Unheathy pool
I’m getting an unhealthy pool error, and after looking around, I found how to check the status of the pool. I’ve also scrubbed the pool and the boot-pool, but still getting the errors. Not sure where to go from here.
truenas_admin@truenas[~]$ sudo zpool status -v pool1
[sudo] password for truenas_admin:
pool: pool1
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
scan: scrub in progress since Mon Sep 22 08:16:15 2025
959G / 1.20T scanned at 5.48G/s, 21.5G / 1.20T issued at 126M/s
0B repaired, 1.75% done, 02:43:34 to go
    NAME                                      STATE     READ WRITE CKSUM
    pool1                                     ONLINE       0     0     0
      mirror-0                                ONLINE       0     0     0
        c0db02e0-9664-5a4c-9424-a0cfa783f1bc  ONLINE       0     0     0
        6693ddbf-db2f-8548-b236-5a8a312f5516  ONLINE       0     0     0
    /var/db/system/configs-ae32c386e13840b2bf9c0083275e7941/TrueNAS-25.04.2.3/20250902.db
