Problems updating certain apps
I am on TrueNAS-SCALE-24.10.0.2. My first example is Overseerr app version 1.33.2 version 1.0.21 getting updated to 1.1.0. I get the following error:
[EFAULT] Failed to render compose templates: Traceback (most recent call last): File "/usr/bin/apps_render_app", line 33, in sys.exit(load_entry_point('apps-validation==0.1', 'console_scripts', 'apps_render_app')()) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 47, in main render_templates_from_path(args.path, args.values) File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 19, in render_templates_from_path rendered_data = render_templates( ^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/catalog_templating/render.py", line 36, in render_templates ).render({'ix_lib': template_libs, 'values': test_values}) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 1301, in render self.environment.handle_exception() File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 936, in handle_exception raise rewrite_traceback_stack(source=source) File "/mnt/.ix-apps/app_configs/overseerr/versions/1.1.0/templates/docker-compose.yaml", line 19, in top-level template code {% do c1.add_storage(store.mount_path, store) %} ^^^^^^^^^^^^^^^^^^^^^^^^^ File "/mnt/.ix-apps/app_configs/overseerr/versions/1.1.0/templates/library/base_v2_0_29/container.py", line 196, in add_storage self._storage.add(mount_path, config) File "/mnt/.ix-apps/app_configs/overseerr/versions/1.1.0/templates/library/base_v2_0_29/storage.py", line 89, in add raise RenderError(f"Mount path [{mount_path}] already used for another volume mount") base_v2_0_29.error.RenderError: Mount path [/app/config] already used for another volume mount
I am rather new to docker and the apps are working, just can’t seem to update. the errors seem to be mostly the same. So far overseerr, prowlarr, radarr, sonarr and sabnzbd are the only apps that won’t update. Any advise?
Had that happen with Metube over the weekend. I just moved to running it as a custom compose app.
OK, I found the custom app. I will have to play with it later. Since these were installed via the apps page I am curious aside from custom apps what would be the typical fix for this? I see this more of a UX issue more then anything. I just want to see truenas only get better and easier for users.
