Simple guide how to install TrueNas?
Hi guys,
a info, but a simple guide on how to install TrueNas Scale?
How do I format ssd?
I have already downloaded the file on Mac and connected ssd bx100 crucial 250gb with external dock, so as to prepare it with the mac and then insert it into the server
Thanks a lot
You download the iso, flash the iso to an USB install stick using etcher or Rufus, stick the USB stick in your Truenas box, start the box, choose to boot from USB and then follow the installer
Edit: Here’s the official documentation
solved thanks
also changed session timeout up to 24 days, and blocked ip in the router making it static with assigned mac andress (for now different from the one marked in truenas, but I think that after reboot it will update)
then I will try to create a restore point ssd boot or backup on another ssd.
I also have to create a system of turning on and off the server at pre-set times, and try to change the admin name and the assigned hdd pool
