Qbittorrent problem v5.0.1 to 5.0.3
Hi I m stuck with a problem
yesterday I update qbittorrent 5.0.1 in jail , it works flawesly webUI
after applied
pkg update
pkg upgrade
qbittorrent-nox -d
the webUI didnt start and I couldn’t access via web
I decided nuke the jail and reinstall qbittorrent in otrher jail and after the installation the shell shows error in libraries that I never seen before.
ld-elf.so.1: /lib/libcxxrt.so.1: version CXXABI_1.3.11 required by /usr/local/lib/libtorrent-rasterbar.so.10 not found
root@qbittorrent:~ #[qbittorrent]
would you help me ?
thanks
Version of Core?
Version of FreeBSD jail?
Was this originally a “Plugin”?
Core 13.0
Jail 13.3
in september 2024 I followed this tutorial without a problem and I made update until yesterday with no issue:
It was installed direct in the jail with commands in its shell, before the problem I updated the pkgs in the shell.
You’ll need to upgrade to Core 13.3, and upgrade your jails for FreeBSD 13.4.
Today I ve update the system to core 13.3. U1 and it doesn’t work, same error creating jail in 13.3 and trying to install qbittorrent.
Truenas doesn’t let me to create jail in 13.4 either
You have to use iocage fetch to first acquire the 13.4-RELEASE.
Iocage fetch in the shell of the system or in the shell of jail?
Thanks for your help
The TrueNAS host. Then after it downloads the release you can upgrade jails to 13.4, or install new 13.4 jails.
Thanks, I will do it,
I more question, actually I have plex working very well in a jail 13.3, if I proceed with the command iocage fletch in truenas host and I select 13.4 , my plex jail 13.3 will continue working properly?
Not sure, but I am using 13.4 jails just fine, including Jellyfin.
After 3 days of intensive work with my truenas core I finally migrated to truenas scale. The migration process was very smooth (10min) and the installations of docker for plex an qbittorrent was very fast. All the settings were ok and all the folder in sambas were ok too. But the current version of qbittorrent in docker (5.0.3) has something weird. Same IP for the truenas , same port forwarding, same tracking for torrents, but the speed is very low. And this version doesn’t allowed to install search engine plugins and I needed to install prowlarr.
Someone could share your experiences or settings with qbittorrent in docker with truenas scale
Thanks
seen another core user move to scale and in my head it’s playing “another one bites the dust” … do i have a problem? :thinking:
funny…
Now the download speed is ok
If I search the torrents with prowlarr , there is no problem, the problem persist in the installation of the search engines plugins and qbittorrent doesn’t allow copy and paste a magnet link in button link.
Are you using the community app version? I gave up on that quickly because it forbids use with a VPN unless you hack it into TN somehow, and switched to using Dockge and then installing gluetun and qbit through that with custom docker-compose yml files. I would never recommend using the community app here.
