Rsync Task with Hetzner Storage-Box
I am having problems getting a rsync task running with the Hetzner Storage Box.
What I already did:
  1. I created an SSH Keypair in the shell and transferred it to the storage box. The login without password works. I used the private key to create the SSH Keypair under Backup credentials
  2. Afterwards I created a SSH connection with this key pair. It was possible to discover the Remote Host Key
  3. The I created the Rsync task with the following settings:
But as soon as I click on “Save” I get the following error message:
I tried several host paths:
/home/backup
backup/
./backup
But none of them worked.
If I uncheck the “Validate Remote Path’ I get the following error message:
“cannot access local variable ‘known_hosts’ where it is not associated with a value”
Do you have any idea what I am making wrong?
I am using the version “25.10.0.1 - Goldeye”
Best regards
With the first option (Validate Remote Directory) the middlewared.log reports:
[2025/12/02 06:06:51] (INFO) asyncssh.log():92 - Opening SSH connection to u513491.your-storagebox.de, port 23
[2025/12/02 06:06:51] (INFO) asyncssh.log():92 - [conn=7] Connected to SSH server at u513491.your-storagebox.de, port 23
[2025/12/02 06:06:51] (INFO) asyncssh.log():92 - [conn=7] Local address: 192.168.3.4, port 54970
[2025/12/02 06:06:51] (INFO) asyncssh.log():92 - [conn=7] Peer address: 167.235.97.35, port 23
[2025/12/02 06:06:51] (DEBUG) asyncssh.log():92 - [conn=7] Sending version SSH-2.0-AsyncSSH_2.10.1
[2025/12/02 06:06:51] (DEBUG) asyncssh.log():92 - [conn=7] Received version SSH-2.0-OpenSSH_9.6p1 Ubuntu-3ubuntu13.14
[2025/12/02 06:06:51] (DEBUG) asyncssh.log():92 - [conn=7] Requesting key exchange
[2025/12/02 06:06:51] (DEBUG) asyncssh.log():92 - [conn=7] Received key exchange request
[2025/12/02 06:06:51] (DEBUG) asyncssh.log():92 - [conn=7] Beginning key exchange
[2025/12/02 06:06:51] (DEBUG) asyncssh.log():92 - [conn=7] Completed key exchange
[2025/12/02 06:06:51] (INFO) asyncssh.log():92 - [conn=7] Beginning auth for user u513491
[2025/12/02 06:06:51] (DEBUG) asyncssh.log():92 - [conn=7] Trying public key auth with rsa-sha2-256 key
[2025/12/02 06:06:52] (DEBUG) asyncssh.log():92 - [conn=7] Signing request with rsa-sha2-256 key
[2025/12/02 06:06:52] (INFO) asyncssh.log():92 - [conn=7] Auth for user u513491 succeeded
[2025/12/02 06:06:52] (DEBUG) asyncssh.log():92 - [conn=7, chan=0] Set write buffer limits: low-water=16384, high-water=65536
[2025/12/02 06:06:52] (INFO) asyncssh.log():92 - [conn=7, chan=0] Requesting new SSH session
[2025/12/02 06:06:52] (DEBUG) asyncssh.log():92 - [conn=7] Received unknown global request: hostkeys-00@openssh.com
[2025/12/02 06:06:52] (DEBUG) asyncssh.log():92 - [conn=7] Received debug message: /backup/account_chroots/u513491/home/.ssh/authorized_keys:1: key options: agent-forwarding port-forwarding pty user-rc x11-forwarding
[2025/12/02 06:06:52] (INFO) asyncssh.log():92 - [conn=7, chan=0] Command: test -d backup2/
[2025/12/02 06:06:52] (INFO) asyncssh.log():92 - [conn=7, chan=0] Received exit status 8
[2025/12/02 06:06:52] (INFO) asyncssh.log():92 - [conn=7, chan=0] Received channel close
[2025/12/02 06:06:52] (INFO) asyncssh.log():92 - [conn=7, chan=0] Channel closed
[2025/12/02 06:06:52] (INFO) asyncssh.log():92 - [conn=7] Closing connection
[2025/12/02 06:06:52] (INFO) asyncssh.log():92 - [conn=7] Sending disconnect: Disconnected by application (11)
[2025/12/02 06:06:52] (INFO) asyncssh.log():92 - [conn=7] Connection closed
When I uncheck the option I get the following log:
Ohne validate:
[2025/12/02 06:08:37] (WARNING) middlewared.process_method_call():394 - Exception while calling rsynctask.create(*[{'path': '/mnt/nvme/storage', 'user': 'truenas_admin', 'mode': 'SSH', 'remotehost': None, 'remoteport': None, 'ssh_credentials': 4, 'remotepath': 'backup', 'direction': 'PUSH', 'desc': 'Test', 'schedule': {'minute': '0', 'hour': '0', 'dom': '*', 'month': '*', 'dow': '*'}, 'recursive': True, 'times': True, 'compress': True, 'archive': False, 'delete': False, 'quiet': False, 'preserveperm': False, 'preserveattr': False, 'delayupdates': True, 'extra': [], 'enabled': True, 'validate_rpath': False}]) @cee:{"TNLOG": {"exception": "Traceback (most recent call last):\n  File \"/usr/lib/python3/dist-packages/middlewared/api/base/server/ws_handler/rpc.py\", line 360, in process_method_call\n    result = await method.call(app, id_, params)\n             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/usr/lib/python3/dist-packages/middlewared/api/base/server/method.py\", line 57, in call\n    result = await self.middleware.call_with_audit(self.name, self.serviceobj, methodobj, params, app,\n             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/usr/lib/python3/dist-packages/middlewared/main.py\", line 954, in call_with_audit\n    result = await self._call(method, serviceobj, methodobj, params, app=app,\n             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/usr/lib/python3/dist-packages/middlewared/main.py\", line 771, in _call\n    return await methodobj(*prepared_call.args)\n           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/usr/lib/python3/dist-packages/middlewared/service/crud_service.py\", line 176, in create\n    return await self.middleware._call(\n           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/usr/lib/python3/dist-packages/middlewared/main.py\", line 771, in _call\n    return await methodobj(*prepared_call.args)\n           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/usr/lib/python3/dist-packages/middlewared/service/crud_service.py\", line 214, in nf\n    rv = await func(*args, **kwargs)\n         ^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py\", line 108, in wrapped\n    result = await func(*args)\n             ^^^^^^^^^^^^^^^^^\n  File \"/usr/lib/python3/dist-packages/middlewared/plugins/rsync.py\", line 370, in do_create\n    verrors, data = await self.validate_rsync_task(data, 'rsync_task_create')\n                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/usr/lib/python3/dist-packages/middlewared/plugins/rsync.py\", line 353, in validate_rsync_task\n    if not known_hosts.match(connect_kwargs['host'], '', None)[0]:\n           ^^^^^^^^^^^\nUnboundLocalError: cannot access local variable 'known_hosts' where it is not associated with a value", "type": "PYTHON_EXCEPTION", "time": "2025-12-02 05:08:37.571845"}}
This means the process checks if in the home directory of the logged in user a subdirectory named backup2 exists. Apparently it does not so the exit status is != 0.
HTH,
Patrick
I have rsync working fine with storage box if you want to compare settings. Heres my config:
Note the folder matches the path folder, in my case “Vault”
Hello @Pross,
I tried the same setting - but I get the same error message as before.
Do you also have version 25.10.2.1?
Best regards,
Hello pmh,
That was one try with a non existing folder.
I get the same error message, wenn I use an existing folder.
For example:
Path after login is /home
I created the folder backup. But none of the following paths is working:
backup, /home/backup, backup/, ./backup
Best regards,
No, im using 24.4 here.
if your folder locally is for example /mnt/nvme/storage then the remote folder would be storage thats what works for me, mine is /mnt/ssd-2tb/Vault and for remote I add Vault.
Hello @Pross,
I tried that also with folder storage. But the error message is the same.
Best regards,
Cant help then, sorry about that.
Hello all,
now I am sure, that this is an issue with version “25.10.0.1 - Goldeye”.
I installed the version “25.04.2.6” on a PROXMOX host. With the same settings I made in the newest version, the rsync job could be configured and also runs without any problem.
The only difference is that I can only use virtual disks for the share as I have no free physical disks in this Proxmox server.
What is the best way to communicate this issue?
Best regards,
Christian
Hi all,
How can I rise this error?
Best regards
I have the exact same problem here. Tried everything told in this topic, nothing is working.
I am also on truenas 25.10.0.1 and trying to backup to Hetzner storage box.
Edit: I have been able to make it “work” with a workaround, not by using a rsync task but with a SFTP Cloud Sync Task. Not really ideal, i would have prefer rsync to work …
I think this is an issue with 25.10.01.
As this is only a test installation I will install version 25.04. I think there will be more issues with the new release so I prefer the previous stable version.
i would report this issue - but I don‘t know how.
Best regards,
Christian
There is also a Report a Bug link to Jira at the top of this page.
Exactly the same thing here!
Anyone else?
The problem with “Validate Remote Path” and the executed command “test -d /home/backup-nas” is that a Hetzner Storage-Box doesn’t have the command test. That’s why I get this message:
”Connection to Remote Host was successful but failed to verify Remote Path. Process exited with non-zero exit status 8”
Running the command manually on the server results in:
u###### /home/backup-nas > test -d /home/backup-nas
Command not found. Use ‘help’ to get a list of available commands.
Using “help” on the shell via ssh shows only these commands:
u###### /home/backup-nas > help
| The following commands are available: |
| ls|ll list directory content |
| tree list directory content |
| cd change current working directory |
| pwd show current working directory |
| mkdir create new directory |
| rmdir delete directory |
| du disk usage of files/directories |
| df show disk usage |
| dd read and write files |
| cat output file content |
| touch create new file |
| cp copy files/directories |
| rm delete files/directories |
| unlink delete file/directory |
| mv move files/directories |
| chmod change file/directory permissions |
| md5|sha1|sha256|sha512 create hash sum of file |
| md5sum|sha1sum|sha256sum|sha512sum create hash sum of file |
| head show first lines of file |
| tail show last lines of file |
| grep search for specific string in files |
| stat stat files/directory |
| version show version of this SSH environment |
| Available as server side backend: |
| borg |
| rsync |
| scp |
| sftp |
| rclone serve restic --stdio |
| Please note that this is only a restricted shell which do not |
| support shell features like redirects or pipes. |
| You can find more information in our Docs: |
| cant post links |
Unchecking “Validate Remote Path” results in an error that is unclear to me.
”Host key not found in /var/empty/.ssh/known_hosts”
In the middleware.log nothing is added. It seems as if no connection is opened at all.
My config is:
Path: /mnt/Shares
Rsync mode: SSH
Connect using: SSH connection from the keychain
User: backupshare
SSH Connection: Hetzner Backup
Direction: Push
Remote Path: /home/backup-nas
Schedule: Weekly
Rest unchanged
I think I’m having this exact problem. A direct ssh session works, but with an rsync task in truenas I get: Connection to Remote Host was successful but failed to verify Remote Path. Process exited with non-zero exit status 8
When I un-tic validate the error is “Host key not found in /mnt/tank/homes//.ssh/known_hosts“ (where I have put it using ssh-scan)
Any help with this would be appricated.
Also a confirmation as to how the remote-dir should work would be helpful as well: does is create the folders on the fly?
To add to this: the hetzner documented rsync through cli works fine when directly running from the user home:
rsync --progress -e ‘ssh -p23’ --recursive test-hetzner-backup uxxx@xxx.your-storagebox.de:test-hetzner-backup
Following, im using webdav for now which seems to work for now, they must have changed something as rsync was working when I tried it in Dec
Same issue here. I managed to set up a some backup jobs a few months ago, and now I can’t create new ones. Can’t even change the schedule of the existing ones.
Did anyone create a ticket in Jira for this? A quick search didn’t give me anything.
