Rsync Issue on truenas scale
Hello all
I have truenas scale running on a Proxmox VM and all is working fine thank you.
I also have a second server running only truenas scale
all servers are up to date and are configured identically including credentials
I use Rsync to do all my backup and it works with the exception of the following
a every time i run a backup scenario for any of my datasets the backup shows running and the jobs icon confirms.
When the job icon shows the task completed the state column in the rsyncs tasks windows the task still shows as running (and will remain in this state for a while) until i click on it the the task status turn to complete.
B) As mentioned all my datasets on a server are configure identically and replicate on the other server.
All Datasets are being backup with no issues , with the exception of one.
For this dataset i need to go to the credentials (on both server) for that dataset open them and then save the credentials (with no changes) .
when i run the rsync task again it works
Thank you for any suggestion
I would like to point out that
