Spice copied mouse actions into the VM, or it didn’t, there was no partial failure.
I’m not seeing that with VNC. VM running windows 10 receives clicks, but mouse movement only occurs when a click is down, i.e the cursor only moves if I drag, and that motion is relative i.e not at the site of my cursor. Connecting to Linux I only have my left clicks sent, but movement is fine.
Is anyone else seeing this? I’m using GNOME Connections 48.0.
Edit: Swapping to RealVNC viewer fixed the Linux issues. I’m still getting relative movement in Windows regardless of the relativeptr setting.
