That is both good and bad.
Good because they are all on the same ZFS write transaction, (like they should be). Bad because their is no obvious next course of action.
Except to ask, “Do you have a recent backup?”
yea, sadly, that’s a big negative on a recent back up.
Then my next suggestions are to use a recovery tool, or recovery service. Neither of which I have knowledge about. I vaguely recall the recovery tool being called Klennet or something. Googling it, I found:
I know next to nothing about it.
Good luck.
Yea I was already looking into trying Klennet. Was just hoping there was something else I could try first. There’s nothing on the disks that is irreplaceable except for maybe some photos. I’m pretty sure I have copies of all of those somewhere. Other than that it’s just music and movies which just = time.
Thanks a bunch for trying though. it’s much appreciated and I learned a little.
Just a note on Klennet. I don’t think it can handle pools that used RAID-Zx-expansion. Check their website for current info.
If I’m reading things right, I don’t think this applies to my situation. These are the original disks I used when I first created the pool. I have not added any disks to expand the pool. I’m new at this so I may be missing something.
Learned something new today.
Just a quick update. I ran the Klennet Recovery. Looking at the results, all the media and other share files are recoverable. I’m just not sure if it’s worth the price. I ran a couple cheaper recovery tools (UFS Explorer and ReclaiMe) but it’s not clear what all is recoverable with those and they are only slightly cheaper. If you really need to recover your data I think Klennet Recovery looks like the way to go. I’m just not sure if it’s worth it my case.
