Hello
I have a TrueNAS Core system (FreeBSD), the current harddrives are pretty old (but still zero problems/warnings) and I want to proactively replace them with new, nice harddrives.
How would you recommend going about replacing the harddrives?
Some additional information:
- The system has plenty of capacity for harddrives, so I can fit/connect all, both old and new, harddrives at the same time.
- The current pool (there is only one) is a bit old, for example TrueNAS shows “Legacy encryption”. So I am thinking that the new harddrives will be a new pool.
- The new harddrives have more storage capacity than the current ones.
- I use jails (note: not “plugins”), no other special features. Besides jails the system is a ordinary NFS NAS.
