hi everyone i have an error installing, shows that failed up action
what might be the problem?
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 509, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 556, in __run_body
rv = await self.middleware.run_in_thread(self.method, *args)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1367, in run_in_thread
return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1364, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/usr/lib/python3/dist-packages/middlewared/service/crud_service.py”, line 268, in nf
rv = func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 55, in nf
res = f(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 183, in nf
return func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py”, line 203, in do_create
return self.create_internal(job, app_name, version, data[‘values’], complete_app_details)
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py”, line 248, in create_internal
raise e from None
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py”, line 241, in create_internal
compose_action(app_name, version, ‘up’, force_recreate=True, remove_orphans=True)
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/compose_utils.py”, line 57, in compose_action
raise CallError(
middlewared.service_exception.CallError: [EFAULT] Failed ‘up’ action for ‘nextcloud’ app, please check /var/log/app_lifecycle.log for more details
@Maor_K
Hard to say from this output what went wrong.
I am quite new to TrueNAS, but installed Nextcloud succesfully a few days ago. Please revisit the documentation and follow it meticulously. It brougth succes to me, why not to you?!
Try sudo cat /var/log/app_lifecycle.log in the shell
