Hi - relatively new Scale user, long(er) time Core user.
Recently migrated to Dragonfish 24.04.2. Running a couple of networks deployed as
eno1 (s/micro X11 built-in 1Gb Nic): mgt lan, IPv4 and IPv6 dual stack
bond0 (on top of 2x Intel XXV710 ports) in LACP to switch
vlan10, vlan30, vlan90 on top of bond0: IPv4 only (although the router offers SLAAC, as IPv6 is used by some other clients on the same network)
I ran a similar config in Core, and although IPv6 default gateway never quite worked through SLAAC (there are several thread on that here), I got IPv6 working for the mgt lan by setting IPv6 default gw manually.
In Scale, everything initially seemed to work as expected. I’ve got “Autoconfigure IPv6” enabled on eno1 and disabled everywhere else.
As of the other day, for unclear reasons, this all started to break. Specifically TrueNAS now picks up and sets IPv6 addresses for ALL the interfaces DESPITE only eno1 having “Autoconfigure IPv6” checked in the GUI. It gets worse when TrueNAS then continues to set multiple and conflicting default routes and gets its whole IPv6 stack in a mess. A reboot resolves it, for a short while.
Anyone else had similar experience?
