Replication tasks - nested vs direct
I’m working on some replications to backup datasets to a dedicated backup pool. The data in question is nextcloud but this isn’t specific to the next cloud app.
My current structure is:
ssdpool
   apps
     nextcloud
      db
      html
datapool
   apps
     nextcloud
      data
backupspool
    apps
      nextcloud
       data
       db
       html
I have 2 replication tasks:
1 - Replicates both /mnt/ssdpool/apps/nextcloud/db and /mnt/ssdpool/apps/nextcloud/html to /mnt/backuppool/apps/nextcloud/
2 - Replicates /mnt/datapool/apps/nextcloud/data to /mnt/backuppool/apps/nextcloud/
The problem I have is they behave differently. Replication number 1 will copy the datasets selected to identical ones underneath the “nextcloud” dataset on the backup pool. This is what I expect to happen.
Replication number 2 however, will copy the contents of the data dataset directly into the nextcloud dataset, it doesn’t create the new dataset as a child. This completely breaks the directory structure.
My questions are - why is the behaviour different, and how do I override it so that it works consistently?
Also as an aside, for the love of everything can we please change it so that removing a dataset doesn’t delete every single sync job associated with it, i’m tired of having to recreate every single replication job just because zfs replication fucked up the datasets
Within the replication wizard once you have selected the destination /mnt/backuppool/apps/nextcloud/ simply type the name of the new dataset after the path like this /mnt/backuppool/apps/nextcloud/somenewdataset and it will auto create the new dataset for the replication to land.
Not sure I understand this.
It depends if you have one dataset, or multiple selected.
With multiple, the datasets are replicated into the destination dataset.
With a single, the contents are.
Yes…. I don’t think its ideal. Rsync solves a similar problem by allowing the destination to have a trailing /
