Problem with Asm1166 10Port PCIE
I have a Truenas community version, which I switched off from 24.10 to 25.04. Since then, I’ve been having problems with the SATA PCIE card Asm1166 10-port PCIE. My hard drives are no longer recognized, so I’ve also added a few locomotives. If you have any ideas or solutions, please let me know.
I’m pretty sure there have been major changes to the kernel, which means the hardware is no longer compatible with the kernel.
3.121781] ahci 0000:00:1f.2: AHCI vers 0001.0000, 32 command slots, 1.5 Gbps, SATA mode
[ 3.121785] ahci 0000:00:1f.2: 6/6 ports implemented (port mask 0x3f)
[ 3.121788] ahci 0000:00:1f.2: flags: 64bit ncq only
[ 3.122149] sd 2:0:0:2: Power-on or device reset occurred
[ 3.122214] sd 1:0:0:1: [sdc] 41943040 512-byte logical blocks: (21.5 GB/20.0 GiB)
[ 3.122613] hub 8-0:1.0: 2 ports detected
[ 3.122675] sd 0:0:0:0: [sda] 31457280 512-byte logical blocks: (16.1 GB/15.0 GiB)
[ 3.122719] sd 0:0:0:0: [sda] Write Protect is off
[ 3.122722] sd 0:0:0:0: [sda] Mode Sense: 63 00 00 08
[ 3.122805] sd 2:0:0:2: [sdb] 41943040 512-byte logical blocks: (21.5 GB/20.0 GiB)
[ 3.122825] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 3.122846] sd 2:0:0:2: [sdb] Write Protect is off
[ 3.122849] sd 2:0:0:2: [sdb] Mode Sense: 63 00 00 08
[ 3.122896] sd 2:0:0:2: [sdb] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 3.124243] sd 1:0:0:1: [sdc] Write Protect is off
[ 3.129951] sd 1:0:0:1: [sdc] Mode Sense: 63 00 00 08
[ 3.130173] sd 1:0:0:1: [sdc] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 3.133202] scsi host3: ahci
[ 3.133492] scsi host4: ahci
[ 3.133781] scsi host5: ahci
[ 3.134040] scsi host6: ahci
[ 3.134299] scsi host7: ahci
[ 3.134555] scsi host8: ahci
[ 3.134680] ata1: SATA max UDMA/133 abar m4096@0xfea1b000 port 0xfea1b100 irq 56 lpm-pol 0
[ 3.134693] ata2: SATA max UDMA/133 abar m4096@0xfea1b000 port 0xfea1b180 irq 56 lpm-pol 0
[ 3.134704] ata3: SATA max UDMA/133 abar m4096@0xfea1b000 port 0xfea1b200 irq 56 lpm-pol 0
[ 3.134715] ata4: SATA max UDMA/133 abar m4096@0xfea1b000 port 0xfea1b280 irq 56 lpm-pol 0
[ 3.134726] ata5: SATA max UDMA/133 abar m4096@0xfea1b000 port 0xfea1b300 irq 56 lpm-pol 0
[ 3.134738] ata6: SATA max UDMA/133 abar m4096@0xfea1b000 port 0xfea1b380 irq 56 lpm-pol 0
[ 3.136211] ahci 0000:06:10.0: SSS flag set, parallel bus scan disabled
[ 3.146556] ahci 0000:06:10.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
[ 3.146565] ahci 0000:06:10.0: 30/32 ports implemented (port mask 0xffffff3f)
[ 3.146568] ahci 0000:06:10.0: flags: 64bit ncq sntf stag pm led only pio slum part deso sadm sds apst
[ 3.147507] sdb: sdb1
[ 3.147558] sdc: sdc1
[ 3.147675] sd 2:0:0:2: [sdb] Attached SCSI disk
[ 3.147710] GPT:Primary header thinks Alt. header is not at the end of the disk.
[ 3.148253] sd 1:0:0:1: [sdc] Attached SCSI disk
[ 3.148646] GPT:20971519 != 31457279
[ 3.149321] GPT:Alternate GPT header not at the end of the disk.
[ 3.149670] GPT:20971519 != 31457279
[ 3.149927] GPT: Use GNU Parted to correct GPT errors.
[ 3.150233] sda: sda1 sda2 sda3
[ 3.150650] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.157073] scsi host9: ahci
[ 3.157499] scsi host10: ahci
[ 3.157921] scsi host11: ahci
[ 3.158661] scsi host12: ahci
[ 3.159097] scsi host13: ahci
[ 3.159506] scsi host14: ahci
[ 3.159888] scsi host15: ahci
[ 3.160237] scsi host16: ahci
[ 3.160500] scsi host17: ahci
[ 3.160887] scsi host18: ahci
[ 3.161226] scsi host19: ahci
[ 3.161508] scsi host20: ahci
[ 3.161793] scsi host21: ahci
[ 3.162065] scsi host22: ahci
[ 3.162428] scsi host23: ahci
[ 3.162829] scsi host24: ahci
[ 3.163256] scsi host25: ahci
[ 3.163759] scsi host26: ahci
[ 3.164184] scsi host27: ahci
[ 3.164841] scsi host28: ahci
[ 3.165270] scsi host29: ahci
[ 3.166113] scsi host30: ahci
[ 3.166791] scsi host31: ahci
[ 3.167419] scsi host32: ahci
[ 3.167872] scsi host33: ahci
[ 3.168319] scsi host34: ahci
[ 3.168782] scsi host35: ahci
[ 3.169217] scsi host36: ahci
[ 3.169689] scsi host37: ahci
[ 3.170124] scsi host38: ahci
[ 3.170551] scsi host39: ahci
[ 3.171026] scsi host40: ahci
[ 3.171106] ata7: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02100 irq 57 lpm-pol 0
[ 3.171111] ata8: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02180 irq 57 lpm-pol 0
[ 3.171114] ata9: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02200 irq 57 lpm-pol 0
[ 3.171117] ata10: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02280 irq 57 lpm-pol 0
[ 3.171121] ata11: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02300 irq 57 lpm-pol 0
[ 3.171124] ata12: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02380 irq 57 lpm-pol 0
[ 3.171126] ata13: DUMMY
[ 3.171128] ata14: DUMMY
[ 3.171130] ata15: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02500 irq 57 lpm-pol 0
[ 3.171133] ata16: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02580 irq 57 lpm-pol 0
[ 3.171136] ata17: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02600 irq 57 lpm-pol 0
[ 3.171139] ata18: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02680 irq 57 lpm-pol 0
[ 3.171142] ata19: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02700 irq 57 lpm-pol 0
[ 3.171145] ata20: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02780 irq 57 lpm-pol 0
[ 3.171148] ata21: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02800 irq 57 lpm-pol 0
[ 3.171151] ata22: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02880 irq 57 lpm-pol 0
[ 3.171154] ata23: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02900 irq 57 lpm-pol 0
[ 3.171157] ata24: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02980 irq 57 lpm-pol 0
[ 3.171160] ata25: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02a00 irq 57 lpm-pol 0
[ 3.171163] ata26: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02a80 irq 57 lpm-pol 0
[ 3.171166] ata27: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02b00 irq 57 lpm-pol 0
[ 3.171168] ata28: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02b80 irq 57 lpm-pol 0
[ 3.171171] ata29: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02c00 irq 57 lpm-pol 0
[ 3.171174] ata30: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02c80 irq 57 lpm-pol 0
[ 3.171177] ata31: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02d00 irq 57 lpm-pol 0
[ 3.171180] ata32: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02d80 irq 57 lpm-pol 0
[ 3.171183] ata33: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02e00 irq 57 lpm-pol 0
[ 3.171186] ata34: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02e80 irq 57 lpm-pol 0
[ 3.171189] ata35: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02f00 irq 57 lpm-pol 0
[ 3.171192] ata36: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf02f80 irq 57 lpm-pol 0
[ 3.171195] ata37: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf03000 irq 57 lpm-pol 0
[ 3.171198] ata38: SATA max UDMA/133 abar m8192@0xfdf02000 port 0xfdf03080 irq 57 lpm-pol 0
[ 3.328495] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 3.448694] ata3: SATA link down (SStatus 0 SControl 300)
[ 3.449028] ata6: SATA link down (SStatus 0 SControl 300)
[ 3.449348] ata5: SATA link down (SStatus 0 SControl 300)
[ 3.449570] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.449770] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 3.449927] ata2.00: ATAPI: QEMU DVD-ROM, 2.5+, max UDMA/100
[ 3.449932] ata2.00: applying bridge limits
[ 3.450091] ata4: SATA link down (SStatus 0 SControl 300)
[ 3.450213] ata2.00: configured for UDMA/100
[ 3.450611] scsi 4:0:0:0: CD-ROM QEMU QEMU DVD-ROM 2.5+ PQ: 0 ANSI: 5
[ 3.474410] usb 1-1: New USB device found, idVendor=0627, idProduct=0001, bcdDevice= 0.00
[ 3.474418] usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=10
[ 3.474420] usb 1-1: Product: QEMU USB Tablet
[ 3.474422] usb 1-1: Manufacturer: QEMU
[ 3.474424] usb 1-1: SerialNumber: 28754-0000:00:1d.7-1
[ 3.479867] hid: raw HID events driver (C) Jiri Kosina
[ 3.480543] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 8.688513] ata7.00: qc timeout after 5000 msecs (cmd 0xec)
[ 8.688887] ata7.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 8.997057] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 19.184515] ata7.00: qc timeout after 10000 msecs (cmd 0xec)
[ 19.184913] ata7.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 19.185251] ata7: limiting SATA link speed to 3.0 Gbps
[ 19.492568] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 320)
[ 50.416506] ata7.00: qc timeout after 30000 msecs (cmd 0xec)
[ 50.416868] ata7.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 50.725251] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 320)
[ 51.033358] ata8: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 56.048543] ata8.00: qc timeout after 5000 msecs (cmd 0xec)
[ 56.048909] ata8.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 56.357104] ata8: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 66.544520] ata8.00: qc timeout after 10000 msecs (cmd 0xec)
[ 66.544910] ata8.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 66.545236] ata8: limiting SATA link speed to 3.0 Gbps
[ 66.852768] ata8: SATA link up 6.0 Gbps (SStatus 133 SControl 320)
[ 97.520515] ata8.00: qc timeout after 30000 msecs (cmd 0xec)
[ 97.520881] ata8.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 97.829045] ata8: SATA link up 6.0 Gbps (SStatus 133 SControl 320)
[ 98.137176] ata9: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 103.152428] ata9.00: qc timeout after 5000 msecs (cmd 0xec)
[ 103.152802] ata9.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 103.461104] ata9: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 113.648529] ata9.00: qc timeout after 10000 msecs (cmd 0xec)
[ 113.648892] ata9.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 113.957465] ata9: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 144.624552] ata9.00: qc timeout after 30000 msecs (cmd 0xec)
[ 144.625025] ata9.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 144.937378] ata9: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 145.244713] ata10: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 150.256505] ata10.00: qc timeout after 5000 msecs (cmd 0xec)
[ 150.256867] ata10.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 150.564930] ata10: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 160.752520] ata10.00: qc timeout after 10000 msecs (cmd 0xec)
[ 160.752901] ata10.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 161.061407] ata10: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 180.844469] random: crng init done
[ 191.728516] ata10.00: qc timeout after 30000 msecs (cmd 0xec)
[ 191.728915] ata10.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 192.037199] ata10: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 192.344963] ata11: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 197.360547] ata11.00: qc timeout after 5000 msecs (cmd 0xec)
[ 197.360935] ata11.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 197.668877] ata11: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 207.856538] ata11.00: qc timeout after 10000 msecs (cmd 0xec)
[ 207.856902] ata11.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 207.857256] ata11: limiting SATA link speed to 3.0 Gbps
[ 208.165328] ata11: SATA link up 6.0 Gbps (SStatus 133 SControl 320)
[ 238.832530] ata11.00: qc timeout after 30000 msecs (cmd 0xec)
[ 238.832897] ata11.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 239.141095] ata11: SATA link up 6.0 Gbps (SStatus 133 SControl 320)
[ 239.451953] ata12: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 244.464469] ata12.00: qc timeout after 5000 msecs (cmd 0xec)
[ 244.464860] ata12.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 244.773182] ata12: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 254.960511] ata12.00: qc timeout after 10000 msecs (cmd 0xec)
[ 254.960896] ata12.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 254.961223] ata12: limiting SATA link speed to 3.0 Gbps
[ 255.269205] ata12: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[ 285.936533] ata12.00: qc timeout after 30000 msecs (cmd 0xec)
[ 285.936897] ata12.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 286.244837] ata12: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[ 286.553277] ata15: SATA link down (SStatus 0 SControl 300)
[ 286.860923] ata16: SATA link down (SStatus 0 SControl 300)
[ 287.168900] ata17: SATA link down (SStatus 0 SControl 300)
[ 287.477035] ata18: SATA link down (SStatus 0 SControl 300)
[ 287.784854] ata19: SATA link down (SStatus 0 SControl 300)
[ 288.093219] ata20: SATA link down (SStatus 0 SControl 300)
[ 288.400974] ata21: SATA link down (SStatus 0 SControl 300)
[ 288.709161] ata22: SATA link down (SStatus 0 SControl 300)
[ 289.017346] ata23: SATA link down (SStatus 0 SControl 300)
[ 289.329155] ata24: SATA link down (SStatus 0 SControl 300)
[ 289.637393] ata25: SATA link down (SStatus 0 SControl 300)
[ 289.944896] ata26: SATA link down (SStatus 0 SControl 300)
[ 290.253114] ata27: SATA link down (SStatus 0 SControl 300)
[ 290.560699] ata28: SATA link down (SStatus 0 SControl 300)
[ 290.873281] ata29: SATA link down (SStatus 0 SControl 300)
[ 291.180865] ata30: SATA link down (SStatus 0 SControl 300)
[ 291.488984] ata31: SATA link down (SStatus 0 SControl 300)
[ 291.797396] ata32: SATA link down (SStatus 0 SControl 300)
[ 292.105222] ata33: SATA link down (SStatus 0 SControl 300)
[ 292.412776] ata34: SATA link down (SStatus 0 SControl 300)
[ 292.720761] ata35: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 297.968396] ata35.00: qc timeout after 5000 msecs (cmd 0xec)
[ 297.968779] ata35.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 298.279382] ata35: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 308.464475] ata35.00: qc timeout after 10000 msecs (cmd 0xec)
[ 308.464875] ata35.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 308.465260] ata35: limiting SATA link speed to 3.0 Gbps
[ 308.775457] ata35: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[ 339.184468] ata35.00: qc timeout after 30000 msecs (cmd 0xec)
[ 339.184841] ata35.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 339.497042] ata35: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[ 339.805162] ata36: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 344.816486] ata36.00: qc timeout after 5000 msecs (cmd 0xec)
[ 344.816850] ata36.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 345.125257] ata36: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 355.312495] ata36.00: qc timeout after 10000 msecs (cmd 0xec)
[ 355.312861] ata36.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 355.313191] ata36: limiting SATA link speed to 3.0 Gbps
[ 355.620575] ata36: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[ 386.288544] ata36.00: qc timeout after 30000 msecs (cmd 0xec)
[ 386.288938] ata36.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 386.597206] ata36: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[ 386.905010] ata37: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 391.920533] ata37.00: qc timeout after 5000 msecs (cmd 0xec)
[ 391.920894] ata37.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 392.228852] ata37: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 402.416459] ata37.00: qc timeout after 10000 msecs (cmd 0xec)
[ 402.416822] ata37.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 402.417184] ata37: limiting SATA link speed to 3.0 Gbps
[ 402.725301] ata37: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[ 433.392476] ata37.00: qc timeout after 30000 msecs (cmd 0xec)
[ 433.392865] ata37.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 433.701072] ata37: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[ 434.012234] ata38: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 439.024504] ata38.00: qc timeout after 5000 msecs (cmd 0xec)
[ 439.024895] ata38.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 439.333309] ata38: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 449.520585] ata38.00: qc timeout after 10000 msecs (cmd 0xec)
[ 449.521049] ata38.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 449.521395] ata38: limiting SATA link speed to 3.0 Gbps
[ 449.828461] ata38: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[ 480.496495] ata38.00: qc timeout after 30000 msecs (cmd 0xec)
[ 480.496863] ata38.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 480.805038] ata38: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[ 480.874527] spl: loading out-of-tree module taints kernel.
[ 480.927101] zfs: module license ‘CDDL’ taints kernel.
[ 480.927503] Disabling lock debugging due to kernel taint
[ 480.927906] zfs: module license taints kernel.
can you link what exact card you’ve bought?
the ASM1166 is a 6-port chipset, not 10-port. which brings the possibility you’ve bought a card with port-multiplier chips.
Your log also has lines like [ 3.449927] ata2.00: ATAPI: QEMU DVD-ROM, 2.5+, max UDMA/100 suggesting you may be running this in on a hypervisor which can be risky if not done correctly. (Proxmox in particular has been known to silently import TrueNAS pools before starting the TrueNAS VM…)
not sure what you mean by adding locomotives… but please describe your setup.
Locomotives’…? Could it be that the text was originally written in another language (maybe German?), and that the English word ‘logs’ (for logfiles) was misspelled as ‘Loks,’ which a not-so-smart AI then translated as ‘locomotives’…?
Please format the log output using the </> button.
Locomotive means logfiles.
Asm1166 10port sata
Yes it runs on a hypervisor (proxmox 9.0) the truenas runs on a VM, the SATA card as device passthrough and we also prevented in proxmox boot settings to mount.
It works flawlessly under TrueNAS 24.10, but as soon as you update to 25.04, it can no longer access the hard drives. If you reboot to 24.10, everything works without issues (do not change the settings on Proxmox or reboot Proxmox at this time).
My Setup and image
Asus F2A85-M
AMD A10-5700
20GB DDR3
SSD Boot
2x 10TB Seagate ironwolf
5x 1TB WB Blue
2x 300GB WB
Powersupply 350W
…until it doesn’t because your SATA card has a JMB port multiplier. Stay on 24.10 until you have replaced the card by a proper SAS HBA, or at the very least a card without port multiplier (won’t be cheaper than the HBA).
