TrueNAS Cloud Sync to Backblaze B2 not completing without errors!
Having an issue with Cloud sync tasks to Backblaze B2. This was working just fine until the last couple of days. I have checked that SSE is turned off and I have even created a fresh empty bucket on Backblaze to no avail. Can anyone give me some ideas as to where to begin beyond what I have already tried.
Thank you in advance.
Here is the error message I got:
2025/09/01 10:34:54 INFO : Proxmox-NFS/images/100/vm-100-disk-1.qcow2: Copied (new)
2025/09/01 10:34:54 INFO : Proxmox-NFS/dump/vzdump-lxc-104-2025_08_26-06_07_19.log: Copied (new)
Transferred: 908.350 KiB / 93.596 GiB, 0%, 0 B/s, ETA -
Checks: 2 / 2, 100%
Transferred: 2 / 52, 4%
Elapsed time: 1.4s
Transferring:
  • Proxmox-NFS/template/i…04.3-desktop-amd64.iso: transferring
  •  Proxmox-NFS/images/106/vm-106-disk-0.raw: transferring
… 1197 more lines …
Checks: 101 / 101, 100%
Transferred: 49 / 50, 98%
Elapsed time: 2h16m4.4s
Transferring:
  • Proxmox-NFS/images/100/vm-100-disk-0.qcow2: 99% /64.010Gi, 27.660Mi/s, 12s
2025/09/01 12:52:47 ERROR : Proxmox-NFS/images/100/vm-100-disk-0.qcow2: corrupted on transfer: sha1 hashes differ src(Local file system at /mnt/Pool-1) “d6a06eb2a5131f6d4401e1c1cd842641cdb7bbbe” vs dst(B2 bucket TrueNAS-Backup-DavidB path TrueNAS-Backup) “59f5affce9c6f8d88aa55e0545e85b93ffb14a0f”
2025/09/01 12:52:47 INFO : Proxmox-NFS/images/100/vm-100-disk-0.qcow2: Removing failed copy
2025/09/01 12:52:47 ERROR : Attempt 3/3 failed with 4 errors and: corrupted on transfer: sha1 hashes differ src(Local file system at /mnt/Pool-1) “d6a06eb2a5131f6d4401e1c1cd842641cdb7bbbe” vs dst(B2 bucket TrueNAS-Backup-DavidB path TrueNAS-Backup) “59f5affce9c6f8d88aa55e0545e85b93ffb14a0f”
2025/09/01 12:52:47 Failed to copy with 4 errors: last error was: corrupted on transfer: sha1 hashes differ src(Local file system at /mnt/Pool-1) “d6a06eb2a5131f6d4401e1c1cd842641cdb7bbbe” vs dst(B2 bucket TrueNAS-Backup-DavidB path TrueNAS-Backup) “59f5affce9c6f8d88aa55e0545e85b93ffb14a0f”
Well, turns out my issue was I was trying to backup running LXC containers and VMs and just needed to turn on snapshot mode for those items. Thanks for all the help from no one!
Same error here on my end since upgrading to 25.10 and following. I don’t have snapshots enabled on my backups as I have nested datasets, which apparently won’t let me set snapshots to run. Here is the error.
[EFAULT] Checks: 1052984 / 1052984, 100%, Listed 2940498 Transferred: 518 / 518, 100% Elapsed time: 3h37m59.0s 2025/12/09 03:38:02 NOTICE: Failed to sync with 3 errors: last error was: corrupted on transfer: sha1 encrypted hashes differ src(B2 bucket TrueNAS-Backup-Nov8-2025 path Main_Tank) “06b9c74254001d13407e997408a16b16ac07f478” vs dst(B2 bucket TrueNAS-Backup-Nov8-2025 path Main_Tank) “835cb8aac650c6b90e511e1163d74ff29756692c”
I never had issues with backing up to Backblaze prior to upgrading from 25.04 to 25.10 and now 25.10.1. I actually removed the full backup to Backblaze and redid this once before uploading all the data into a brand new bucket and now it’s erroring out again. Here are more from logs:
2025/12/09 00:00:04 INFO :Transferred: 0 B / 0 B, -, 0 B/s, ETA -Checks: 0 / 0, -, Listed 15Elapsed time: 1.0s
2025/12/09 00:00:06 NOTICE: .bzEmpty: Skipping undecryptable file name: not an encrypted file - does not match suffix2025/12/09 00:00:07 INFO : Kavita/config/kavita.db-shm: Copied (replaced existing)2025/12/09 00:00:07 INFO : FreshRSS/data/index.html: Copied (replaced existing)2025/12/09 00:00:08 INFO : Kavita/config/backups/kavita_backup_12_08_2025_07_00_02_v0.8.8.3.zip: Copied (new)2025/12/09 00:00:08 INFO : JellyFin/Cache/fedafbe3f2764064b8168862c44c0b31_channels: Copied (replaced existing)… 1063 more lines …Transferred: 518 / 519, 100%Elapsed time: 3h35m11.0sTransferring:
  • JellyFin/Transcodes/2c…6c9a55808333e9bd2b6.ts:134% /13.131Gi, 4.956Mi/s, -
2025/12/09 03:38:02 ERROR : JellyFin/Transcodes/2cc69d61454646c9a55808333e9bd2b6.ts: Failed to copy: corrupted on transfer: sha1 encrypted hashes differ src(B2 bucket TrueNAS-Backup-Nov8-2025 path Main_Tank) “06b9c74254001d13407e997408a16b16ac07f478” vs dst(B2 bucket TrueNAS-Backup-Nov8-2025 path Main_Tank) “835cb8aac650c6b90e511e1163d74ff29756692c”2025/12/09 03:38:02 ERROR : Encrypted drive ‘encrypted:/’: not deleting files as there were IO errors2025/12/09 03:38:02 ERROR : Encrypted drive ‘encrypted:/’: not deleting directories as there were IO errors2025/12/09 03:38:02 ERROR : Attempt 3/3 failed with 3 errors and: corrupted on transfer: sha1 encrypted hashes differ src(B2 bucket TrueNAS-Backup-Nov8-2025 path Main_Tank) “06b9c74254001d13407e997408a16b16ac07f478” vs dst(B2 bucket TrueNAS-Backup-Nov8-2025 path Main_Tank) “835cb8aac650c6b90e511e1163d74ff29756692c”2025/12/09 03:38:02 NOTICE: Failed to sync with 3 errors: last error was: corrupted on transfer: sha1 encrypted hashes differ src(B2 bucket TrueNAS-Backup-Nov8-2025 path Main_Tank) “06b9c74254001d13407e997408a16b16ac07f478” vs dst(B2 bucket TrueNAS-Backup-Nov8-2025 path Main_Tank) “835cb8aac650c6b90e511e1163d74ff29756692c”
Any ideas?
