Qemu Guest Agent installation for newbie
Thank you all for your help! I am going to see how an upgrade to SCALE works. Will have to look into that.
Does anyone have current install guide of qemu guest agent for truenas core current version? TrueNAS CORE 13.0-U6.4
I dont want to use scale. I dont like it one bit, I have zero use for all the bloat and features, I just want a NAS, and my HBA that works fine under truenas core does nothing but constant io errors under true nas scale anyways. I have tried several versions of scale. They all do not work properly with it and all of them have had the same io error problems.
The machine is an old dell power edge r720 with a old lsi HBA connected to two netapp ds4346 disk boxes. Each holds 24x 4tb sas drives. I have a total of 48x 4tb drives in zfs and I want to stay with true nas core… however since i cant properly shut down the vm from proxmox its problematic and scale is def going to corrupt it. Using scale I have thousands of io errors within seconds. Using core its been stable for years without any (though i have had to replace the occasional drive over the years) …
The old guides for installing qemu guest agent were simple but do not work on core any longer.
I appreciate any input. Thank you and Happy New years!
@Clayton_Mileto I got this working with the creator of the script.
