Summary of smartctl output
Linux FreeNAS 6.6.44-production+truenas #1 SMP PREEMPT_DYNAMIC Tue Jan 28 03:14:06 UTC 2025 x86_64
TrueNAS (c) 2009-2025, iXsystems, Inc.
All rights reserved.
TrueNAS code is released under the LGPLv3 and GPLv3 licenses with some
source files copyrighted by (c) iXsystems, Inc. All other components
are released under their own respective licenses.
For more information, documentation, help or support, go here:
http://truenas.com
Warning: the supported mechanisms for making configuration changes
are the TrueNAS WebUI, CLI, and API exclusively. ALL OTHERS ARE
NOT SUPPORTED AND WILL RESULT IN UNDEFINED BEHAVIOR AND MAY
RESULT IN SYSTEM FAILURE.
Welcome to FreeNAS
Last login: Wed Jan 29 14:33:46 EST 2025 on pts/12
root@FreeNAS[~]# smartctl --scan
/dev/sda -d scsi # /dev/sda, SCSI device
/dev/sdb -d scsi # /dev/sdb, SCSI device
/dev/sdc -d scsi # /dev/sdc, SCSI device
/dev/sdd -d scsi # /dev/sdd, SCSI device
/dev/sde -d scsi # /dev/sde, SCSI device
/dev/sdf -d scsi # /dev/sdf, SCSI device
/dev/sdg -d scsi # /dev/sdg, SCSI device
/dev/sdh -d scsi # /dev/sdh, SCSI device
/dev/sdi -d scsi # /dev/sdi, SCSI device
/dev/sdj -d scsi # /dev/sdj, SCSI device
/dev/sdk -d scsi # /dev/sdk, SCSI device
root@FreeNAS[~]# smartctl -x /dev/sde
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.44-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate Exos X16
Device Model: ST16000NM001G-2KK103
Serial Number: ZL20JQQ3
LU WWN Device Id: 5 000c50 0c2a60766
Firmware Version: SN02
User Capacity: 16,000,900,661,248 bytes [16.0 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database 7.3/5653
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Feb 11 16:54:50 2025 EST
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Disabled
ATA Security is: Disabled, NOT FROZEN [SEC1]
Write SCT (Get) Feature Control Command failed: scsi error unsupported field in scsi command
Wt Cache Reorder: Unknown (SCT Feature Control command failed)
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Self-test execution status: ( 36) The self-test routine was interrupted
by the host with a hard or soft reset.
data collection: ( 567) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1447) minutes.
Conveyance self-test routine
SCT capabilities: (0x70bd) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-- 074 064 044 - 25950832
3 Spin_Up_Time PO---- 090 089 000 - 0
4 Start_Stop_Count -O–CK 100 100 020 - 62
5 Reallocated_Sector_Ct PO–CK 100 100 010 - 0
7 Seek_Error_Rate POSR-- 076 060 045 - 37438557
9 Power_On_Hours -O–CK 050 050 000 - 43924
10 Spin_Retry_Count PO–C- 100 100 097 - 0
12 Power_Cycle_Count -O–CK 100 100 020 - 62
18 Head_Health PO-R-- 100 100 050 - 0
187 Reported_Uncorrect -O–CK 100 100 000 - 0
188 Command_Timeout -O–CK 100 100 000 - 0
190 Airflow_Temperature_Cel -O—K 070 059 040 - 30 (Min/Max 21/33)
192 Power-Off_Retract_Count -O–CK 100 100 000 - 60
193 Load_Cycle_Count -O–CK 081 081 000 - 38973
194 Temperature_Celsius -O—K 030 040 000 - 30 (0 20 0 0 0)
197 Current_Pending_Sector -O–C- 100 100 000 - 0
198 Offline_Uncorrectable ----C- 100 100 000 - 0
199 UDMA_CRC_Error_Count -OSRCK 200 200 000 - 0
200 Pressure_Limit PO—K 100 100 001 - 0
240 Head_Flying_Hours ------ 100 253 000 - 41383h+48m+18.121s
241 Total_LBAs_Written ------ 100 253 000 - 133410024624
242 Total_LBAs_Read ------ 100 253 000 - 1160643575130
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 5 Ext. Comprehensive SMART error log
0x04 GPL R/O 256 Device Statistics log
0x04 SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x08 GPL R/O 2 Power Conditions log
0x09 SL R/W 1 Selective self-test log
0x0a GPL R/W 8 Device Statistics Notification
0x0c GPL R/O 2048 Pending Defects log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x13 GPL R/O 1 SATA NCQ Send and Receive log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x24 GPL R/O 768 Current Device Internal Status Data log
0x2f GPL R/O 1 Set Sector Configuration
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa1 GPL,SL VS 160 Device vendor specific log
0xa2 GPL VS 16320 Device vendor specific log
0xa4 GPL,SL VS 160 Device vendor specific log
0xa6 GPL VS 192 Device vendor specific log
0xa8-0xa9 GPL,SL VS 136 Device vendor specific log
0xab GPL VS 1 Device vendor specific log
0xad GPL VS 16 Device vendor specific log
0xbe-0xbf GPL VS 65535 Device vendor specific log
0xc1 GPL,SL VS 8 Device vendor specific log
0xc3 GPL,SL VS 56 Device vendor specific log
0xc7 GPL,SL VS 8 Device vendor specific log
0xc9 GPL,SL VS 8 Device vendor specific log
0xca GPL,SL VS 16 Device vendor specific log
0xcd GPL,SL VS 1 Device vendor specific log
0xce GPL VS 1 Device vendor specific log
0xcf GPL VS 512 Device vendor specific log
0xd1 GPL VS 656 Device vendor specific log
0xd2 GPL VS 10000 Device vendor specific log
0xd4 GPL VS 2048 Device vendor specific log
0xda GPL,SL VS 1 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
0xe2 GPL,SL - 160 Reserved
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
1 Extended offline Interrupted (host reset) 40% 43852 -
2 Short offline Completed without error 00% 43766 -
3 Extended offline Completed without error 00% 43698 -
4 Short offline Completed without error 00% 43526 -
5 Extended offline Interrupted (host reset) 10% 43453 -
6 Short offline Completed without error 00% 43358 -
7 Short offline Completed without error 00% 43190 -
8 Extended offline Completed without error 00% 43118 -
9 Short offline Completed without error 00% 43022 -
#10 Short offline Completed without error 00% 42782 -
#11 Extended offline Completed without error 00% 42709 -
#12 Short offline Completed without error 00% 42614 -
#13 Short offline Completed without error 00% 42446 -
#14 Extended offline Completed without error 00% 42373 -
#15 Short offline Completed without error 00% 42278 -
#16 Short offline Completed without error 00% 42062 -
#17 Extended offline Completed without error 00% 41989 -
#18 Short offline Completed without error 00% 41894 -
#19 Short offline Completed without error 00% 41726 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 522 (0x020a)
Device State: Active (0)
Current Temperature: 30 Celsius
Power Cycle Min/Max Temperature: 20/33 Celsius
Lifetime Min/Max Temperature: 20/41 Celsius
Under/Over Temperature Limit Count: 0/0
SMART Status: 0xc24f (PASSED)
Vendor specific:
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version: 2
Temperature Sampling Period: 4 minutes
Temperature Logging Interval: 59 minutes
Min/Max recommended Temperature: 10/40 Celsius
Min/Max Temperature Limit: 5/60 Celsius
Temperature History Size (Index): 128 (16)
Index Estimated Time Temperature Celsius
17 2025-02-06 11:17 30 ***********
… ..( 41 skipped). .. ***********
59 2025-02-08 04:35 30 ***********
60 2025-02-08 05:34 32 *************
61 2025-02-08 06:33 33 **************
62 2025-02-08 07:32 32 *************
63 2025-02-08 08:31 32 *************
64 2025-02-08 09:30 33 **************
65 2025-02-08 10:29 33 **************
66 2025-02-08 11:28 32 *************
67 2025-02-08 12:27 33 **************
68 2025-02-08 13:26 33 **************
69 2025-02-08 14:25 33 **************
70 2025-02-08 15:24 32 *************
71 2025-02-08 16:23 32 *************
72 2025-02-08 17:22 32 *************
73 2025-02-08 18:21 30 ***********
74 2025-02-08 19:20 31 ************
… ..( 4 skipped). .. ************
79 2025-02-09 00:15 31 ************
80 2025-02-09 01:14 30 ***********
… ..( 33 skipped). .. ***********
114 2025-02-10 10:40 30 ***********
115 2025-02-10 11:39 29 **********
116 2025-02-10 12:38 30 ***********
… ..( 2 skipped). .. ***********
119 2025-02-10 15:35 30 ***********
120 2025-02-10 16:34 29 **********
121 2025-02-10 17:33 30 ***********
… ..( 15 skipped). .. ***********
9 2025-02-11 09:17 30 ***********
10 2025-02-11 10:16 31 ************
11 2025-02-11 11:15 30 ***********
16 2025-02-11 16:10 30 ***********
SCT Error Recovery Control:
Read: 100 (10.0 seconds)
Write: 100 (10.0 seconds)
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 1) ==
0x01 0x008 4 62 — Lifetime Power-On Resets
0x01 0x010 4 43924 — Power-on Hours
0x01 0x018 6 133397915608 — Logical Sectors Written
0x01 0x020 6 2529902345 — Number of Write Commands
0x01 0x028 6 1160354637882 — Logical Sectors Read
0x01 0x030 6 5263688199 — Number of Read Commands
0x01 0x038 6 - — Date and Time TimeStamp
0x03 ===== = = === == Rotating Media Statistics (rev 1) ==
0x03 0x008 4 43918 — Spindle Motor Power-on Hours
0x03 0x010 4 43455 — Head Flying Hours
0x03 0x018 4 38973 — Head Load Events
0x03 0x020 4 0 — Number of Reallocated Logical Sectors
0x03 0x028 4 0 — Read Recovery Attempts
0x03 0x030 4 0 — Number of Mechanical Start Failures
0x03 0x038 4 0 — Number of Realloc. Candidate Logical Sectors
0x03 0x040 4 60 — Number of High Priority Unload Events
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 0 — Number of Reported Uncorrectable Errors
0x04 0x010 4 0 — Resets Between Cmd Acceptance and Completion
0x04 0x018 4 0 -D- Physical Element Status Changed
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 30 — Current Temperature
0x05 0x010 1 29 — Average Short Term Temperature
0x05 0x018 1 25 — Average Long Term Temperature
0x05 0x020 1 37 — Highest Temperature
0x05 0x028 1 20 — Lowest Temperature
0x05 0x030 1 35 — Highest Average Short Term Temperature
0x05 0x038 1 21 — Lowest Average Short Term Temperature
0x05 0x040 1 31 — Highest Average Long Term Temperature
0x05 0x048 1 24 — Lowest Average Long Term Temperature
0x05 0x050 4 0 — Time in Over-Temperature
0x05 0x058 1 60 — Specified Maximum Operating Temperature
0x05 0x060 4 0 — Time in Under-Temperature
0x05 0x068 1 5 — Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 407 — Number of Hardware Resets
0x06 0x010 4 200 — Number of ASR Events
0x06 0x018 4 0 — Number of Interface CRC Errors
0xff ===== = = === == Vendor Specific Statistics (rev 1) ==
0xff 0x008 7 0 — Vendor Specific
0xff 0x010 7 0 — Vendor Specific
0xff 0x018 7 0 — Vendor Specific
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x000a 2 25 Device-to-host register FISes sent due to a COMRESET
0x0001 2 0 Command failed due to ICRC error
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
Seagate FARM log (GP Log 0xa6) supported [try: -l farm]
root@FreeNAS[~]# amartctl -x /dev/sda
zsh: command not found: amartctl
root@FreeNAS[~]# smartctl -x /dev/sda
Serial Number: ZL2034Y0
LU WWN Device Id: 5 000c50 0b586d4db
Local Time is: Tue Feb 11 16:55:14 2025 EST
been run.
data collection: ( 559) seconds.
command.
power-saving mode.
recommended polling time: (1411) minutes.
1 Raw_Read_Error_Rate POSR-- 078 064 044 - 56523144
4 Start_Stop_Count -O–CK 100 100 020 - 69
7 Seek_Error_Rate POSR-- 078 060 045 - 70303371
9 Power_On_Hours -O–CK 050 050 000 - 43998
12 Power_Cycle_Count -O–CK 100 100 020 - 69
190 Airflow_Temperature_Cel -O—K 069 061 040 - 31 (Min/Max 21/34)
192 Power-Off_Retract_Count -O–CK 100 100 000 - 62
193 Load_Cycle_Count -O–CK 081 081 000 - 39919
194 Temperature_Celsius -O—K 031 040 000 - 31 (0 21 0 0 0)
240 Head_Flying_Hours ------ 100 253 000 - 41358h+32m+30.043s
241 Total_LBAs_Written ------ 100 253 000 - 133409959447
242 Total_LBAs_Read ------ 100 253 000 - 1140938109246
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
No Errors Logged
1 Extended offline Completed without error 00% 43935 -
2 Short offline Completed without error 00% 43840 -
3 Short offline Completed without error 00% 43600 -
4 Extended offline Completed without error 00% 43527 -
5 Short offline Completed without error 00% 43432 -
6 Short offline Completed without error 00% 43264 -
7 Extended offline Completed without error 00% 43191 -
8 Short offline Completed without error 00% 43096 -
9 Short offline Completed without error 00% 42856 -
#10 Extended offline Completed without error 00% 42783 -
#11 Short offline Completed without error 00% 42688 -
#12 Short offline Completed without error 00% 42520 -
#13 Extended offline Completed without error 00% 42446 -
#14 Short offline Completed without error 00% 42362 -
#15 Short offline Completed without error 00% 42356 -
#16 Short offline Completed without error 00% 42352 -
#17 Short offline Completed without error 00% 42136 -
#18 Extended offline Completed without error 00% 42062 -
#19 Short offline Completed without error 00% 41968 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Current Temperature: 31 Celsius
Power Cycle Min/Max Temperature: 21/34 Celsius
Lifetime Min/Max Temperature: 21/39 Celsius
Vendor specific:
Temperature History Size (Index): 128 (57)
58 2025-02-06 11:17 31 ************
… ..( 28 skipped). .. ************
87 2025-02-07 15:48 31 ************
88 2025-02-07 16:47 32 *************
89 2025-02-07 17:46 31 ************
90 2025-02-07 18:45 31 ************
91 2025-02-07 19:44 31 ************
92 2025-02-07 20:43 32 *************
93 2025-02-07 21:42 31 ************
… ..( 6 skipped). .. ************
100 2025-02-08 04:35 31 ************
101 2025-02-08 05:34 34 ***************
… ..( 17 skipped). .. ***************
119 2025-02-08 23:16 34 ***************
120 2025-02-09 00:15 33 **************
121 2025-02-09 01:14 33 **************
122 2025-02-09 02:13 31 ************
… ..( 62 skipped). .. ************
57 2025-02-11 16:10 31 ************
0x01 0x008 4 69 — Lifetime Power-On Resets
0x01 0x010 4 43998 — Power-on Hours
0x01 0x018 6 133399609631 — Logical Sectors Written
0x01 0x020 6 2542269454 — Number of Write Commands
0x01 0x028 6 1140404051144 — Logical Sectors Read
0x01 0x030 6 5949614818 — Number of Read Commands
0x03 0x008 4 43942 — Spindle Motor Power-on Hours
0x03 0x010 4 43467 — Head Flying Hours
0x03 0x018 4 39919 — Head Load Events
0x03 0x040 4 62 — Number of High Priority Unload Events
0x05 0x008 1 31 — Current Temperature
0x05 0x010 1 31 — Average Short Term Temperature
0x05 0x018 1 26 — Average Long Term Temperature
0x05 0x020 1 39 — Highest Temperature
0x05 0x028 1 21 — Lowest Temperature
0x05 0x030 1 36 — Highest Average Short Term Temperature
0x05 0x038 1 22 — Lowest Average Short Term Temperature
0x05 0x040 1 32 — Highest Average Long Term Temperature
0x05 0x048 1 25 — Lowest Average Long Term Temperature
0x06 0x008 4 417 — Number of Hardware Resets
0x06 0x010 4 205 — Number of ASR Events
||__ D supports DSN
No Defects Logged
root@FreeNAS[~]# smartctl -x /dev/sdb
Serial Number: ZL204DMB
LU WWN Device Id: 5 000c50 0b5d4f497
Local Time is: Tue Feb 11 16:55:19 2025 EST
been run.
command.
power-saving mode.
recommended polling time: (1480) minutes.
1 Raw_Read_Error_Rate POSR-- 082 064 044 - 163678864
7 Seek_Error_Rate POSR-- 080 060 045 - 94198825
9 Power_On_Hours -O–CK 050 050 000 - 43997
193 Load_Cycle_Count -O–CK 081 081 000 - 39770
240 Head_Flying_Hours ------ 100 253 000 - 41367h+04m+32.187s
241 Total_LBAs_Written ------ 100 253 000 - 133420326464
242 Total_LBAs_Read ------ 100 253 000 - 1174157383235
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
No Errors Logged
1 Extended offline Completed without error 00% 43936 -
3 Short offline Completed without error 00% 43599 -
8 Short offline Completed without error 00% 43095 -
9 Short offline Completed without error 00% 42855 -
#11 Short offline Completed without error 00% 42687 -
#12 Short offline Completed without error 00% 42519 -
#13 Extended offline Completed without error 00% 42447 -
#15 Short offline Completed without error 00% 42351 -
#16 Short offline Completed without error 00% 42135 -
#17 Extended offline Completed without error 00% 42063 -
#18 Short offline Completed without error 00% 41968 -
#19 Short offline Completed without error 00% 41800 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Vendor specific:
… ..( 41 skipped). .. ************
101 2025-02-08 05:34 33 **************
… ..( 2 skipped). .. **************
104 2025-02-08 08:31 33 **************
105 2025-02-08 09:30 34 ***************
… ..( 5 skipped). .. ***************
111 2025-02-08 15:24 34 ***************
112 2025-02-08 16:23 33 **************
… ..( 9 skipped). .. **************
122 2025-02-09 02:13 33 **************
123 2025-02-09 03:12 31 ************
… ..( 31 skipped). .. ************
27 2025-02-10 10:40 31 ************
28 2025-02-10 11:39 30 ***********
29 2025-02-10 12:38 31 ************
30 2025-02-10 13:37 31 ************
31 2025-02-10 14:36 31 ************
32 2025-02-10 15:35 30 ***********
33 2025-02-10 16:34 31 ************
… ..( 23 skipped). .. ************
0x01 0x010 4 43997 — Power-on Hours
0x01 0x018 6 133408321992 — Logical Sectors Written
0x01 0x020 6 2544938211 — Number of Write Commands
0x01 0x028 6 1173781619623 — Logical Sectors Read
0x01 0x030 6 4706519305 — Number of Read Commands
0x03 0x018 4 39770 — Head Load Events
0x05 0x010 1 30 — Average Short Term Temperature
0x05 0x030 1 37 — Highest Average Short Term Temperature
0x05 0x040 1 33 — Highest Average Long Term Temperature
0x06 0x008 4 205 — Number of Hardware Resets
0x06 0x010 4 204 — Number of ASR Events
||__ D supports DSN
No Defects Logged
0x000a 2 10 Device-to-host register FISes sent due to a COMRESET
root@FreeNAS[~]#
