Truenas scale docker problem
so suddenly after i restart my server my apps won’t auto start i tried to run them manually it gave me this error message
[EFAULT] Failed ‘up’ action for ‘nextcloud’ app, please check /var/log/app_lifecycle.log for more details
remove_circle_outline
More info…
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 488, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 535, in __run_body
rv = await self.middleware.run_in_thread(self.method, *args)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1364, in run_in_thread
return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1361, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 183, in nf
return func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 55, in nf
res = f(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/app_scale.py”, line 51, in start
compose_action(app_name, app_config[‘version’], ‘up’, force_recreate=True, remove_orphans=True)
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/compose_utils.py”, line 57, in compose_action
raise CallError(
middlewared.service_exception.CallError: [EFAULT] Failed ‘up’ action for ‘nextcloud’ app, please check /var/log/app_lifecycle.log for more details
any soultion please
Run sudo cat /var/log/app_lifecycle.log and post the results
Had this issue today while installing urbackup. Read the internets that unset pool then reconnect it might help. Worked for me. Could be only luck. I’m a beginner in Scale but succesfully installed Urbackup and MiniDLNA in custom apps using YAML!
