- how to i fix “web interface cannot be accessed” i have the default F8 SSD Plus
We would need more information. Is the TrueNAS server still on the network or did it lose all network connectivity? Can you ping it’s ip address or access file shares? Do you have access to the console screen or SSH set up to see if and where the system is saying the GUI address is?
Browse some other threads and do the Tutorial by the Bot to get your forum trust level up if you need to post images
TrueNAS-Bot
Type this in a new reply and send to bring up the tutorial, if you haven’t done it already.
@TrueNAS-Bot start tutorial
After booting from nvme drive with installed system it shows this message and 1-9 menu:
…Web interface could not be accessed …
Configure network settings
Configure static routes
Set up local administrator
Reset configuration to defaults
Open TrueNAS CLI Shell
Open Linux Shell
B) Reboot
- Shutdown
Enter an option from 1-9:…
How did you have your network set up? Did the TrueNAS system use DHCP to get an ip address or did you use a static ip?
