Truenas scale network adapter problem
I just install tp link tx201 2.5 card its all working but logs is being spammed with - pcieport 0000:xx:xx.x: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
error status/mask=00000001/00002000
not sure if its a problem and how to fix
Some BIOSes allow you to disable PCIe bus error reporting like that, called AER (Advanced Error Reporting).
Now - whether or not that is a good idea is a different subject matter.
My guess is that the alerts stem from something in the PCIe power settings (in the BIOS) that Linux doesn’t like, but that’s just speculation.
