Hi everyone,
I’m new to TrueNAS and I just started using 25.04.1 (when incus was introduced?) and while I could install the following OS: Windows 11, Windows Server 2025 or 2022, it would 100% of the time go in a recovery boot loop directly after the FIRST reboot AFTER joining the active directory domain.
I looked online to not find too much info on the issue but did find some info. Some hinted that it has something to do with the intel cpu.
I tried disabling all gpos, playing with tpm and secure boot, registry hacks, playing with different versions of virtio drivers, etc. Nothing worked.
However, I did notice that it did happen on proxmox too. CPU type: x86-64-v3 works stable though. Proxmox is using a similar CPU as my truenas: Intel Core Ultra 7 265k. My truenas is using Core Ultra 5 225.
So on 25.04.2 I again tried to install server 2025 with the exact same issue but with this new implementation it allowed me to try new settings, here are my findings:
- Cpu type: Host - has boot loop after AD join
- Cpu type: Host passthrough - has boot loop after AD join
- Cpu type: KVM64 - fails to get past press any key to boot to CD (to install)
- Cpu type: Qemu64 - fails to get past press any key to boot to CD (to install)
- Cpu type: Tried other various CPU models like broadwell, etc. - Complains not compatible
6. Cpu type: IvyBridge - Let me use the CPU model and install worked. No boot loop after joining AD + reboot afterwards.
I hope this might help others with my issue that I struggled with and maybe help get a proper cpu type added in dropdown menu settings that works with this cpu optimally.
My CPU: Intel Core Ultra 5 225 on a bare metal truenas (25.04.2)
Thank you everyone and developers.
Ive had my windows server 2025 DC installed for 1 day now stable, where as before it would boot loop after first reboot after joining active directory domain every time.
