So weird issues with my box. We were shutting down an old office and they had a bunch of WD 4TB red drives that had like 350 hours on each one.. I am assuming they were only stress tested and never really in production. I decided to upgrade the 2TB that I have in a ZFS that is 4 wide and only one used for redundancy just a simple raid for movies and photos. So i make sure my data was backed up and a removed one of the 2TB drives and replaced it with one of the 4TB drives and went to the UI and it didn’t show up.. did some research and rebooted the NAS and it wont show on the controller either. I took the drive and put it on my utility machine that has SpinRite 6.1 on it and went level 5 on the drive and 0 errors and works fine.. I am so confused why this drive will not show up on my TrueNAS box though not a TrueNAS issue because if the controller cannot see it when then that is why TrueNAS does not Enumerate it
My hardware setup is as follows
Drive Bay: Kingwin Hard Drive Enclosure for Computer PC Case Internal 3 Bay Hot Swap for 3.5” HDD SSD, Backplane Trayless, SATA I/II/III & SAS I/II 6 Gbps : Amazon.ca: Musical Instruments, Stage & Studio
HBA: YiBaoTong LSI 9211-8I SAS2008 6Gbps SAS HBA FW:P20 LSI 9211-8i IT Mode ZFS FreeNAS unRAID Controller Card 2* SFF-8087 SATA : Amazon.ca: Electronics
Any idea why on SpinRite works and runs perfectly fine but on this machine it wont.. I do have a single 8 TB drive on this just for NVR recording so I know the BIOS/MB/Controller can handle larger drives. Just no idea what I am missing here.
Appreciate any help!
