I received two 6TB WD Red plus drives to replace two existing WD Black drives to increase my storage capacity. I’ll be replacing two WD 1TB Black drives. These will be mirrored along with two existing WD Red drives for a total capacity of 8TB.
I just got my server up and running after my USB mirrored boot drive failed running FreeNas 9.3. The import did not go smooth so I’m being very cautious doing this replacement. What is the best and safest way to install these drives?
I ventured forward, read the documentation on replacing drives and got an error saying it can’t find the drives. First it didn’t copy the serial number over to the replace drive screen so I did a cut and paste. Then I got an error that it couldn’t find the drives.
I don’t know what you mean when you said “Please paste the results back using Preformatted Text (</>) on toolbar.” I hope this is OK.
truenas_admin@truenas[~]$ sudo zpool status -v
[sudo] password for truenas_admin:
pool: Volume1
state: ONLINE
action: Enable all features using ‘zpool upgrade’. Once this is done,
scan: scrub repaired 0B in 03:39:42 with 0 errors on Sun Sep 28 03:39:44 2025
Do you have the new disk or disks connected and powered on? They have to be attached and powered on to see them on those screens.
If you can’t attach all the disks at one, you would need to offline a WD Black that you are replacing, power off the server, replace that ‘offline’ drive with a new WD replacement and power back on. Make sure you are replacing the correct hard drive by serial numbers.
You would then chose to replace the ‘offline’ drive with the new WD drive in the GUI. It will take a bit as it resilvers the data. Once you confirm it is done, then you repeat the same procedure in replacing the other, old WD Black drive.
It’s on the toolbar when you type out replies. See top, middle section of screenshot. It is also refered to as posting it as Code format, sometimes. The forum does wierd things trying to autoformat, otherwise.
There lies the issue. I only have 4 bays for storage. When I try to replace the disk, I can’t see anything in the drop down window When I copy and paste the serial number, it still says “Disk Not Found”.
Maybe I’m not putting in the right info. Where it says “Member Disk *” what is it looking for?
That is the right spot. Write down the serial number of the drive (in your screenshot WD-WCATRC094645). Make sure the drive you are taking out of the system has a matching serial number.
OK, I placed the disk offline I intend to replace and got unexpected results. After placing the disc offline, shutting down the computer and replacing the drive, I expected it to automatically start to resilver once rebooted but that is not what happened. It came back saying the vdev is degraded and there is 1 unused disk.
I believe you want to choose the offline disk and then choose the Replace button on the lower right of the GUI. Then you choose the new disk you just inserted. I just mocked up a screenshot in a VM
