(update - I think I nailed it down to 25gb card - see below)
Hey All, for the first time that I can remember…I’m a little stumped about getting some slow SMB speeds off a fresh bare metal install. Is anything jumping out to you all? I’m remotely troubleshooting this one - right now this Mac is the only 10gbe connected device but I should have a 10gbe Windows machine online in a little bit to test. I know Macs can be a little funky - but never really had any issues until now! As always - appreciate any insight on this one!
System & Network Specs
TrueNAS SCALE
- Hardware:
- AMD EPYC 8324P (32 cores)
- ~250 GiB ECC RAM
- Version: ElectricEel‐24.10.2
- Storage Pool:
- Layout: 3× RAIDZ1 VDEVs (15 spinning disks total)
- ~196 TiB usable; ~36 TiB used
- Network:
- NIC: 25 GbE - connected via DAC to Switch
- MTU: 9000 (Jumbo Frames)
- Verified link speed: 25 Gb/s full duplex (
cat /sys/class/net/.../speed) - 01:00.1 Ethernet controller [0200]: Mellanox Technologies MT27800 Family [ConnectX-5] [15b3:1017]
Subsystem: Mellanox Technologies ConnectX-5 EN network interface card, 10/25GbE dual-port SFP28, PCIe3.0 x8, tall bracket ; MCX512A-ACAT [15b3:0020]
Kernel driver in use: mlx5_core
Kernel modules: mlx5_core
- Hardware:
Switch:
- Ubiquiti UniFi USW Enterprise XG 24
- 25 Gb SFP28 port → TrueNAS
- 10 Gbe → Mac
- Jumbo Frames, Flow Control toggled on/off in different tests
- Firmware version not explicitly stated, but reboots performed
Mac Client - Mac Studio M1 Ultra w/ Sonoma MacOS 15.1
- NIC: 10 GbE, manually set to 10Gbase‐T, full duplex, MTU 9000
- Flow Control: auto‐negotiated on the Mac, shown in
ifconfig - SMB signing: disabled via
/etc/nsmb.conf - macOS: Using AJA System Test, iperf3, etc. for throughput tests
Pool and Datasets Overview
- Pool Name:
tank- Layout: 3 × RAIDZ1 VDEVs (5 disks each, total 15 HDD)
- Usable Capacity: ~196 TiB
- Used: ~36.19 TiB (~18.5%)
- Encryption: Unencrypted
- ZFS Dedupe: OFF
Performance Tests
iPerf3 Single‐Stream
- Forward (Mac → TrueNAS): ~6–7 Gbits/s
- Reverse (TrueNAS → Mac): ~2–3 Gbits/s initially, with occasional stalls or heavy retransmissions
iPerf3 Multi‐Stream (-P 4)
- Forward: Often ~9.7–9.8 Gbits/s (close to saturating the Mac’s 10 Gb link)
- Reverse: Ranged from stalling at 2–3 Gbits/s to ~6–7 Gbits/s, but with thousands of TCP retransmissions. Reboots and toggling settings sometimes improved or worsened it.
Jumbo Frames & Flow Control Toggling
- Jumbo On, Flow Control On: Forward ~9.7 Gb/s, reverse stalling or ~2–3 Gb/s
- Jumbo Off (MTU=1500), Flow Control Off: Reverse ~3.9 Gb/s
- Re‐enabled Jumbo: Reverse improved to ~6–6.5 Gb/s but still with high retransmissions
- In all scenarios, forward direction is near 9–10 Gb/s, reverse direction is lower
SMB / AJA Tests (macOS)
- AJA System Test saw ~500 MB/s writes, ~300 MB/s reads to SMB share.
Write speed (to me) seems expected - but I def should be getting full 10gbe speeds with the setup - I’ve set this up a quite a few times like this before (same exact systems as well) with no issues.
