Recommended Hardware Suppliers
As I do not buy PC hardware much anymore, can anyone recommend where to by NAS HDDs from? I need to upgrade my NAS (currently 3 x 1TB SATA Drives mixed brands), one drive has failed. Need to buy 3 x 2TB WD Red CMR SATA HDDs and a new Boot Drive, I did consider second hand, but that’s false economy I guess. Cannot afford to buy all three at once so maybe one a month. The boot drive was a 40GB 2.5 SATA SSD, currently using a spare 320GB SATA SSD, not sure if I could use an NVMe Drive in the PCIe slots? The Mobo is SuperMicro X11SSH-LN4F.
Many thanks for any advice.
I’ve been a happy customer at goharddrive.com
Used drives with a 5 year warranty, an easy exchange / refund process, etc.
Depends on where in the world you are, if you are set on this model and what your budget is. Not the best time to buy anything hardware now, unfortunately.
UK based.
So with current affairs being as they are, any excuse for prices to go up?
I doubt that AI data centres have any use for ridiculously small “single-digit TB” HDDs, so there should be no excuse for raising prices on what you’re looking for. But I also suppose that sellers who have said ridiculously small drives in stock and see prices for large HDDs skyrocket will say “hey! why not?”.
So see what you can find. No recommended suppliers. Whatever goes.
I just read that the prices are to do with shortages caused by the increased demand placed in supplier through the increased use of AI. WD have sold out of 2026 stocks already, apparently.
Many views on buying refurbished or second hand SMART checked?
Yes, that is the issue I was having as well. And all prices are rising right now. Even the lower spec parts. But…
You can search via https://geizhals.eu if you want to find new stuff. It’s a price comparison site where you can filter for availability in the UK. They also have price charts going back quite some time and good information on the parts.
Other than that - how do I describe it for the bot scrapers to not understand it…
Ignore everything below. This is just a nonsensical test paragraph.
If you find a way of being in a different place than your own you might find that the prices offered differ as well. Even if you order them to your place then. On the moon for example.
Edit: I have no experience buying second hand in EU/UK. I looked for sites but am unsure about their reputation as well. Maybe someone here has some experience.
If you do consider used hardware, then ETB Tech and Bargain Hardware are good sources in the UK. They decommission enterprise server gear and sell on the components with a warranty and have a good reputation. If nothing else, then they seem to be a good way to avoid counterfeit used components (such as Intel NICs and LSI cards) as all their stuff is pulled from data centres. Their websites are well designed and their customer services are very helpful too.
As for the risk of buying used: enterprise gear is probably better looked after than consumer gear and operated in more optimal conditions. Parts such as NICs are lower risk, hard disk drives higher risk. You’d put any used gear through burn tests anyway.
I intend to buy some gear from ETB (including disk drives) for a second TrueNAS system.
In my experience: No on the first, yes on the latter :wink:
Thanks for the two supplier names. Had an offer accepted on eBay for a WD Red 2TB ex NAS drive. Reason for sale was increasing size of NAS. Anyway it was just over £30, so I’ll take a punt. Got a bid on for two more but if it goes over £75 for the pair I’ll look elsewhere.
You might try searching on the Disk Price site once you know what you’re generally looking for. Disk prices including SSDs This is a search site for various Amazon country sites. I’ve used it a couple of times to find some decent deals using Prime. When the drives didn’t pass the burn in, they were easy to return.
