Setting up TrueNAS Scale
I had an earlier version of TrueNAS installed on an old server but recently decided to try the TrueNAS Scale version. Installation went well and am able to remote into the Dashboard but in setting up the storage, I seem to be running into some bit of a problem that I don’t recall on the earlier version.
I go into “Storage” and start to Create Pool but when I get to Step 2: Data it seems there is nothing there to select as far as VDEV go. I base this on some of the videos that I have seen in trying to figure out where I have gone wrong.
Any assistance would be greatly appreciated.
Thank you,
BGunn
I’m not sure I’m quite following your explanation, but you need to select a Layout first for the other options to populate.
Did you change any hardware?
If not, you presumably still have the same storage drives as you did when you ran the earlier version of TrueNAS.
Do you want to retain the data stored to those drives or do you want to remove it all and start from scratch with a completely new and empty pool?
It would be useful to know more about the hardware used, please share any details you can.
