After setting static ip internet stopped working
First time installing TrueNAS and everything went smooth until I changed the IP address to a static one.
I can connect to the console, log in and do what i want to do from a settings perspective as long as it does not involve an internet connection like looking for updates, apps, etc. I can access the NAS from a different computer to browse the files.
When i try to look for updates i get: Cannot connect to host 443 ssl:default [Temporary failure in name resolution]: Automatic update check failed. Please check system network settings.
Trying to discover apps: [EFAULT] Failed to clone github link’ repository at ‘/mnt/.ix-apps/truenas_catalog’ destination: [EFAULT] Failed to clone ‘github link’ repository at ‘/mnt/.ix-apps/truenas_catalog’ destination: Cloning into ‘/mnt/.ix-apps/truenas_catalog’…
All of this worked before I set up the static ip address.
What am I missing here?
System Version: 25.04.0
Did you set a default gateway and one or more DNS servers?
I had a default gateway but I did not have a DNS server record. Once I added it, it just started working as expected.
I appreciate your extremely fast response/help!
