True NAS Core 13 installation stuck with white - Cursor
I created USB bootable pen drive for TrueNAS core image ver 13.0 using Rufus tool.
I tried to install on my computer( see the hardware details in the below screen), but after selecting menu option 1, the installation stops with white cursor and black screen.
what may be the reason.
we have 8 GB RAM and 2 drives with 1 TB each.
What is the device you are booting the installer from? From what I can glean (and I’m having my own installation issues) it’s kinda touchy about what USB device you use and on what USB port. IIRC, USB3 isn’t properly supported by the installer. You might want to see if the port you have the installer flash drive in is USB3, if it is, move to a USB 1 or 2 port.
Just a guess, but worth a go I think.
My problem is that when it completes install, it can’t fully boot the newly installed TrueNAS because it can’t mount the ZFS root volume (error 2) which seems to mean unknown file system, possibly due to the installer creating loader.conf without an instruction to allow ZFX volumes to mount. I have had zero response to the questions about it over the last 24 hours. Not one single response.
Good luck, I think we’re both gonna need it.
Regards
Geoff
Thanka a lot for the hints. Will try these tips tmrw and see, if I am. Lucky enough!
Found these above links related to the similar issue with different work arounds… FYI
Not the same problem. They are all to do with getting the installer to boot.
I booted mine from a Ventoy installed USB stick and the installer runs fine, and the installation goes normally, says it was successful and asks me to remove the installation media and reboot. The problem is that when it reboots the installed TrueNAS, it can’t mount the zfs root file system, error 2, which means ‘unknown file system’. Probably an issue with the installer, but I can’t find a workaround and there has been zero response in the forums (aside from yours) so far.
Thanks for your help
Regards
BIOS screenshot shows 4Gb of RAM, upper left by Information. DIMM_A1: N/A, DIMM_B1 Kingston 4096 MB. Check your RAM sticks
Your USB is 8GB.
Documentation
https://www.truenas.com/docs/core/13.0/
We tried installing after upgrading to 8 GB RAM later but still the same issue during installation..
Sorry. What I meant was related to my issue not yours…
You can try updating your motherboard bios to the latest from Asus. 2402 is latest per their website.
What device were you going to use as your boot drive?
The BIOS screenshot shows two, 1TB hard drives and the USB at 8GB. Was the USB just the installation media?
When you made your install USB with Rufus did it ask about using DD Mode per the documenation instructions
To write the TrueNAS installer to a USB stick on Windows, plug the USB stick into the system and use a program like Rufus to write the .iso file to the memory stick. When Rufus prompts for which write method to use, make sure dd mode is selected.
The USB stick is not recognized by Windows after the TrueNAS installer writes to it. To reclaim the USB stick after installing TrueNAS, use Rufus to write a “Non bootable” image, then remove and reinsert the USB stick.
Verify the checksum of your downloaded ISO: if it does not match with the official one, download it again.
Format the USB and burn-in again the ISO (with the correct checksum.
Yes it asked as shown below and I clicked Yes/ok and proceeded further as shown below:
In order to reclaim, I tried this method of writing “Non-bootable” image and removing and inserting
But still not able to detect this pen drive again? any idea why. thanks
I just tried two different USB drives and both were recognized by Windows after that method.
Did you verify your ISO download checksum?
Did not find the steps how to verify the checksum?
I can see only some checksum value being displayed in the website.
Also one more question,
To download older versions of True NAS?
It says direct downloads.after that no option to dowload
Core previous versions
https://download-core.sys.truenas.net/
Expand ISO Verification section
Give the install a minute or two to continue. It might be probing hardware and just looks like it is stuck
Checksum matches.
Similarly I verified checksum for couple of other ISO images like :
TrueNAS-13.0-U6.2.iso
TrueNAS-13.3-BETA2
even they are matching.
so I dont think, issue with check sum here.
I think, we waited for couple of minutes, anyways will give a try about this again and see.
Thanks
I verified, checksums are fine.
I feel its some other issue…
I checked Asus websit for our motherboard modele. But could not find any download options for motherboard bios.
USB was just installation media.
We want to just try installation on one of the 1 TB hard drives as this is first time, we are installing a NAS OS.
later on we will install it on lesser memory capacity ssd/hdd and use this 1 TB drive for memory pool/storage functionalilties as datasets etc
I would suggest trying a different USB port and USB drive.
