Webdav and network drive
Hi everybody. Is it possible to connect a network drive via WebDAV? If I insert a link https://192.168.1.4:30035/mywebdav / in the browser, it works great. If the same link is inserted into the mapping window, it says that the network path has not been found. What could be the problem?
Just did a quick google - came up with https://www.thewindowsclub.com/how-to-map-webdav-in-windows
look at the section labeled “Cannot connect to WebDAV Directory” - possible solution?
Thanks, I tried it. The result is the same. Does not work.
Thanks! This method with registry correction came up and it turned out to map a network drive using http. Using https still doesn’t work.
