Hi all, i get this error while running Rsync Task.
[EFAULT] rsync command returned 255
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 469, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 513, in __run_body
rv = await self.middleware.run_in_thread(self.method, *args)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1324, in run_in_thread
return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1321, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 191, in nf
return func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 53, in nf
res = f(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/plugins/rsync.py”, line 685, in run
raise CallError(msg)
middlewared.service_exception.CallError: [EFAULT] rsync command returned 255 - UNKNOWN. Check logs for further information.
I uses TrueNAS Scale on both hosts, and using SSH connection from the keychain method for running Rsync from this intructions.
Please help me to solve it.
Thanks in advance.
