-pool/ROOT/24.10.1/mnt                                      mountpoint  /mnt                                               local
boot-pool/ROOT/24.10.1/opt                                      mountpoint  /opt                                               local
boot-pool/ROOT/24.10.1/opt@pristine                             mountpoint  -                                                  -
boot-pool/ROOT/24.10.1/root                                     mountpoint  /root                                              local
boot-pool/ROOT/24.10.1/usr                                      mountpoint  /usr                                               local
boot-pool/ROOT/24.10.1/usr@pristine                             mountpoint  -                                                  -
boot-pool/ROOT/24.10.1/var                                      mountpoint  /var                                               local
boot-pool/ROOT/24.10.1/var@pristine                             mountpoint  -                                                  -
boot-pool/ROOT/24.10.1/var/ca-certificates                      mountpoint  /var/local/ca-certificates                         local
boot-pool/ROOT/24.10.1/var/log                                  mountpoint  /var/log                                           local
boot-pool/ROOT/24.10.1/var/log/journal                          mountpoint  /var/log/journal                                   local
boot-pool/ROOT/24.10.2                                          mountpoint  legacy                                             local
boot-pool/ROOT/24.10.2@pristine                                 mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2                                        mountpoint  legacy                                             local
boot-pool/ROOT/24.10.2.2@pristine                               mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/audit                                  mountpoint  /audit                                             local
boot-pool/ROOT/24.10.2.2/audit@install-2024-12-17-17-26-09      mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/audit@install-2025-02-10-19-39-48      mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/audit@install-2025-06-26-01-05-06      mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/conf                                   mountpoint  /conf                                              local
boot-pool/ROOT/24.10.2.2/conf@pristine                          mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/data                                   mountpoint  /data                                              local
boot-pool/ROOT/24.10.2.2/data@install-2024-12-17-17-26-09       mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/data@install-2025-02-10-19-39-48       mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/data@install-2025-06-26-01-05-07       mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/etc                                    mountpoint  /etc                                               local
boot-pool/ROOT/24.10.2.2/etc@pristine                           mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/home                                   mountpoint  /home                                              local
boot-pool/ROOT/24.10.2.2/home@install-2024-12-17-17-26-10       mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/home@install-2025-02-10-19-39-49       mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/home@install-2025-06-26-01-05-08       mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/mnt                                    mountpoint  /mnt                                               local
boot-pool/ROOT/24.10.2.2/opt                                    mountpoint  /opt                                               local
boot-pool/ROOT/24.10.2.2/opt@pristine                           mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/root                                   mountpoint  /root                                              local
boot-pool/ROOT/24.10.2.2/root@install-2024-12-17-17-26-11       mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/root@install-2025-02-10-19-39-50       mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/root@install-2025-06-26-01-05-09       mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/usr                                    mountpoint  /usr                                               local
boot-pool/ROOT/24.10.2.2/usr@pristine                           mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/var                                    mountpoint  /var                                               local
boot-pool/ROOT/24.10.2.2/var@pristine                           mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/var/ca-certificates                    mountpoint  /var/local/ca-certificates                         local
boot-pool/ROOT/24.10.2.2/var/log                                mountpoint  /var/log                                           local
boot-pool/ROOT/24.10.2.2/var/log@install-2024-12-17-17-26-12    mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/var/log@install-2025-02-10-19-39-51    mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/var/log@install-2025-06-26-01-05-10    mountpoint  -                                                  -
boot-pool/ROOT/24.10.2.2/var/log/journal                        mountpoint  /var/log/journal                                   local
boot-pool/ROOT/24.10.2/audit                                    mountpoint  /audit                                             local
boot-pool/ROOT/24.10.2/conf                                     mountpoint  /conf                                              local
boot-pool/ROOT/24.10.2/conf@pristine                            mountpoint  -                                                  -
boot-pool/ROOT/24.10.2/data                                     mountpoint  /data                                              local
boot-pool/ROOT/24.10.2/etc                                      mountpoint  /etc                                               local
boot-pool/ROOT/24.10.2/etc@pristine                             mountpoint  -                                                  -
boot-pool/ROOT/24.10.2/home                                     mountpoint  /home                                              local
boot-pool/ROOT/24.10.2/mnt                                      mountpoint  /mnt                                               local
boot-pool/ROOT/24.10.2/opt                                      mountpoint  /opt                                               local
boot-pool/ROOT/24.10.2/opt@pristine                             mountpoint  -                                                  -
boot-pool/ROOT/24.10.2/root                                     mountpoint  /root                                              local
boot-pool/ROOT/24.10.2/usr                                      mountpoint  /usr                                               local
boot-pool/ROOT/24.10.2/usr@pristine                             mountpoint  -                                                  -
boot-pool/ROOT/24.10.2/var                                      mountpoint  /var                                               local
boot-pool/ROOT/24.10.2/var@pristine                             mountpoint  -                                                  -
boot-pool/ROOT/24.10.2/var/ca-certificates                      mountpoint  /var/local/ca-certificates                         local
boot-pool/ROOT/24.10.2/var/log                                  mountpoint  /var/log                                           local
boot-pool/ROOT/24.10.2/var/log/journal                          mountpoint  /var/log/journal                                   local
boot-pool/grub                                                  mountpoint  legacy                                             local
It looks to me that it can’t find it because it changed the mount point from
to
Could you verify this with ls -lh /.ix-apps/app_configs?
a little more info
recent zpool history
2025-08-03.13:43:49 zpool import 7643010355667187867 -R /mnt -m -N -f -o cachefile=/data/zfs/zpool.cache
2025-08-03.13:48:32 py-libzfs: zfs snapshot -r Pool1/ix-apps/app_mounts/actual-budget@1.3.7
2025-08-03.13:51:03 py-libzfs: zfs snapshot -r Pool1/ix-apps/app_mounts/home-assistant@1.5.11
2025-08-03.13:54:04 py-libzfs: zfs snapshot -r Pool1/ix-apps/app_mounts/pihole@1.3.6
2025-08-03.13:54:17 py-libzfs: zfs snapshot -r Pool1/ix-apps/app_mounts/radarr@1.3.7
2025-08-03.13:54:32 py-libzfs: zfs snapshot -r Pool1/ix-apps/app_mounts/sabnzbd@1.2.3
2025-08-03.13:54:43 py-libzfs: zfs snapshot -r Pool1/ix-apps/app_mounts/tailscale@1.3.3
2025-08-03.13:58:18 zfs destroy -R Pool1/ix-apps/app_mounts/wyze-bridge
2025-08-04.00:00:04 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250804070004
2025-08-04.00:00:08 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250804070004
2025-08-05.00:00:04 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250805070004
2025-08-05.00:00:05 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250805070004
2025-08-06.00:00:05 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250806070005
2025-08-06.00:00:06 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250806070005
2025-08-07.00:00:04 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250807070004
2025-08-07.00:00:05 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250807070004
2025-08-08.00:00:04 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250808070004
2025-08-08.00:00:05 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250808070004
2025-08-09.00:00:04 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250809070004
2025-08-09.00:00:04 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250809070004
2025-08-10.00:00:04 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250810070004
2025-08-10.00:00:05 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250810070004
2025-08-11.00:00:05 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250811070005
2025-08-11.00:00:06 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250811070005
2025-08-12.00:00:04 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250812070004
2025-08-12.00:00:05 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250812070004
2025-08-13.00:00:04 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250813070004
2025-08-13.00:00:05 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250813070004
2025-08-14.00:00:04 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250814070004
2025-08-14.00:00:05 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250814070004
2025-08-15.00:00:04 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250815070004
2025-08-15.00:00:04 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250815070004
2025-08-16.00:00:04 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250816070004
2025-08-16.00:00:05 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250816070004
2025-08-17.00:00:07 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250817070004
2025-08-17.00:00:15 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250817070004
2025-08-18.00:00:04 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250818070004
2025-08-18.00:00:05 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250818070004
2025-08-19.00:00:03 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250819070003
2025-08-19.00:00:05 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250819070003
2025-08-20.00:00:04 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250820070003
2025-08-20.00:00:05 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250820070003
2025-08-21.00:00:04 py-libzfs: zfs snapshot  Pool1@cloud_sync-1-20250821070004
2025-08-21.00:00:05 py-libzfs: zfs destroy Pool1@cloud_sync-1-20250821070004
2025-08-21.16:52:39 zpool import Pool1
2025-08-21.17:26:37 py-libzfs: zpool scrub Pool1
root@truenas[~]# zfs list
NAME                                                     USED  AVAIL  REFER  MOUNTPOINT
Pool1                                                    131G   318G  4.06G  /Pool1
Pool1/.system                                           1.98G   318G  1.47G  legacy
Pool1/.system/configs-ae32c386e13840b2bf9c0083275e7941  18.6M   318G  18.6M  legacy
Pool1/.system/cores                                      120K  1024M   120K  legacy
Pool1/.system/netdata-ae32c386e13840b2bf9c0083275e7941   504M   318G   504M  legacy
Pool1/.system/nfs                                        104K   318G   104K  legacy
Pool1/.system/samba4                                     624K   318G   252K  legacy
Pool1/ActualBudget                                      30.5G   349G    56K  -
Pool1/N8N                                               46.8M   318G  46.8M  /Pool1/N8N
Pool1/SMBVM1-cmedha                                     60.9G   369G  10.5G  -
Pool1/ix-apps                                           33.9G   318G   136K  /.ix-apps
Pool1/ix-apps/app_configs                               29.3M   318G  29.3M  /.ix-apps/app_configs
Pool1/ix-apps/app_mounts                                14.6G   318G   144K  /.ix-apps/app_mounts
Pool1/ix-apps/app_mounts/actual-budget                   552K   318G    96K  /.ix-apps/app_mounts/actual-budget
Pool1/ix-apps/app_mounts/actual-budget/data              456K   318G   440K  /.ix-apps/app_mounts/actual-budget/data
Pool1/ix-apps/app_mounts/home-assistant                  120M   318G   112K  /.ix-apps/app_mounts/home-assistant
Pool1/ix-apps/app_mounts/home-assistant/config          1.70M   318G   384K  /.ix-apps/app_mounts/home-assistant/config
Pool1/ix-apps/app_mounts/home-assistant/media             96K   318G    96K  /.ix-apps/app_mounts/home-assistant/media
Pool1/ix-apps/app_mounts/home-assistant/postgres_data    118M   318G  26.8M  /.ix-apps/app_mounts/home-assistant/postgres_data
Pool1/ix-apps/app_mounts/overseerr                      12.6M   318G    96K  /.ix-apps/app_mounts/overseerr
Pool1/ix-apps/app_mounts/overseerr/config               12.5M   318G  1.87M  /.ix-apps/app_mounts/overseerr/config
Pool1/ix-apps/app_mounts/pihole                          322M   318G   104K  /.ix-apps/app_mounts/pihole
Pool1/ix-apps/app_mounts/pihole/config                   322M   318G  88.8M  /.ix-apps/app_mounts/pihole/config
Pool1/ix-apps/app_mounts/pihole/dnsmasq                  184K   318G    96K  /.ix-apps/app_mounts/pihole/dnsmasq
Pool1/ix-apps/app_mounts/plex                           10.2G   318G   104K  /.ix-apps/app_mounts/plex
Pool1/ix-apps/app_mounts/plex/config                    10.2G   318G  4.58G  /.ix-apps/app_mounts/plex/config
Pool1/ix-apps/app_mounts/plex/data                        96K   318G    96K  /.ix-apps/app_mounts/plex/data
Pool1/ix-apps/app_mounts/radarr                         3.63G   318G    96K  /.ix-apps/app_mounts/radarr
Pool1/ix-apps/app_mounts/radarr/config                  3.63G   318G  1.34G  /.ix-apps/app_mounts/radarr/config
Pool1/ix-apps/app_mounts/sabnzbd                        3.95M   318G    96K  /.ix-apps/app_mounts/sabnzbd
Pool1/ix-apps/app_mounts/sabnzbd/config                 3.86M   318G   952K  /.ix-apps/app_mounts/sabnzbd/config
Pool1/ix-apps/app_mounts/sonarr                          330M   318G    96K  /.ix-apps/app_mounts/sonarr
Pool1/ix-apps/app_mounts/sonarr/config                   329M   318G  86.6M  /.ix-apps/app_mounts/sonarr/config
Pool1/ix-apps/app_mounts/tailscale                      1.07M   318G    96K  /.ix-apps/app_mounts/tailscale
Pool1/ix-apps/app_mounts/tailscale/state                1004K   318G   148K  /.ix-apps/app_mounts/tailscale/state
Pool1/ix-apps/docker                                    18.9G   318G  18.9G  /.ix-apps/docker
Pool1/ix-apps/truenas_catalog                            340M   318G   340M  /.ix-apps/truenas_catalog
boot-pool                                               10.4G   124G    96K  none
boot-pool/ROOT                                          10.3G   124G    96K  none
boot-pool/ROOT/24.10.0.2                                2.30G   124G   168M  legacy
boot-pool/ROOT/24.10.0.2/audit                            88K   124G   420K  /audit
boot-pool/ROOT/24.10.0.2/conf                           6.83M   124G  6.83M  /conf
boot-pool/ROOT/24.10.0.2/data                            104K   124G   280K  /data
boot-pool/ROOT/24.10.0.2/etc                            7.47M   124G  6.40M  /etc
boot-pool/ROOT/24.10.0.2/home                              0B   124G   120K  /home
boot-pool/ROOT/24.10.0.2/mnt                             104K   124G   104K  /mnt
boot-pool/ROOT/24.10.0.2/opt                              96K   124G    96K  /opt
boot-pool/ROOT/24.10.0.2/root                              8K   124G   140K  /root
boot-pool/ROOT/24.10.0.2/usr                            2.05G   124G  2.05G  /usr
boot-pool/ROOT/24.10.0.2/var                            77.3M   124G  32.6M  /var
boot-pool/ROOT/24.10.0.2/var/ca-certificates              96K   124G    96K  /var/local/ca-certificates
boot-pool/ROOT/24.10.0.2/var/log                        43.8M   124G  19.7M  /var/log
boot-pool/ROOT/24.10.0.2/var/log/journal                43.6M   124G  43.6M  /var/log/journal
boot-pool/ROOT/24.10.1                                  2.65G   124G   165M  legacy
boot-pool/ROOT/24.10.1/audit                              88K   124G   632K  /audit
boot-pool/ROOT/24.10.1/conf                             6.82M   124G  6.82M  /conf
boot-pool/ROOT/24.10.1/data                              104K   124G   300K  /data
boot-pool/ROOT/24.10.1/etc                              7.51M   124G  6.44M  /etc
boot-pool/ROOT/24.10.1/home                                0B   124G   120K  /home
boot-pool/ROOT/24.10.1/mnt                                96K   124G    96K  /mnt
boot-pool/ROOT/24.10.1/opt                                96K   124G    96K  /opt
boot-pool/ROOT/24.10.1/root                                8K   124G   196K  /root
boot-pool/ROOT/24.10.1/usr                              2.39G   124G  2.39G  /usr
boot-pool/ROOT/24.10.1/var                              84.5M   124G  33.0M  /var
boot-pool/ROOT/24.10.1/var/ca-certificates                96K   124G    96K  /var/local/ca-certificates
boot-pool/ROOT/24.10.1/var/log                          50.2M   124G  13.1M  /var/log
boot-pool/ROOT/24.10.1/var/log/journal                  49.9M   124G  49.9M  /var/log/journal
boot-pool/ROOT/24.10.2                                  2.66G   124G   165M  legacy
boot-pool/ROOT/24.10.2.2                                2.72G   124G   166M  legacy
boot-pool/ROOT/24.10.2.2/audit                          1.39M   124G   680K  /audit
boot-pool/ROOT/24.10.2.2/conf                           6.82M   124G  6.82M  /conf
boot-pool/ROOT/24.10.2.2/data                           1.05M   124G   292K  /data
boot-pool/ROOT/24.10.2.2/etc                            7.55M   124G  6.51M  /etc
boot-pool/ROOT/24.10.2.2/home                            356K   124G   120K  /home
boot-pool/ROOT/24.10.2.2/mnt                             180K   124G   180K  /mnt
boot-pool/ROOT/24.10.2.2/opt                              96K   124G    96K  /opt
boot-pool/ROOT/24.10.2.2/root                            496K   124G   196K  /root
boot-pool/ROOT/24.10.2.2/usr                            2.40G   124G  2.40G  /usr
boot-pool/ROOT/24.10.2.2/var                             143M   124G  33.1M  /var
boot-pool/ROOT/24.10.2.2/var/ca-certificates              96K   124G    96K  /var/local/ca-certificates
boot-pool/ROOT/24.10.2.2/var/log                         109M   124G  16.1M  /var/log
boot-pool/ROOT/24.10.2.2/var/log/journal                50.2M   124G  50.2M  /var/log/journal
boot-pool/ROOT/24.10.2/audit                              96K   124G   648K  /audit
boot-pool/ROOT/24.10.2/conf                             6.82M   124G  6.82M  /conf
boot-pool/ROOT/24.10.2/data                               96K   124G   288K  /data
boot-pool/ROOT/24.10.2/etc                              7.57M   124G  6.51M  /etc
boot-pool/ROOT/24.10.2/home                                0B   124G   128K  /home
boot-pool/ROOT/24.10.2/mnt                               104K   124G   104K  /mnt
boot-pool/ROOT/24.10.2/opt                                96K   124G    96K  /opt
boot-pool/ROOT/24.10.2/root                                8K   124G   196K  /root
boot-pool/ROOT/24.10.2/usr                              2.40G   124G  2.40G  /usr
boot-pool/ROOT/24.10.2/var                              85.5M   124G  33.8M  /var
boot-pool/ROOT/24.10.2/var/ca-certificates                96K   124G    96K  /var/local/ca-certificates
boot-pool/ROOT/24.10.2/var/log                          50.6M   124G  16.4M  /var/log
boot-pool/ROOT/24.10.2/var/log/journal                  50.3M   124G  50.3M  /var/log/journal
boot-pool/grub                                          8.19M   124G  8.19M  legacy
root@truenas[~]#
root@truenas[~]# ls -lh /.ix-apps/app_configs
ls: cannot access '/.ix-apps/app_configs': No such file or directory
Well, I’m stumped.
Try running zfs mount
As a last resort, you could try find / -iname "*ix-apps" and see what it will find, but I will leave that for later after I see the output of zfs mount.
Do note that this find command can end up taking a long time because it will traverse your entire file system. If you don’t want to wait and want to cancel it early, hit CTRL-C.
root@truenas[/data/zfs]# zfs mount
boot-pool/ROOT/24.10.2.2        /
boot-pool/ROOT/24.10.2.2/audit  /audit
boot-pool/ROOT/24.10.2.2/conf   /conf
boot-pool/ROOT/24.10.2.2/data   /data
boot-pool/ROOT/24.10.2.2/etc    /etc
boot-pool/ROOT/24.10.2.2/home   /home
boot-pool/ROOT/24.10.2.2/mnt    /mnt
boot-pool/ROOT/24.10.2.2/opt    /opt
boot-pool/ROOT/24.10.2.2/root   /root
boot-pool/ROOT/24.10.2.2/usr    /usr
boot-pool/ROOT/24.10.2.2/var    /var
boot-pool/ROOT/24.10.2.2/var/ca-certificates  /var/local/ca-certificates
boot-pool/ROOT/24.10.2.2/var/log  /var/log
boot-pool/ROOT/24.10.2.2/var/log/journal  /var/log/journal
boot-pool/grub                  /boot/grub
Pool1/.system                   /var/db/system
Pool1/.system/cores             /var/db/system/cores
Pool1/.system/nfs               /var/db/system/nfs
Pool1/.system/samba4            /var/db/system/samba4
Pool1/.system/configs-ae32c386e13840b2bf9c0083275e7941  /var/db/system/configs-ae32c386e13840b2bf9c0083275e7941
Pool1/.system/netdata-ae32c386e13840b2bf9c0083275e7941  /var/db/system/netdata
Pool1/.system/cores             /var/lib/systemd/coredump
root@truenas[/]# find / -iname "*ix-apps"
/run/middleware/ix-apps
/mnt/.ix-apps
root@truenas[/]#
log output from middlewared.log
[2025/08/21 17:03:42] (ERROR) PoolService.import_on_boot_impl():312 - Failed to import 'Pool1' with guid: '7643010355667187867' with error: "cannot import '7643010355667187867': a pool with that name already exists\nuse the form 'zpool import <pool | id> <newpool>' to give it a new name\n"
[2025/08/21 17:03:42] (DEBUG) PoolService.import_on_boot():499 - Calling pool.post_import
[2025/08/21 17:03:55] (DEBUG) PoolService.import_on_boot():501 - Finished calling pool.post_import
[2025/08/21 19:17:52] (DEBUG) PoolService.import_on_boot():464 - Creating '/data/zfs' (if it doesnt already exist)
[2025/08/21 19:17:52] (DEBUG) PoolService.import_on_boot():471 - Creating '/data/zfs/zpool.cache' (if it doesnt already exist)
[2025/08/21 19:17:52] (DEBUG) PoolService.import_on_boot_impl():309 - Importing 'Pool1' with guid: '7643010355667187867'
[2025/08/21 19:17:52] (ERROR) PoolService.import_on_boot_impl():312 - Failed to import 'Pool1' with guid: '7643010355667187867' with error: "cannot import '7643010355667187867': a pool with that name already exists\nuse the form 'zpool import <pool | id> <newpool>' to give it a new name\n"
[2025/08/21 19:17:52] (DEBUG) PoolService.import_on_boot():499 - Calling pool.post_import
[2025/08/21 19:18:05] (DEBUG) PoolService.import_on_boot():501 - Finished calling pool.post_import
[2025/08/21 19:25:36] (DEBUG) PoolService.import_on_boot():464 - Creating '/data/zfs' (if it doesnt already exist)
[2025/08/21 19:25:36] (DEBUG) PoolService.import_on_boot():471 - Creating '/data/zfs/zpool.cache' (if it doesnt already exist)
[2025/08/21 19:25:36] (DEBUG) PoolService.import_on_boot_impl():309 - Importing 'Pool1' with guid: '7643010355667187867'
[2025/08/21 19:25:36] (ERROR) PoolService.import_on_boot_impl():312 - Failed to import 'Pool1' with guid: '7643010355667187867' with error: "cannot import '7643010355667187867': a pool with that name already exists\nuse the form 'zpool import <pool | id> <newpool>' to give it a new name\n"
[2025/08/21 19:25:36] (DEBUG) PoolService.import_on_boot():499 - Calling pool.post_import
[2025/08/21 19:25:49] (DEBUG) PoolService.import_on_boot():501 - Finished calling pool.post_import
Ah this makes sense now. You have to run
zfs mount Pool1/ix-apps
zfs mount Pool1/ix-apps/app_configs
etc....
do I have to export/disconnect the current ‘Pool1’
root@truenas[/var/log]# zfs mount Pool1/ix-apps
cannot mount '/.ix-apps': failed to create mountpoint: Read-only file system
root@truenas[/var/log]# zfs get -r readonly Pool1/ix-apps
Pool1/ix-apps                                                 readonly  off     default
Pool1/ix-apps/app_configs                                     readonly  off     default
Pool1/ix-apps/app_mounts                                      readonly  off     default
Pool1/ix-apps/app_mounts/actual-budget                        readonly  off     default
Pool1/ix-apps/app_mounts/actual-budget@1.2.20                 readonly  -       -
Pool1/ix-apps/app_mounts/actual-budget@1.3.5                  readonly  -       -
Pool1/ix-apps/app_mounts/actual-budget@1.3.7                  readonly  -       -
Pool1/ix-apps/app_mounts/actual-budget/data                   readonly  off     default
Pool1/ix-apps/app_mounts/actual-budget/data@1.2.20            readonly  -       -
Pool1/ix-apps/app_mounts/actual-budget/data@1.3.5             readonly  -       -
Pool1/ix-apps/app_mounts/actual-budget/data@1.3.7             readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant                       readonly  off     default
Pool1/ix-apps/app_mounts/home-assistant@1.4.41                readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant@1.4.42                readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant@1.4.43                readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant@1.5.7                 readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant@1.5.11                readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant/config                readonly  off     default
Pool1/ix-apps/app_mounts/home-assistant/config@1.4.41         readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant/config@1.4.42         readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant/config@1.4.43         readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant/config@1.5.7          readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant/config@1.5.11         readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant/media                 readonly  off     default
Pool1/ix-apps/app_mounts/home-assistant/media@1.4.41          readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant/media@1.4.42          readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant/media@1.4.43          readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant/media@1.5.7           readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant/media@1.5.11          readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant/postgres_data         readonly  off     default
Pool1/ix-apps/app_mounts/home-assistant/postgres_data@1.4.41  readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant/postgres_data@1.4.42  readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant/postgres_data@1.4.43  readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant/postgres_data@1.5.7   readonly  -       -
Pool1/ix-apps/app_mounts/home-assistant/postgres_data@1.5.11  readonly  -       -
Pool1/ix-apps/app_mounts/overseerr                            readonly  off     default
Pool1/ix-apps/app_mounts/overseerr@1.1.2                      readonly  -       -
Pool1/ix-apps/app_mounts/overseerr@1.1.1                      readonly  -       -
Pool1/ix-apps/app_mounts/overseerr@1.1.4                      readonly  -       -
Pool1/ix-apps/app_mounts/overseerr@1.1.5                      readonly  -       -
Pool1/ix-apps/app_mounts/overseerr@1.1.6                      readonly  -       -
Pool1/ix-apps/app_mounts/overseerr@1.1.8                      readonly  -       -
Pool1/ix-apps/app_mounts/overseerr@1.1.9                      readonly  -       -
Pool1/ix-apps/app_mounts/overseerr@1.1.12                     readonly  -       -
Pool1/ix-apps/app_mounts/overseerr/config                     readonly  off     default
Pool1/ix-apps/app_mounts/overseerr/config@1.1.2               readonly  -       -
Pool1/ix-apps/app_mounts/overseerr/config@1.1.1               readonly  -       -
Pool1/ix-apps/app_mounts/overseerr/config@1.1.4               readonly  -       -
Pool1/ix-apps/app_mounts/overseerr/config@1.1.5               readonly  -       -
Pool1/ix-apps/app_mounts/overseerr/config@1.1.6               readonly  -       -
Pool1/ix-apps/app_mounts/overseerr/config@1.1.8               readonly  -       -
Pool1/ix-apps/app_mounts/overseerr/config@1.1.9               readonly  -       -
Pool1/ix-apps/app_mounts/overseerr/config@1.1.12              readonly  -       -
Pool1/ix-apps/app_mounts/pihole                               readonly  off     default
Pool1/ix-apps/app_mounts/pihole@1.2.1                         readonly  -       -
Pool1/ix-apps/app_mounts/pihole@1.2.7                         readonly  -       -
Pool1/ix-apps/app_mounts/pihole@1.2.14                        readonly  -       -
Pool1/ix-apps/app_mounts/pihole@1.2.19                        readonly  -       -
Pool1/ix-apps/app_mounts/pihole@1.2.25                        readonly  -       -
Pool1/ix-apps/app_mounts/pihole@1.3.6                         readonly  -       -
Pool1/ix-apps/app_mounts/pihole/config                        readonly  off     default
Pool1/ix-apps/app_mounts/pihole/config@1.2.1                  readonly  -       -
Pool1/ix-apps/app_mounts/pihole/config@1.2.7                  readonly  -       -
Pool1/ix-apps/app_mounts/pihole/config@1.2.14                 readonly  -       -
Pool1/ix-apps/app_mounts/pihole/config@1.2.19                 readonly  -       -
Pool1/ix-apps/app_mounts/pihole/config@1.2.25                 readonly  -       -
Pool1/ix-apps/app_mounts/pihole/config@1.3.6                  readonly  -       -
Pool1/ix-apps/app_mounts/pihole/dnsmasq                       readonly  off     default
Pool1/ix-apps/app_mounts/pihole/dnsmasq@1.2.1                 readonly  -       -
Pool1/ix-apps/app_mounts/pihole/dnsmasq@1.2.7                 readonly  -       -
Pool1/ix-apps/app_mounts/pihole/dnsmasq@1.2.14                readonly  -       -
Pool1/ix-apps/app_mounts/pihole/dnsmasq@1.2.19                readonly  -       -
Pool1/ix-apps/app_mounts/pihole/dnsmasq@1.2.25                readonly  -       -
Pool1/ix-apps/app_mounts/pihole/dnsmasq@1.3.6                 readonly  -       -
Pool1/ix-apps/app_mounts/plex                                 readonly  off     default
Pool1/ix-apps/app_mounts/plex@1.1.15                          readonly  -       -
Pool1/ix-apps/app_mounts/plex@1.1.16                          readonly  -       -
Pool1/ix-apps/app_mounts/plex@1.1.18                          readonly  -       -
Pool1/ix-apps/app_mounts/plex@1.1.19                          readonly  -       -
Pool1/ix-apps/app_mounts/plex@1.1.22                          readonly  -       -
Pool1/ix-apps/app_mounts/plex@1.2.4                           readonly  -       -
Pool1/ix-apps/app_mounts/plex/config                          readonly  off     default
Pool1/ix-apps/app_mounts/plex/config@1.1.15                   readonly  -       -
Pool1/ix-apps/app_mounts/plex/config@1.1.16                   readonly  -       -
Pool1/ix-apps/app_mounts/plex/config@1.1.18                   readonly  -       -
Pool1/ix-apps/app_mounts/plex/config@1.1.19                   readonly  -       -
Pool1/ix-apps/app_mounts/plex/config@1.1.22                   readonly  -       -
Pool1/ix-apps/app_mounts/plex/config@1.2.4                    readonly  -       -
Pool1/ix-apps/app_mounts/plex/data                            readonly  off     default
Pool1/ix-apps/app_mounts/plex/data@1.1.15                     readonly  -       -
Pool1/ix-apps/app_mounts/plex/data@1.1.16                     readonly  -       -
Pool1/ix-apps/app_mounts/plex/data@1.1.18                     readonly  -       -
Pool1/ix-apps/app_mounts/plex/data@1.1.19                     readonly  -       -
Pool1/ix-apps/app_mounts/plex/data@1.1.22                     readonly  -       -
Pool1/ix-apps/app_mounts/plex/data@1.2.4                      readonly  -       -
Pool1/ix-apps/app_mounts/radarr                               readonly  off     default
Pool1/ix-apps/app_mounts/radarr@1.2.8                         readonly  -       -
Pool1/ix-apps/app_mounts/radarr@1.2.9                         readonly  -       -
Pool1/ix-apps/app_mounts/radarr@1.2.3                         readonly  -       -
Pool1/ix-apps/app_mounts/radarr@1.2.12                        readonly  -       -
Pool1/ix-apps/app_mounts/radarr@1.2.14                        readonly  -       -
Pool1/ix-apps/app_mounts/radarr@1.2.17                        readonly  -       -
Pool1/ix-apps/app_mounts/radarr@1.2.24                        readonly  -       -
Pool1/ix-apps/app_mounts/radarr@1.2.26                        readonly  -       -
Pool1/ix-apps/app_mounts/radarr@1.3.6                         readonly  -       -
Pool1/ix-apps/app_mounts/radarr@1.3.7                         readonly  -       -
Pool1/ix-apps/app_mounts/radarr/config                        readonly  off     default
Pool1/ix-apps/app_mounts/radarr/config@1.2.8                  readonly  -       -
Pool1/ix-apps/app_mounts/radarr/config@1.2.9                  readonly  -       -
Pool1/ix-apps/app_mounts/radarr/config@1.2.3                  readonly  -       -
Pool1/ix-apps/app_mounts/radarr/config@1.2.12                 readonly  -       -
Pool1/ix-apps/app_mounts/radarr/config@1.2.14                 readonly  -       -
Pool1/ix-apps/app_mounts/radarr/config@1.2.17                 readonly  -       -
Pool1/ix-apps/app_mounts/radarr/config@1.2.24                 readonly  -       -
Pool1/ix-apps/app_mounts/radarr/config@1.2.26                 readonly  -       -
Pool1/ix-apps/app_mounts/radarr/config@1.3.6                  readonly  -       -
Pool1/ix-apps/app_mounts/radarr/config@1.3.7                  readonly  -       -
Pool1/ix-apps/app_mounts/sabnzbd                              readonly  off     default
Pool1/ix-apps/app_mounts/sabnzbd@1.1.2                        readonly  -       -
Pool1/ix-apps/app_mounts/sabnzbd@1.1.7                        readonly  -       -
Pool1/ix-apps/app_mounts/sabnzbd@1.1.9                        readonly  -       -
Pool1/ix-apps/app_mounts/sabnzbd@1.1.10                       readonly  -       -
Pool1/ix-apps/app_mounts/sabnzbd@1.1.11                       readonly  -       -
Pool1/ix-apps/app_mounts/sabnzbd@1.1.15                       readonly  -       -
Pool1/ix-apps/app_mounts/sabnzbd@1.2.3                        readonly  -       -
Pool1/ix-apps/app_mounts/sabnzbd/config                       readonly  off     default
Pool1/ix-apps/app_mounts/sabnzbd/config@1.1.2                 readonly  -       -
Pool1/ix-apps/app_mounts/sabnzbd/config@1.1.7                 readonly  -       -
Pool1/ix-apps/app_mounts/sabnzbd/config@1.1.9                 readonly  -       -
Pool1/ix-apps/app_mounts/sabnzbd/config@1.1.10                readonly  -       -
Pool1/ix-apps/app_mounts/sabnzbd/config@1.1.11                readonly  -       -
Pool1/ix-apps/app_mounts/sabnzbd/config@1.1.15                readonly  -       -
Pool1/ix-apps/app_mounts/sabnzbd/config@1.2.3                 readonly  -       -
Pool1/ix-apps/app_mounts/sonarr                               readonly  off     default
Pool1/ix-apps/app_mounts/sonarr@1.1.3                         readonly  -       -
Pool1/ix-apps/app_mounts/sonarr@1.1.4                         readonly  -       -
Pool1/ix-apps/app_mounts/sonarr@1.1.7                         readonly  -       -
Pool1/ix-apps/app_mounts/sonarr@1.1.8                         readonly  -       -
Pool1/ix-apps/app_mounts/sonarr@1.1.11                        readonly  -       -
Pool1/ix-apps/app_mounts/sonarr@1.1.12                        readonly  -       -
Pool1/ix-apps/app_mounts/sonarr@1.1.13                        readonly  -       -
Pool1/ix-apps/app_mounts/sonarr@1.1.15                        readonly  -       -
Pool1/ix-apps/app_mounts/sonarr@1.1.17                        readonly  -       -
Pool1/ix-apps/app_mounts/sonarr/config                        readonly  off     default
Pool1/ix-apps/app_mounts/sonarr/config@1.1.3                  readonly  -       -
Pool1/ix-apps/app_mounts/sonarr/config@1.1.4                  readonly  -       -
Pool1/ix-apps/app_mounts/sonarr/config@1.1.7                  readonly  -       -
Pool1/ix-apps/app_mounts/sonarr/config@1.1.8                  readonly  -       -
Pool1/ix-apps/app_mounts/sonarr/config@1.1.11                 readonly  -       -
Pool1/ix-apps/app_mounts/sonarr/config@1.1.12                 readonly  -       -
Pool1/ix-apps/app_mounts/sonarr/config@1.1.13                 readonly  -       -
Pool1/ix-apps/app_mounts/sonarr/config@1.1.15                 readonly  -       -
Pool1/ix-apps/app_mounts/sonarr/config@1.1.17                 readonly  -       -
Pool1/ix-apps/app_mounts/tailscale                            readonly  off     default
Pool1/ix-apps/app_mounts/tailscale@1.2.2                      readonly  -       -
Pool1/ix-apps/app_mounts/tailscale@1.2.5                      readonly  -       -
Pool1/ix-apps/app_mounts/tailscale@1.2.7                      readonly  -       -
Pool1/ix-apps/app_mounts/tailscale@1.2.8                      readonly  -       -
Pool1/ix-apps/app_mounts/tailscale@1.2.1                      readonly  -       -
Pool1/ix-apps/app_mounts/tailscale@1.2.12                     readonly  -       -
Pool1/ix-apps/app_mounts/tailscale@1.2.13                     readonly  -       -
Pool1/ix-apps/app_mounts/tailscale@1.2.14                     readonly  -       -
Pool1/ix-apps/app_mounts/tailscale@1.2.17                     readonly  -       -
Pool1/ix-apps/app_mounts/tailscale@1.3.3                      readonly  -       -
Pool1/ix-apps/app_mounts/tailscale/state                      readonly  off     default
Pool1/ix-apps/app_mounts/tailscale/state@1.2.2                readonly  -       -
Pool1/ix-apps/app_mounts/tailscale/state@1.2.5                readonly  -       -
Pool1/ix-apps/app_mounts/tailscale/state@1.2.7                readonly  -       -
Pool1/ix-apps/app_mounts/tailscale/state@1.2.8                readonly  -       -
Pool1/ix-apps/app_mounts/tailscale/state@1.2.1                readonly  -       -
Pool1/ix-apps/app_mounts/tailscale/state@1.2.12               readonly  -       -
Pool1/ix-apps/app_mounts/tailscale/state@1.2.13               readonly  -       -
Pool1/ix-apps/app_mounts/tailscale/state@1.2.14               readonly  -       -
Pool1/ix-apps/app_mounts/tailscale/state@1.2.17               readonly  -       -
Pool1/ix-apps/app_mounts/tailscale/state@1.3.3                readonly  -       -
Pool1/ix-apps/docker                                          readonly  off     default
Pool1/ix-apps/truenas_catalog                                 readonly  off     default
I’m not sure, maybe you do. It doesn’t make sense that it says readonly when the flag is off.
Unless, maybe it won’t let you mount anything on the root / in which case, then it would make sense why those datasets are not mounting.
What bothers me is how did those mount points change in the first place? In any case, the next thing you can try now is to reassign the mount points from /.ix-apps to /mnt/.ix-apps with the command:
zfs set mountpoint=/mnt/.ix-apps Pool1/ix-apps
Obviously, if that works, then you should duplicate it with all the other datasets as well.
so that ‘worked’
root@truenas[~]# zfs get mountpoint | grep Pool1
Pool1/ix-apps                                                   mountpoint  /mnt/.ix-apps                                          local
Pool1/ix-apps/app_configs                                       mountpoint  /mnt/.ix-apps/app_configs                              inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts                                        mountpoint  /mnt/.ix-apps/app_mounts                               inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/actual-budget                          mountpoint  /mnt/.ix-apps/app_mounts/actual-budget                 inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/actual-budget/data                     mountpoint  /mnt/.ix-apps/app_mounts/actual-budget/data            inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/home-assistant                         mountpoint  /mnt/.ix-apps/app_mounts/home-assistant                inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/home-assistant/config                  mountpoint  /mnt/.ix-apps/app_mounts/home-assistant/config         inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/home-assistant/media                   mountpoint  /mnt/.ix-apps/app_mounts/home-assistant/media          inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/home-assistant/postgres_data           mountpoint  /mnt/.ix-apps/app_mounts/home-assistant/postgres_data  inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/overseerr                              mountpoint  /mnt/.ix-apps/app_mounts/overseerr                     inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/overseerr/config                       mountpoint  /mnt/.ix-apps/app_mounts/overseerr/config              inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/pihole                                 mountpoint  /mnt/.ix-apps/app_mounts/pihole                        inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/pihole/config                          mountpoint  /mnt/.ix-apps/app_mounts/pihole/config                 inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/pihole/dnsmasq                         mountpoint  /mnt/.ix-apps/app_mounts/pihole/dnsmasq                inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/plex                                   mountpoint  /mnt/.ix-apps/app_mounts/plex                          inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/plex/config                            mountpoint  /mnt/.ix-apps/app_mounts/plex/config                   inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/plex/data                              mountpoint  /mnt/.ix-apps/app_mounts/plex/data                     inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/radarr                                 mountpoint  /mnt/.ix-apps/app_mounts/radarr                        inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/radarr/config                          mountpoint  /mnt/.ix-apps/app_mounts/radarr/config                 inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/sabnzbd                                mountpoint  /mnt/.ix-apps/app_mounts/sabnzbd                       inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/sabnzbd/config                         mountpoint  /mnt/.ix-apps/app_mounts/sabnzbd/config                inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/sonarr                                 mountpoint  /mnt/.ix-apps/app_mounts/sonarr                        inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/sonarr/config                          mountpoint  /mnt/.ix-apps/app_mounts/sonarr/config                 inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/tailscale                              mountpoint  /mnt/.ix-apps/app_mounts/tailscale                     inherited from Pool1/ix-apps
Pool1/ix-apps/app_mounts/tailscale/state                        mountpoint  /mnt/.ix-apps/app_mounts/tailscale/state               inherited from Pool1/ix-apps
Pool1/ix-apps/docker                                            mountpoint  /mnt/.ix-apps/docker                                   inherited from Pool1/ix-apps
Pool1/ix-apps/truenas_catalog                                   mountpoint  /mnt/.ix-apps/truenas_catalog                          inherited from Pool1/ix-apps
but when I run ‘zfs mount’ no changes
root@truenas[~]# zfs mount
when I rebooted i did attach an external enclosure that is attached via SCSI but I did not do anything else, the disks in the enclosure were detected and were not part of any pool. They are all spinning disks and these are disks are all SSDs and I know i did not do anything with regards to pool config. The external enclosure is no longer connected. Is there anyway i can restore from a snapshot - I have seen some other posts about similar issues.
so i tried another reboot and now the ‘system managed’ volumes have come back, so my apps are showing up and some running except for the applications I had on non system managed volumes. The volumes are listed in the GUI but I get an error when I click on top level. I can click on each child volume with no error.
This one volume is the only one i have an Rsync task configured for and it is the only one not working.
It sounds like you got most of things working again, minor maybe some other unrelated stuff (rsync)? What specifically on it isn’t working?
Yes thank you for pointing me at the issue. It was a mountpoint mapping problem. I still have an issue with ‘why’ it happened but thankful nothing was lost :slight_smile:
