Setting up vim
I tried to improve vim, but I have a problem with the vimrc file. I get an error when adding the syntax on line:
Sorry, the command is not available in this version: syntax on. I’m wondering what else can’t be configured and why this was done?
“vim --version” will let you know what’s not configured.
The answer to the “why” question is that the package installed is vim-tiny, which does not have the syntax mode built in.
Thank you for your response
This is understandable. Is it possible to upgrade to a full-fledged vim?
You can, if you are willing to take on the responsibilities that go with developer mode.
Details here:
Make sure you note the caveat mentioned there that you will not be able to receive support on any issues submitted to iXsystems once you’ve activated developer mode.
