What did you do after clicking 1?
Do you have access to your modem/router? Have you connected a LAN cable to the system you are installing TN?
Not sure if you doing Core or Scale. Work your way through the Getting Started section in the docs under the version you are working with. Please post your hardware. You can expand a few of the links in posters signature to get an idea of what we would like to see.
Yes, that’s option 1–we can see it on the screen shot you posted. And the rest? What options did you pick, what did you enter, etc.? And you continue to not answer the other questions I posted.
This is my new favourite way to install TrueNAS ![]()
Skips the whole “how to burn” problem.
Also, copy the shasum file to the same place as the ISO and Ventoy supports verifying the ISO at install time too.
Once you’ve created your Ventoy installer USB, you just drop isos+checksum files onto the disk.
