OK, this is the second time this has happened to me in 2 months so if it is happening to you, here’s how to fix it:
- Reinstall truenas
- Restore the config file (that I know you are making regularly)
What caused my system to get stuck on this screen, although in my opinion it shouldn’t have been the reason? I overcomplicated the network configuration—I had two interfaces with the same IP address. Booting from a USB and using cli --menu helped me resolve the issue.
truenas_admin@chaos[~]$ ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp5s0: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc mq master bond0 state UP mode DEFAULT group default qlen 1000
link/ether 24:5e:be:4b:7c:aa brd ff:ff:ff:ff:ff:ff
3: enp6s0: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc mq master bond0 state UP mode DEFAULT group default qlen 1000
link/ether 24:5e:be:4b:7c:aa brd ff:ff:ff:ff:ff:ff permaddr 24:5e:be:4b:7c:a9
4: enx00e04c688a39: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
link/ether 00:e0:4c:68:8a:39 brd ff:ff:ff:ff:ff:ff
5: bond0: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000
7: vlan20@bond0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000
8: br-013f0f940dd3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default
link/ether 02:42:2f:65:83:c6 brd ff:ff:ff:ff:ff:ff
10: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default
link/ether 02:42:1e:5c:e3:01 brd ff:ff:ff:ff:ff:ff
12: veth9dfd745@if11: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-013f0f940dd3 state UP mode DEFAULT group default
link/ether 5e:22:ee:31:0d:a3 brd ff:ff:ff:ff:ff:ff link-netnsid 0
