Suggestion: Better sVDEV Planning, Oversight Tools in GUI
Good evening,
I would like to beat another dead horse re: a great feature that TrueNAS offers but which is not yet fully implemented. Specifically, I am somewhat flummoxed that while TrueNAS can enable the use of Fusion Pools via the use of sVDEVs, that the company provides no GUI tools for the admin to plan / administer such pools. Let me explain.
For one, a sVDEV requires careful planning. A user has to be educated to the potential downsides (i.e. pool loss), what drives are and are not suitable, etc. Next, the needed pool size should be determined by how much metadata and small files need to be stored in the sVDEV (which features a rigid 50/50 split between small files and metdata).
There are CLI commands to allow the user to determine the size of the metadata (rule of thumb is about 0.3% of the pool size but it varies by use case) as well as the small file size distribution. Neither is can be executed by the GUI, so you better have some good Google skills because the Fusion Pool tutorial goes into the how but not the why, which is potentially really frustrating / dangerous.
Similarly, the Dashboard gives ZERO clues re: the sVDEV other than whether the disks are still available and/or whether they passed their latest SMART test. For example: zero data on how full the sVDEV partitions are, how much data is going in and out, at what speed, etc.
Even a basic check to see how full the sVDEV is requires CLI commands that you will likely have to google for. I find the lack of good documentation somewhat disheartening, sVDEVs offers a significant performance gain but have to be handled with care. Documenting the issues, commands, etc. should have happened by now.
So here is my ask. IXsystems please consider the following improvement suggestions:
  • Provide the user with a GUI tool to examine the distribution of small files (by file size cutoff) as well as their metadata storage needs in the extant pool
  • If the proposed sVDEV is too small to hold expected metadata and / or small files, warn the user
  • Ideally, extrapolate and provide a suggestion re: small file size cutoff as a starting point
  • Let the user set the small file limit from within the GUI as part of the setup process
  • Most importantly: Add a dashboard item to allow the sVDEV user to see how full the sVDEV is, just like the regular pool or memory. If either sVDEV partition is too full (i.e. >80%), warn the user. Given how erratic storage performance likely becomes once the sVDEV overflows into the main pool, it would make diagnosing a badly behaving pool that much easier.
I brought some of these issues up in Jira across three postings (1,2,3) but with zero users voting for them, they remain in the suggestion in-box bitbucket.
Edit: Thank you @HoneyBadger for letting me know that the small-file / metadata allocation is actually 75/25% respectively by default and that it is adjustable.
I’ve voted for the first issue; I don’t have access to the second or third.
Really good suggestions in my opinion.
Ditto
Ditto. And I note that Jira now displays real names rather than user names.
I wondered if suggestions 2 and 3 were also marked private preventing anyone besides me from seeing / voting on them also. Why yes, they are. No wonder they’ve been unpopular suggestions. :rofl:
Look for the little Red Lock, and here is what it means:
Screenshot 2024-04-06 at 05.30.35
Naturally, I cannot change it. :grinning:
So I get it, sVDEV is likely considered a less popular option to work on than a graphic showing off which drive in a hot-swap array has gone bad. But I’d really like to see iXsystems invest a bit more in the documentation and implementation of sVDEVs also.
Voted for the first, let me know whne the others become public.
Voted for all three.
Good morning! Thanks to @kris the sVDEV suggestions in Jira should now be accessible by the general public. All Jira submissions were accidentally marked as Private by default for a while, so that’s how my suggestions went super-stealthy. If you have any other suggestions re: sVDEV and how to make it better, I’m all ears. If there is interest, I can start to turn it more into a resource page.
What I struggle with is that some of the commands that I used in the past at the CLI level appear to have been superseeded / replaced and no longer seem to execute as expected.
As a heads up to the group, if others are still marked private by mistake, DM me. We had a period in the past where incoming issues got erroneously flagged as sensitive / private. That shouldn’t happen going forward, but if there are legacy issues I can re-open them to the public side.
Shouldn’t they be flagged as private by default if someone attaches a debug?
EDIT: In case anyone is wondering, your debug attachment can contain some personal/private information, even if you don’t realize it at first…
There was no debug in my case. I agree that it should be done when a debug is attached.
I cannot change the private / public status of my own submissions, which is kind of weird. Don’t get me wrong, iXsystems has to get the ultimate say on this issue (i.e. to deal with abuse, private info, etc) but I don’t quite understand why only iXsystems has a say on the toggle of public vs. private. I see little harm giving the user some agency here (while respecting pre-emption by iXsystems).
TLDR; Suggestions / bug reports should be set to public to default while giving the submitter a option to make them private.
OK, added some additional data for folk who want to follow in my footsteps re: implementing a sVDEV now. If someone has a better approach for planning, (i.e. determining the minimum sizes needed for either sVDEV partition) please let me know. I hope this is a good start towards a resource in the future.
Why consider a sVDEV?
A sVDEV has the potential to significantly speed up the operations of a HDD pool by putting small files and pool metadata into a faster special VDEV (sVDEV), which usually consists of SSDs. You can also designate specific datasets to reside on a sVDEV by setting record size in the dataset configuration page to equal the sVDEV small file cutoff. Thus, the common practice of segregating pools by hard drive type (SSD vs. HDD) is no longer necessary.
What about L2ARC?
The main difference between Second Level Adaptive Replacement Cache (L2ARC) and sVDEV is that while L2ARC can cache frequently-accessed files, or metadata, or files and metadata, it is read-only, redundant, and it also needs to get “hot”. Unlike sVDEV, the L2ARC has to “miss” having a file or metadata in cache before the miss is noted and might be read into the L2ARC for later reuse. L2ARC also requires RAM to function, so the common recommendation here is not to enable L2ARC unless you have a minimum 64GB of RAM available to TrueNAS.
Based on my limited testing, it took my NAS about three passes with rsync for a metadata=only L2ARC to cache all the metadata it needed.. As you can see from my test results, using L2ARC solely for metadata sped up the rsync task significantly. For an in-depth discussion of L2ARC, see this TrueNAS documentation hub page. Happily, L2ARC can be made persistent, allowing a “hot” cache to survive reboots. Because L2ARC is redundant, any SSD will do, as long as it’s read performance is decent.
Unlike L2ARC, the sVDEV doesn’t need more RAM and it’s 100% hot from the start since all metadata will reside on it. Additionally, the sVDEV will also host small files, which are the worst-performing category for HDDs to deal with. Unlike the L2ARC, your pool will die if the sVDEV stops functioning. For a L2ARC-sVDEV comparison, see my results from a few years ago comparing the impact of L2ARC and sVDEVs in my rsync use case.
About record sizes and small file cutoffs…
What constitutes a small file depends in part on the recordsize used in your pool / dataset. By default, TrueNAS uses 128k recordsizes but you can adjust them on a per-dataset basis, if you wish (See Storage/Pool/Dataset triple-dot on the right of the GUI). Larger record sizes (up to 1M) used in conjunction with compression are great for media files. Smaller record sizes are helpful for databases and like use cases.
For simple large-file data transfers, adjusting the record size up to 1M with zstd compression and adding the sVDEV, made transfer speeds to my pool jump from about 250MB/s to 400MB/s. Not bad for a single-VDEV Z3 pool.
Important: the pool depends on the sVDEV to function, so if the sVDEV dies, your pool dies also. Take the same care with sVDEVs re: redundancy and resilience as you did with the other VDEVs! Do not use crummy SSDs for the sVDEV unless you don’t care about pool life expectancy..
Planning
Ideally, a special VDEV (sVDEV) is planned carefully in advance and is added to the pool before the pool is populated with data. In order to get moved to the sVDEV, a small file has to be copied into the pool or rebalanced in-situ, so figuring out how much storage the sVDEV of a new pool needs in advance is better than adding one later and rebalancing everything just to migrate small files into the sVDEV.
Similarly, you will want to adjust the record size of each data set ideally in advance to figure out what the best balance between record size and sVDEV use is. The good news is that sVDEV cutoffs can be adjusted by dataset, so there is plenty of flexibility.
This feature is also interesting in that you can make datasets that use the same small file cutoff as the recordsize, ensuring that the entire dataset sits on flash drives only. Thus, a sVDEV can selectively host all data that needs speed (databases, metadata, etc.) all as part of a common pool vs. setting up two pools (one flash, the other HDD).
Required sVDEV Size
The needed sVDEV size has be determined by how much metadata and small files data needs to be held. By default, the sVDEV features a 25/75% partition split between metadata and small files, respectively. It can be adjusted by adjusting the zfs_special_class_metadata_reserve_pct parameter (thank you, @HoneyBadger!). The sVDEV does not like to be filled more than 75% by default and you also have to allow for pool expansion in the future. Some extrapolation is likely needed.
Determining Metadata Space Needs
There is a rule of thumb that metadata consumes about 0.3% of the pool space but this will vary by use case. NAS’ hosting only large video files will have comparatively little metadata compared to someone who makes a non-archived copy of a MacOS drive. If you have the time, there are CLI commands to allow the user to determine the size of the metadata exactly. In TrueNAS Core as of 13.0U6, the command to determine your metadata space needs is
zdb -LbbbA -U /data/zfs/zpool.cache poolname
That will spit out a series of tables. One will be long… so long in fact that I’ve truncated mine to only show the top and the bottom while cutting out the middle.
Blocks  LSIZE   PSIZE   ASIZE     avg    comp   %Total  Type
     -      -       -       -       -       -        -  unallocated
     2    32K      8K     24K     12K    4.00     0.00  object directory
                            .... SNIP! .....
 89.0K  2.80G    359M    718M   8.06K    8.00     0.00      L2 Total
 1.61M  51.6G   11.6G   23.2G   14.4K    4.44     0.08      L1 Total
  140M  17.3T   17.2T   30.1T    220K    1.01    99.92      L0 Total
  142M  17.4T   17.2T   30.1T    218K    1.01   100.00  Total
Draw your attention to the line with L1 total, i.e. three lines up from the bottom. There is our metadata information i.e. 23.2GB or 0.08% of my pool was metadata. Extrapolating across 50TB of pool capacity in my use case, that comes out to about 40GB of metadata needs.
Once TrueNAS transitions to OpenZFS 2.2.0 or higher, the current metadata space needs will be even easier to determine via zdb -bbbs with a nice summary at the bottom, see here. Now you know one minimum.
Small File Space Needs
The zdb -LbbbA -U /data/zfs/zpool.cache poolname command will also spit out the answer for your small file needs by publishing something called the “Block Size Histogram”. It summarizes the block sizes used, i.e. how many of each type can be found in your pool today.
  block   psize                  lsize                asize
   size   Count   Size      Cum.  Count   Size   Cum.  Count   Size   Cum.
    512:   422K   211M   211M   422K   211M   211M      0      0      0
     1K:   113K   123M   334M   113K   123M   334M      0      0      0
     2K:  65.7K   175M   510M  65.7K   175M   510M      0      0      0
     4K:  1.92M  7.71G  8.21G   119K   554M  1.04G  1.01M  4.04G  4.04G
     8K:   383K  3.56G  11.8G  39.6K   436M  1.46G  1.77M  14.6G  18.6G
    16K:   765K  13.2G  25.0G   316K  5.18G  6.64G   297K  5.87G  24.5G
    32K:   368K  16.5G  41.5G  1.80M  59.3G  65.9G   585K  18.8G  43.4G
    64K:   622K  56.3G  97.8G  34.0K  2.73G  68.6G   386K  32.4G  75.8G
   128K:   137M  17.1T  17.2T   139M  17.3T  17.4T   138M  30.0T  30.1T
   256K:      0      0  17.2T      0      0  17.4T    605   164M  30.1T
   512K:      0      0  17.2T      0      0  17.4T      0      0  30.1T
     1M:      0      0  17.2T      0      0  17.4T      0      0  30.1T
     2M:      0      0  17.2T      0      0  17.4T      0      0  30.1T
     4M:      0      0  17.2T      0      0  17.4T      0      0  30.1T
     8M:      0      0  17.2T      0      0  17.4T      0      0  30.1T
    16M:      0      0  17.2T      0      0  17.4T      0      0  30.1T
Pay attention to the column “Cum.” to the right of the table. That shows how much room the small files are taking up in your pool on a cumulative basis. None of my files show a record size about 128k, since that is block size that this pool was created with. It’s also why the sVDEV cutoff has to be set below the pool record size.
Once you have your small file distribution, you need to determine where to set your cutoff re: what small files to send to the sVDEV vs. the general pool. By default, I chose 32kB which consumed 18.8GB of metadata needs. Plenty of space for the pool to grow. Extrapolate your data needs and see what kind of storage you might need.
For example, if my pool is 20% full and small files needs make up for 18GB as shown above, then a full pool would need 5x as much sVDEV space for small files, i.e. 90GB. If I leave the small files / metadata ratio at the default 75/25% ratio, then my sVDEV pool has to be at least 120GB. However, you might find that by adjusting the record sizes that the diversity of your pool will increase and more data could be stored in the sVDEV. If you suspect that you will host more smaller files in the future, you would do well to select a much larger sVDEV to account for expansion in the future.
sVDEV drive selection
At minimum, choose SSDs that can handle the workload and a proven track record re: endurance. Power Loss Protection (PLP) is also a nice to have, though that can get expensive. I went for Intel S3610 SATA SSDs that (though used) have incredible write-endurance. I also bought two spares. I qualified all my SSDs before using them, set aside the spares in caddies, ready to mount if one of the four SSDs I use for a sVDEV develop a failure and needs to be replaced.
Because a loss of the sVDEV will result in a pool loss, you will want to mount sVDEV SSDs in mirrors, at minimum in a 2-way. I use a four-way mirror for my Z3 pool.
Implementation
Yes, the sVDEV can be enabled / attached / assigned at the GUI level, see here. Make sure all the SSDs you need are in the sVDEV, set up as mirrors, etc.
The small file record size cutoff can be set via the GUI - select “Storage” then “Pools”, followed by going over the pool/dataset table. The pool or individual dataset small file cutoff can be adjusted by opening “edit option” (see three dots to the right of each pool or dataset name in the menu) and adjusting the “Metadata small block size”. If you do it for the pool, the datasets will inherit the pool value by default. You can also do this via the CLI, per this Level 1 post, the command is
zfs set special_small_blocks=64K poolname
or if you want to vary small file cutoffs on a dataset basis:
zfs set special_small_blocks=128K poolname/dataset
If you are about to enjoy a new pool of content, congratulations, you are pretty much done. If you have an extant pool, the small-files benefit won’t really start to accrue until you move the small files onto the sVDEV.
This is also a great time to brush up on recordsize and to determine if you should adjust the record sizes of particular pools to better suit the data in them - you can do this in the GUI by selecting, Storage → Pools and then individual datasets. Lastly, there may be some small pools (think iocage jails) where likely all data should reside on the sVDEV. Go ahead and tune the recordsize cutoff by dataset to your liking.
There is no GUI rebalancing command, though we may get one if ZFS VDEV expansion ever becomes a reality in TrueNAS. In the meantime, there is an excellent script written in bash that can do the rebalancing for you. Before you rebalance, back up, turn off snapshot and then replication tasks. I also had to delete all snapshots since it becomes very difficult to see the impact of record size changes and rebalancing efforts if snapshots pollute the data.
In TrueNAS Core, you have to “su” to become the owner of the data before you run the script, I’d also advise to tmux the session to ensure the command can actually execute across the whole dataset. After installing the script in my root folder, my steps are as follows:
  1. cd /mnt/pool/dataset
  2. ls -al (to see who the owner is)
  3. tmux
  4. su owner
  5. bash /root/zfs-inplace-rebalancing.sh --checksum true --passes 1 /pool/path/to/rebalance
then CTRL-B and then “d” to detach.
It will run for a while, and as it does, you’ll watch the pool start to redistribute data, especially if you have also tuned the recordsize to be larger for some pools like image, archive, or video content. Hopefully, you’ll see the big sets of data migrate to larger recordsizs, allowing you to fine tune the cutoff limits for the sVDEV recordsizes, storing as much small file data on the sVDEVs as possible to maximize the speed boost.
You may have to run the rebalancing script a few times. Only when your pool is “perfect” turn both Snapshot and Replication tasks back on. I would also hit the “Add” button in Storage / Snapshot GUI at this point to manually execute a snapshot. Replication tasks can only start if there is a extant snapshot. Then go to Tasks / Replication and “Run Now” your replication tasks to verify they’re still OK.
Maintenance
Sadly, the dashboard currently gives ZERO clues re: the sVDEV other than whether the disks are still available and/or whether they passed their latest SMART test. For example: zero data on how full the sVDEV partitions are. If you go into reporting, you can get a glimpse into I/O of the sVDEV drives but not on a group basis, which would be helpful if your sVDEV pool contains multiple mirrors.
Even a basic check to see how full the sVDEV is requires CLI commands (i.e. use zpool list -vvv poolname to see how full each VDEV is [thank you, @NickF1227!).
I find the lack of good documentation somewhat disheartening, sVDEVs offer a significant performance gain but have to be handled with care. Documenting the issues, implementing GUI commands, etc. should have happened by now.
Some other considerations
I would ensure that the remote NAS for a replication task has the exact same settings re: recordsize, compression, sVDEV small file cutoff (if fitted), etc. on a dataset by dataset basis as the primary NAS. If your remote NAS already has content, I’d either wipe and start over (safest option) or nuke all remote snapshots, change the recordsizes, etc. to match the primary NAS, rebalance, and only then re-enable replication. (seems like a less safe option)
So what though?
Well, I have found the implementation of sVDEV on my pool to enable a improvement over L2ARC in terms of metadata, even if a L2ARC is “hot”, persistent, and metadata-only (the L2ARC only really helps for read operations re: metadata, not writes, which have to go to the slow HDD pool). Between sVDEV, recordsize=1M, compression=zstd, and a rebalance, my sustained large-file pool write speed has risen to 400MB/s, well above the expected 250MB/s limit I used to experience. The
command now executes in less than two minutes and the amount of files stored in the small files sVDEV has shot up considerably. Meanwhile, my NAS’ metadata needs dropped to just 0.03% of the pool.
17.0T completed (331016MB/s) estimated time remaining: 0hr 00min 00sec
        bp count:              13671449        ganged count:                 0
        bp logical:      12053360033792      avg: 881644
        bp physical:     11620838932480      avg: 850007     compression:   1.04
        bp allocated:    18659308601344      avg: 1364837     compression:   0.65
        bp deduped:                   0    ref>1:      0   deduplication:   1.00
        Normal class:    18553586663424     used: 23.21%
        Special class      106690252800     used:  6.68%
        Embedded log class              0     used:  0.00%
        additional, non-pointer bps of type 0:        131
         number of (compressed) bytes:  number of bps
and
     1    32K      8K     24K     24K    4.00     0.00      L1 object array
    77  38.5K   38.5K    924K     12K    1.00     0.00      L0 object array
    78  70.5K   46.5K    948K   12.2K    1.52     0.00  object array
------ SNIP! ------
  586K  18.3G   2.61G   5.23G   9.15K    7.00     0.03      L1 Total
 12.5M  10.9T   10.6T   17.0T   1.36M    1.04    99.97      L0 Total
 13.0M  11.0T   10.6T   17.0T   1.30M    1.04   100.00  Total
and
    512:   238K   119M   119M   238K   119M   119M      0      0      0
     1K:  80.2K  99.0M   218M  80.2K  99.0M   218M      0      0      0
     2K:   126K   334M   552M   126K   334M   552M      0      0      0
     4K:   849K  3.36G  3.90G  97.3K   526M  1.05G   458K  1.79G  1.79G
     8K:  96.8K   914M  4.80G  60.3K   662M  1.70G   916K  7.29G  9.08G
    16K:   135K  2.42G  7.21G   229K  3.86G  5.56G  63.5K  1.28G  10.4G
    32K:   197K  9.10G  16.3G   701K  23.6G  29.1G   267K  11.1G  21.5G
    64K:   144K  11.8G  28.2G  31.6K  2.49G  31.6G   135K  11.0G  32.5G
   128K:   561K  75.9G   104G   620K  79.5G   111G   566K   119G   152G
   256K:   185K  67.5G   172G  57.1K  20.3G   131G   173K  63.0G   215G
   512K:   303K   214G   386G  58.3K  40.9G   172G   105K  85.4G   300G
     1M:  10.2M  10.2T  10.6T  10.8M  10.8T  11.0T  10.4M  16.7T  17.0T
     2M:      0      0  10.6T      0      0  11.0T      0      0  17.0T
     4M:      0      0  10.6T      0      0  11.0T      0      0  17.0T
     8M:      0      0  10.6T      0      0  11.0T      0      0  17.0T
    16M:      0      0  10.6T      0      0  11.0T      0      0  17.0
NAME                                             SIZE  ALLOC   FREE  CKPOINT  EXPZ   FRAG    CAP  DEDUP    HEALTH  ALTROOT
pool                                            74.2T  17.0T  57.2T        -     -     0%    22%  1.00x    ONLINE  /mnt
  raidz3-0                                      72.7T  16.9T  55.9T        -     -     0%  23.2%      -    ONLINE
    gptid/e6a453ca-90cf-11eb-acc9-ac1f6b738b00  9.09T      -      -        -     -      -      -      -    ONLINE
    gptid/e7dfdfc1-90cf-11eb-acc9-ac1f6b738b00  9.09T      -      -        -     -      -      -      -    ONLINE
    gptid/e85bad6d-90cf-11eb-acc9-ac1f6b738b00  9.09T      -      -        -     -      -      -      -    ONLINE
    gptid/6e4220ac-c6b0-11ed-88d6-ac1f6b738b00  9.09T      -      -        -     -      -      -      -    ONLINE
    gptid/e97464f9-90cf-11eb-acc9-ac1f6b738b00  9.09T      -      -        -     -      -      -      -    ONLINE
    gptid/e98fe8b5-90cf-11eb-acc9-ac1f6b738b00  9.09T      -      -        -     -      -      -      -    ONLINE
    gptid/e9d3abb0-90cf-11eb-acc9-ac1f6b738b00  9.09T      -      -        -     -      -      -      -    ONLINE
    gptid/ea54f6eb-90cf-11eb-acc9-ac1f6b738b00  9.09T      -      -        -     -      -      -      -    ONLINE
special                                             -      -      -        -     -      -      -      -  -
  mirror-2                                      1.45T  99.4G  1.36T        -     -    14%  6.67%      -    ONLINE
    da6p1                                       1.46T      -      -        -     -      -      -      -    ONLINE
    gptid/65cf991f-90d0-11eb-acc9-ac1f6b738b00  1.46T      -      -        -     -      -      -      -    ONLINE
    gptid/6602f626-90d0-11eb-acc9-ac1f6b738b00  1.46T      -      -        -     -      -      -      -    ONLINE
logs                                                -      -      -        -     -      -      -      -  -
  gptid/b4029892-c0d0-11eb-a3ed-ac1f6b738b00    93.2G  1.65M  93.0G        -     -     0%  0.00%      -    ONLINE
cache                                               -      -      -        -     -      -      -      -  -
  gptid/66d6684f-90d0-11eb-acc9-ac1f6b738b00     932G   927G  4.20G        -     -     0%  99.5%      -    ONLINE
freenas-boot                                    58.9G  7.74G  51.1G        -     -    23%    13%  1.00x    ONLINE  -
  mirror-0                                      58.9G  7.74G  51.1G        -     -    23%  13.1%      -    ONLINE
    ada1p2                                      59.0G      -      -        -     -      -      -      -    ONLINE
    ada0p2                                      59.0G      -      -        -     -      -      -      -    ONLINE
Issues are open by default. The system gives the submitter a link to upload private debug files automatically. If somebody says something sensitive in the ticket by mistake, we remove those bits as soon as we can. Not perfect, but the best we’ve got right now :slight_smile:
                            .... SNIP! .....
Draw your attention to the line with L1 total, i.e. three lines up from the bottom. There is our metadata information i.e. 23.2GB or 0.08% of my pool is metadata. Extrapolating across 50TB of pool capacity in my use case, that comes out to about 40GB of metadata needs.
@Constantin thanks… this is useful insight and request.
Would not this 1st step of reporting actual metadata size help most users with planning their sVDEV size?
Has anyone tried scripting it? We’d be open to contributions as well.
The community is also hungry for stories/use-cases where the sVDEVs work and where they don’t. For example, with a 128GB server, the sVDEV may not be that impactful for this pool.
Isn’t that what I suggested? - i.e. determining whether it’s small files or metadata dominating and the extrapolating across the empty pool space to determine the minimum sVDEV disk size. It’s also why I suggested in Jira that the sVDEV have a flexible allocation between small files and metadata (see above).
Not to my knowledge and I certainly would not feel comfortable doing it.
I’m not sure how to answer this assertion other than to point you to the differences in performance based on sVDEV vs. no sVDEV. I have found there to be a tremendous difference, especially for any task that requires a lot of directory traversal (i.e. rsync, for example). Perhaps the coming changes to ARC will help mitigate that, I can run some more tests in the future as 13.3 stable trickles down to mere users.
One significant advantage of sVDEV over L2ARC is that the sVDEV is always “hot” re: metadata. The benefit re: small files is usually quite significant, especially if a lot of reading and writing is going on (i.e. databases). Specific datasets can be selectively tuned to reside entirely in the sVDEV (i.e. iocage, VMs) massively speeding them up also.
Don’t get me wrong, there are potential downsides also but as long as one carefully considers the costs and benefits, I see nothing wrong with enjoying a sVDEV as part of a pool.
The problem with this command (and the abridged one) is that zdb is literally traversing all of the blocks in your system to get you this information. It also highly threaded and forks off a bagillion processes to do this:
So real-time reporting of this is not really feasible. There is also a significant enough performance impact in getting the one-off reporting to make it challenging in production.
Thats probably a much bigger ask of OpenZFS.
Quantifying the Benefits
It is true in many specific use cases like this, rsync is a generally good example. Performance profiling pools with special VDEVs is a quirky thing, I’ve been on-again off-again playing with this for a while.
But finding a “usecase” that matters I can benchmark against isn’t like running an FIO test or CrystalDiskMark. Actual tooling would probably need to be created with some pseudo realistic scenarios. Benchmarking ls or rsync times on large directories may be a thing to do, but there’s more to this story and it’s also not quite that simple, many variables. As an example, ARC will (rather helpfully) get in the way.
At the moment I don’t have any readily available hardware to putz with this some more. It’s on my list, unfortunately had a server die on me :frowning:
Measuring Performance
Netdata/Reporting in TrueNAS does a great job of collecting the stats for all of your drives individually, so you do have at least some insight into what the special VDEV is doing in terms of it’s activity over time, kinda like it’s “hit rate”.
I’ve had some thoughts about ways I can script the collection of performance metrics in a low impact way and display them easily. I have some work done grepping for values from zpool iostat (more info here) where I dump values to a CSV I can parse into something to make pretty charts or simply open it in excel. Looking at latency over time on a given special VDEV is the low hanging fruit and is easy enough to do.
Here’s an example where I am able to quantify the impact of a scrub by measuring latency:
This is a fun project I’ve been toying with. However, Making the leap from what I have done to making pretty Grafana dashboards is something that needs time in the oven. If you’re interested in what I have I’ll happily share. It’d be nice to see what data we get from your pool and usecase.
More to come from me. You’ve reignited an old flame! I’m sure more will come from iX in good time, but we can do better at the grass roots level to quantify the need and demonstrate the ask. This is high on my list of projects to complete for sure.
You are amazing and you are correct in that the resources needed to plan for a sVDEV are potentially time-intensive - that is why I only advocate for the use of zdb -LbbbA -U /data/zfs/zpool.cache *poolname* in the context of planning, not real-time monitoring.
My hope was that there is a ZFS command that can look at how full a drive / VDEV is without having to resort to a full traversal of the file system? Something along the lines of zpool list -v poolname, which seems to execute very quickly on my system and currently shows the sVDEV only using about 1.6% of its total capacity. Ideally, that would be expanded to look at the two partitions separately, i.e. % full for metadata and %full for small files.
If a full traversal of the file system cannot be avoided, then give the user the option to set a given interval (say daily/weekly/etc) and have it update on that basis. For my system, it takes about 3 minutes and doesn’t tax the system much, but that’s likely because the sVDEV contains all the metadata already. Perhaps add a “update now” button in the widget and only execute the data update / traversal as needed?
Similarly, if ZFS doesn’t readily made I/O stats re: sVDEV available, then by all means ignore adding them to the Widget. I’d simply like to see something rather than having to resort to the CLI to look over the fill status of my sVDEV. Additional stats would simply help folk tune their systems / datasets.
I agree that use cases matter, which is why I explicitly explained my specific use case for the benchmarking I did. I’ll be happy to collaborate and help with testing your script. Let me finish rebalancing here first though since rebalancing will likley affect your execution speeds by absorbing much of the read/write capacity of the pool.
This actually already exists as the parameter zfs_special_class_metadata_reserve_pct which defaults to 25% of each vdev size.
If you’re talking about the metadata balance changes to ARC, those do help significantly in metadata-read-heavy cases - but of course you do need an sVDEV for the more metadata-write-heavy workloads especially on HDD pools that would otherwise struggle with the random small record writes.
zpool iostat -v can give you general vdev/drive usage but it doesn’t break it down between meta/small-file.
I can’t speak for what’s officially coming to a TrueNAS update near you, but my opinion on this is that it shouldn’t be something that exposed in the UI. The performance penalty is too great, and the time it takes is looking to be weeks for my pool. This is 12/13 hours in:
Granted its a relatively big (but not uncommonly sized!) pool:
root@prod[~]# zpool list -vvv
NAME                                       SIZE  ALLOC   FREE  CKPOINT  EXPANDSZ   FRAG    CAP  DEDUP    HEALTH  ALTROOT
boot-pool                                   95G  44.6G  50.4G        -         -    28%    46%  1.00x    ONLINE  -
  sda3                                    95.3G  44.6G  50.4G        -         -    28%  46.9%      -    ONLINE
ice                                        255T   141T   114T        -         -     3%    55%  1.00x    ONLINE  /mnt
  raidz2-0                                50.9T  27.8T  23.2T        -         -     4%  54.5%      -    ONLINE
    028d1ff1-474e-4378-9367-eb09979bc202  7.28T      -      -        -         -      -      -      -    ONLINE
    fbce79d0-6db2-41ea-b83d-d86090d62814  7.28T      -      -        -         -      -      -      -    ONLINE
    ab738ba2-7291-4e9b-beb3-6cbca0917f60  7.28T      -      -        -         -      -      -      -    ONLINE
    920d1d04-8f3f-452b-87c2-8e4d9f71c5aa  7.28T      -      -        -         -      -      -      -    ONLINE
    77429595-9454-4152-9ba5-5fecbd8af598  7.28T      -      -        -         -      -      -      -    ONLINE
    cf4ede22-0b39-4ad1-a0be-51e974a96be7  7.28T      -      -        -         -      -      -      -    ONLINE
    4bf26bfe-3e20-4d24-add0-f367ae74e3f9  7.28T      -      -        -         -      -      -      -    ONLINE
  raidz2-1                                50.9T  28.2T  22.7T        -         -     4%  55.4%      -    ONLINE
    b12c53b4-a32a-4cde-a835-dce039199fa3  7.28T      -      -        -         -      -      -      -    ONLINE
    8fb5d904-dd5c-494a-9d75-e8fe155a89bc  7.28T      -      -        -         -      -      -      -    ONLINE
    2f8b9428-915a-4109-826f-0dd2c039b7bd  7.28T      -      -        -         -      -      -      -    ONLINE
    e28b0363-8d27-4d75-8eff-d73054f6b4e8  7.28T      -      -        -         -      -      -      -    ONLINE
    c81992e2-3315-47ce-b839-cabef787a5c2  7.28T      -      -        -         -      -      -      -    ONLINE
    03d3709f-43d5-4d43-aada-c49dda1246e8  7.28T      -      -        -         -      -      -      -    ONLINE
    8acc8ce0-99d0-4e1d-b2a3-8f55d45fc963  7.28T      -      -        -         -      -      -      -    ONLINE
  raidz2-2                                50.9T  28.2T  22.8T        -         -     4%  55.3%      -    ONLINE
    af36fe9c-18c8-4c01-b9e4-991d13f8bfb4  7.28T      -      -        -         -      -      -      -    ONLINE
    374f6b0c-cbea-4597-b44d-5b91a3410e15  7.28T      -      -        -         -      -      -      -    ONLINE
    5eaa2d45-3fb7-42d6-af1b-8a561ca56169  7.28T      -      -        -         -      -      -      -    ONLINE
    127afe09-e10d-4884-aed3-eeac99f82be0  7.28T      -      -        -         -      -      -      -    ONLINE
    044cfd82-3ab0-4378-abff-d4952e0515f9  7.28T      -      -        -         -      -      -      -    ONLINE
    57ebb7ea-e7f3-43dd-9445-bca31a60cb4d  7.28T      -      -        -         -      -      -      -    ONLINE
    3aff0510-28d5-4e78-bf7c-c675941217ad  7.28T      -      -        -         -      -      -      -    ONLINE
  raidz2-3                                50.9T  28.2T  22.7T        -         -     3%  55.4%      -    ONLINE
    ddf9473c-48ff-4f5a-9af9-f367ca80c182  7.28T      -      -        -         -      -      -      -    ONLINE
    60f1dc27-041d-46de-9970-c8d0906edeb2  7.28T      -      -        -         -      -      -      -    ONLINE
    bba518e0-1c32-422d-ac9e-1d2a4275c9ea  7.28T      -      -        -         -      -      -      -    ONLINE
    d645a548-b228-4470-99e5-fed51aff3d4b  7.28T      -      -        -         -      -      -      -    ONLINE
    be798ef3-bb11-4546-b0b0-109e044f3188  7.28T      -      -        -         -      -      -      -    ONLINE
    cfe17d9e-3db9-4863-a979-a3ba7ddc7425  7.28T      -      -        -         -      -      -      -    ONLINE
    c2dfee62-4936-4c5f-a957-66994b075454  7.28T      -      -        -         -      -      -      -    ONLINE
  raidz2-4                                50.9T  28.1T  22.8T        -         -     4%  55.3%      -    ONLINE
    a0823ea8-1a73-4d18-907b-3f0d97d5dccb  7.28T      -      -        -         -      -      -      -    ONLINE
    34f23c66-72e4-49d4-bd40-50b1aff9f8ad  7.28T      -      -        -         -      -      -      -    ONLINE
    050afa47-7d9b-4beb-8167-49f38e2a4c61  7.28T      -      -        -         -      -      -      -    ONLINE
    a6a003a5-dcbd-4693-a990-d94e2627dbe3  7.28T      -      -        -         -      -      -      -    ONLINE
    34cfb707-8d83-461b-86e1-4689ca42440e  7.28T      -      -        -         -      -      -      -    ONLINE
    b5a166f7-2478-4487-a80c-aaf23dafd031  7.28T      -      -        -         -      -      -      -    ONLINE
    1a2f31ae-c25d-428a-9f5e-839ebcc53b19  7.28T      -      -        -         -      -      -      -    ONLINE
Out of curiosity, can you post the zpool list -vvv of your pool?
Hmmm. Good point - just because it executes quickly on my end doesn’t mean it’ll execute quickly on pools with pure rust, no L2ARC metadata-only cache, etc. Would your deadline be very different if a metadata-only L2ARC can be used as part of planning? The cost would be moderate and it would be better than planning for 0.3% as a rule of thumb.
Your wish is my command. That executed quickly as well and 25.8G of data is hilariously little compared to the capacity of the sVDEV.
Pool                                            74.2T  20.9T  53.3T        -     -     2%    28%  1.00x    ONLINE  /mnt
  raidz3-0                                      72.7T  20.9T  51.9T        -     -     2%  28.7%      -    ONLINE
  mirror-2                                      1.45T  25.8G  1.43T        -     -    14%  1.73%      -    ONLINE
  gptid/66d6684f-90d0-11eb-acc9-ac1f6b738b00     932G   929G  2.58G        -     -     0%  99.7%      -    ONLINE
