Some IPv6 network woes
Today my remote replication failed.
I use on the remote side a firewall rule that goes like this:
Allow all incoming form static IPv6_TrueNAS to static IPv6_TrueNAS_remote.
Worked fine for months. Now all of a sudden it fails. Strange. So I take a look at the firwall and see, TrueNAS is not using it’s in the webGUI statically applied IPv6, but some I guess privacy extension IPv6?
ifconfig shows me:
vlan51: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.0.51.13  netmask 255.255.255.0  broadcast 10.0.51.255
        inet6 fe80::XXXXXXXX  prefixlen 64  scopeid 0x20<link>
        inet6 2000:2000:2000:51:527c:6fff:fe62:39c3  prefixlen 64  scopeid 0x0<global>
        inet6 2000:2000:2000:51::13  prefixlen 64  scopeid 0x0<global>
So my question basically is, what is 2000:2000:2000:51:527c:6fff:fe62:39c3 doing there?
Is privacy extension enabled by default?
I did not set that in the webGUI.
I did not set DHCPv6, I set the interface to two static IPs, 10.0.51.13 and 2000:2000:2000:51::13
yeah that second global addr is an autoconf address from the kernel, not from your static GUI entry. SCALE still lets the interface pick up a SLAAC addr even when you typed a static IPv6, so outbound uses the wrong source and your remote firewall drops it.
check:
sysctl net.ipv6.conf.vlan51.use_tempaddr
sysctl net.ipv6.conf.vlan51.accept_ra
ip -6 route get <remote_ipv6>
to kill the extra addr for now:
sysctl -w net.ipv6.conf.vlan51.use_tempaddr=0
sysctl -w net.ipv6.conf.vlan51.accept_ra=0
ip -6 addr del 2000:2000:2000:51:527c:6fff:fe62:39c3/64 dev vlan51
make those stick under System → Tunables (or a post-up script). after that ip -6 addr show vlan51 should only show ::13 plus link-local, then re-run the replication.
I don’t get the current network philosophy of TrueNAS.
IMHO either you say:
  • we are a conservative server os. No tempaddr by default, no SLAAC or at least not if a static IPv6 is defined
  • we use the normal SLAAC and tempaddr, but then we also support “normal” networking like anybody else. By normal I for example mean that multiple interfaces can have DHCP enabled
thinkering with tunables is not really what I wanna do just to get basic networking settings.
yeah the gui static ipv6 doesnt turn off kernel slaac/tempaddr on that vlan, so you get both.
to pin it:
  1. System → Tunables:
    net.ipv6.conf.vlan51.accept_ra = 0
    net.ipv6.conf.vlan51.autoconf = 0
    net.ipv6.conf.vlan51.use_tempaddr = 0
  2. apply, then flush and put the static back:
    ip -6 addr flush dev vlan51 scope global
    (or bounce the interface from the gui)
  3. check ip -6 addr show dev vlan51 — should be one global, the one in the gui
until those stick, outbound keeps picking the autoconf addr and your remote allow rule misses it.
