Relocate Dataset from pool:bunker -> pool:tank
hi guys.
ok, so there is the create a new dataset on the pool:tank option and then either mv or cp -a the data…
guessing all client consumers will need to be reconfigured.
but, question, is there a way to move/copy the dataset and data to a new pool without needing to reconfigure… guess it will ask does the apps refer to the mount point or the dataset name.
the pool:bunker is to be destroyed, disk replaced and new disk will be added to pool:tank.
G
If you rename ‘tank’ to ‘bunker’, shares and apps should fall back on their feet.
