I am experiencing a critical issue where my TrueNAS SCALE 25.10.5 installation cannot import a RAIDZ1 pool after a normal shutdown and server relocation. The pool import process hangs indefinitely, blocking all ZFS operations and preventing the system from completing its boot sequence.
System Configuration:
TrueNAS SCALE 25.10.3 (now 25.10.5 after clean reinstall)
Boot disk: NVMe 476.9 GB (nvme0n1)
Data pool: 4x Seagate IronWolf 8TB in RAIDZ1 (/dev/sda1, /dev/sdb1, /dev/sdc1, /dev/sdd1)
Pool name: “pool 1” (with space)
Pool GUID: 7835538760692273829
Pool Metadata (from zdb -l):
raidz_expand_txgs[0]: 1415393 (pool underwent RAIDZ expansion)
txg: 8349471 (identical on all four disks — data is consistent)
Features enabled: com.delphix:hole_birth, com.delphix:embedded_data, com.klarasystems:vdev_zaps_v2, org.openzfs:raidz_expansion
ZFS labels 0, 1, 2, 3: all present and coherent on all disks
The Problem:
After normal shutdown for server relocation, the pool refuses to import. The zpool import process hangs indefinitely:
sudo zpool import -f -d /dev -o cachefile=none "pool 1"
This command produces no output and never returns. Meanwhile, the boot logs show:
task IoThread:1350 blocked for more than 120 seconds -
task zpool:11319 blocked for more than 120 seconds -
ix-zfs.service - Import ZFS poolsstuck in “starting…” state (progresses from 39s → 3m57s → 5m5s but never completes) -
Kernel Tainted flag set due to prolonged task stalls
Diagnostics Performed:
SMART checks on all four disks: PASSED, zero reallocated sectors, zero uncorrectable errors
Sequential read speed: ~260 MB/s on all disks (hardware functioning normally)
zdb -l /dev/sda1/sdb1/sdc1/sdd1: all ZFS labels intact and coherent -
/dev/disk/by-partuuid/symlinks: all present and pointing correctly -
zpool.cache file present (1536 bytes, dated Jul 28)
iostat after first snapshot: zero I/O on sda/sdb/sdc/sdd — process is truly hung in kernel space
Root Cause (Known Bug):
This matches the symptoms of OpenZFS issue #18129: “Reboot after RAIDZ expand causes zpool import to hang”
https://github.com/openzfs/zfs/issues/18129
The combination of RAIDZ expansion (raidz_expand_txgs present in labels) and server interruption causes an indefinite deadlock during zpool import. The zfs kernel process enters uninterruptible sleep (state D) in spa_lookup, holding a lock that blocks all subsequent ZFS commands.
Question for the Community:
Is there a recovery procedure for this deadlock? I have read references to:
zpool import flags like -T or -X for transaction rollback
Manual ZFS pool recovery procedures
Possible kernel-level debugging steps
The pool data appears intact (all SMART checks passed, labels coherent, txg consistent), but I cannot access it due to this deadlock. Are there any known workarounds or recovery techniques for this specific bug?
Additional Context:
Configuration backup downloaded and restored, same issue persists
Clean TrueNAS SCALE 25.10.5 installation on new NVMe, same deadlock reproduced
All four disks physically present and detected by system
No recent hardware changes prior to relocation
Thank you for any guidance. I am willing to provide additional diagnostic output or logs if needed.
