Sata pcie replacement to HBA
hi there
im not much more about nas just have a basic knowledge in truenas world. i build this server running for a year with an ordinary pcie sata a non HBA card, now i decided to replaced a real HBA card do i need to detached first the drives which part of the existing sata pcie or replaced without any configuration?
my NAS specs
gigabyte b550m ds3h
amd ryzen 5 5600g
64gig ram
1 nvme boot os drive
8 hdd 2tb each
silverstone nas casing
thanks
As long as your sata multiplier wasn’t doing too much sketchy stuff, moving to an HBA should basically be plug & play. TrueNAS doesn’t care how the drives are connected (simplification; unless something is critical wrong with existing setup) - it should be as simple as moving the drives from the port multiple to the HBA.
Note that the OP has not mentioned a port multiplier and not all SATA cards are disasters in waiting…
Still the replacement should be a plug and play exercise.
…if it is flashed to IT mode…
Actually not. ZFS does not care about ports or controlers, so replacing would equally work with an HBA on IR firmware, a RAID controller, or another SATA card.
But for safe functioning later on, you want a HBA on the latest IT or IR firmware—emphasis on LATEST.
see circa 2018
Jokes about how fresh firmware releases are aside, he is 100% correct.
Indeed, we may just say “LAST” firmware.
