Absolute path to configure Immich
Hi all.
I´m trying to configure an external library in Immich, and need to tell it where the images are…so I enter:
nvme1n1/mnt/imagem/imagemTN/FotosAVS
imagem is the pool and imagemTN is the parent dataset But it fails to validate the path. I installed Immich in a different disk so I know I have to give the full path…where is my mistake?
Thanks!
Try removing the nvme1n1 portion.
I did…did not work…and it makes sense since the images are in a different disk…
are you trying to add this in the app or on the Edit screen in TrueNAS?
in the app
You need to set up the host path to your library in the Storage Configuration for the App deployment
Oh, cool, will work on it, thanks!
